Remote Conversion Kit (Basic Model with Massage) Compatible with Rize or Privia Craftmatic Manuta by Ruoey Lung-Used for a lost/broken remote. 13 Button Backlit Controls Movement/Massage- NO PRESETS
$219.00
was $359.00 Save 39%
In stock: 10 available
This universal kit converts Mantua Rize Craftmatic or Reverie by Ruoey Lung bed base control boxes and includes a new wireless remote to control your bed base with advanced features like backlit lighting, a flashlight, and massage with three intensities and wave modes. Used to replace a lost or broken remote when there are no more replacements available
THIS KIT WILL NOT WORK WITH PRESETS LIKE ONE TOUCH FLAT OR MEMORY POSITIONS, we do have a kit that allows for that feature for a bit more if needed.
This kit includes all the wiring and ports needed to make your conversion. Simply unplug your four motors from the existing control box under your bed and plug them into our new unit. All of the remotes showed above used control boxes with four pin connection ports. As long as your box has massage and head and foot motors with four pins in the plugs and your remotes looked similar then this will work. (See above picture)
Total installation should take no more than 5 minutes but it does require plugging in your head and foot motors from under your bed. Kit Includes:
1) Wireless Remote Control with flashlight and backlighting. (Presets, Flat, and Memory Buttons will not work) Each remote uses three AAA batteries (included since we program this prior to shipping.). You can only have one remote paired with one box at a time. If you want to buy a 2nd remote to use as a backup, we sell them for $70 each.
We also offer this remote and control box without the memory features for $179 if interested.
Serta Perfect Position 1st Gen Converter Kit w/New Remote, Plug and Adapters
SKU 00119
$849.00
Reverie 2E/3E Head Only 2 or 3 Button Corded Remote
SKU 00281
was $139.00
Save 14%
$119.00
Replacement Remote Compatible with Ashley Sierra Sleep M9X4 (x4) Bases
SKU 00059
$179.00
Replacement White Wireless Remote Compatible with BedTech BT2500 Or Genesis (Bed Tech 2500) Bases
SKU 00251
was $159.00
Save 21%
$125.00
Replacement Wireless Remote Compatible with  Beautyrest and In Motion (inMotion) Old Gen Renew Plus Bases - ALSO AVAIL Blue FOR $20 Less
SKU 00101
$249.00
Replacement Power Cord Compatible with  Beautyrest Luxury, Advance, or Smartmotion (Smart Motion) 1.0/2.0/3.0 Beds- 3 Piece Set Inc Input Cord
SKU 00048
was $109.00
Save 27%
$80.00
Adjusta-Magic E91 (e-91) Or Certain Craftmatic Classic Corded Remotes Replacement (see 2nd Picture)
SKU 00050
$239.00
Replacement Remote Compatible with Sealy BASIC ONE VIBE E97 Old Generation Single Vibe (see Pics and Massage Info Below)
SKU 00124
$299.00
Ergomotion E4 or Tempur (must Match Picture Exactly) WIRED 2 Piece Conversion Kit- New Wireless White Remote & Control Box, See Pics
SKU 00116
was $299.00
Save 43%
$169.00
Leggett & Platt Simplicity HF Remote- Physical Button OEM Version Also Avail For $119- Ask For Info
SKU 10107
was $189.00
Save 11%
$169.00
Replacement Wireless Remote Compatible with  Beautyrest Simple Motion Beds (New Black With Light button Non Logo Version)
SKU 00276
was $135.00
Save 12%
$119.00
Replacement Remote Compatible with Leggett and Platt Basis C3 or Sleep Comfort (New 3 Preset Version) Scape
SKU 00087
$549.00
Leggett & Platt Signature, Simplicity 2.0, or certain 100 Or 300 Brio Series Remote- Disc. Model, See Pics
SKU 00034
$179.00
Reverie Oasis ERC117 Wireless Remote (New 4M Multi Button Version)
SKU 00092
was $149.00
Save 13%
$129.00
Leggett & Platt Raven K-120 White Remote
SKU 00036
was $149.00
Save 20%
$119.00
Replacement Wireless Remote Compatible with BedTech, Bob’s, or Moto Sleep (Motto Sleep) CH04-ZG Bases
SKU 10083
$199.00
Out of stock
Replacement Remote Compatible with Sleep Number Flex Fit or Select Comfort Shipshape Swingline Corded Bases NEW White OEM Version
SKU 00156
$299.00
Replacement Remote Compatible with Sealy Old Generation Or Certain Old WRLS 2 VIB Dual Massage
SKU 00126
$449.00
Ergomotion/Blissful Nights/InKline/Essence/Motion Air 5 or 6 Button Wireless Remote (Value Grey Remote Available For $135)
SKU 00272
$149.00
Leggett and Platt Wallhugger S-Cape (New Black Version) Old Gen E-95 WRLS 2 VIB Raven Remote
SKU 00019
$549.00
Leggett & Platt Symmetry Richmat HJH37 Remote
SKU 00208
was $169.00
Save 26%
$125.00
Conversion Kit Compatible with Boyd Specialty Sleep Adjusta Flex 5 Button Corded Remote (new 3 Pc Conversion Kit Version, See Pics)
SKU 10061
was $199.00
Save 10%
$179.00
Reverie 8T/9T or R600 R650 RC-WM-110 or Personal Comfort Flex 9 Wireless Remote with Lumbar Feature
SKU 00044
was $149.00
Save 13%
$129.00
Leggett & Platt Promotion 2.0 Remote
SKU 00133
was $149.00
Save 20%
$119.00
Replacement Remote Compatible with Idealbeds 5i/custom Wireless Remote (New Name brand Replacement Remote With All The Same Features- ideal)
SKU 00277
was $149.00
Save 20%
$119.00
Ergomotion Softide 8100 Or 8300 Remote- Discontinued- See Our New Conversion Kit
SKU 00111
$249.00
Out of stock
Replacement Remote Compatible w Profile DC, Series III, Innova, Sleep Number Corded, or 1st Gen Brio Replacement Corded Remote - (Use Promo Code “scratch” To Save $10 Off A Slightly Scratched Model
SKU 10053
was $129.00
Save 8%
$119.00
Replacement Remote Compatible with Sealy Ease 1.0/2.0/ or 3.0 Generation Slightly Scratched 30 Day Trial OEM with Added Zero-G And Memory Presets- See Picture For The Remote You’ll Get
SKU 00055
was $139.00
Save 14%
$119.00
Remote Replacement Compatible with S-Cape E95 (E-95), Adjusta-Sleep, Certain Old Gen Craftmatic, WRLS 2 VIB, and Certain Contour Premier, Sleep Comfort, Eurosleep, Simmons Series 2000, or Craft 1
SKU 00018
$549.00
Okimat 2 Okin Remote Compatible with New Gen Craftmatic/Comfort Base Remote, 258A Model Electropedic, or Saatva Lineal Bases- Must Match Back Of Old Remote Exactly w Oval Button above AAAs
SKU 00209
$339.00
Replacement Remote Compatible with Sleep Number/ Select Comfort 12 Button Flexfit 3 (Flex Fit) 360 Version
SKU 00309
was $199.00
Save 40%
$119.00
Leggett And Platt D-Series (D Series) Converter Kit w/Plug, New Motors, and Adapters #4b8900
SKU 00143
$399.00
Replacement Remote Control Protection Plan -No Deductible 5 Year
SKU 00098
$79.00
Replacement Remote Compatible with  Ashley Sierra Sleep M9X9 Or Black Moto Sleep ZG3 Bases
SKU 00061
$249.00
E95 Scape (S-cape) -Only Compatible with Certain Old Gen Craftmatic, and Certain Okimat or Hb310 Leggett Or Sealy Remotes
SKU 00100
$549.00
Leggett And Platt Softline Pro-Motion, Swingline, Sleep Number Flex Fit Wired, Series III, or 1st Gen Brio (new Black And White Version- Top Right Pic)
SKU 00073
was $129.00
Save 8%
$119.00
Replacement Remote Compatible with Certain Model Craftmatic Legacy (l132 L-132 Series) Linak Bed Remotes- See Our Universal Conversion Kits
SKU 00043
$549.00
Replacement Remote Compatible with Living Comfort, Euro Sleep, and WRLS 2 VIBE Adjustable Bed Remote Replacement
SKU 00305
$549.00
Serta Motion Plus Headboard Brackets Set (All Sizes) make sure to match the picture of the remote on the second page
SKU 00094
was $119.00
Save 17%
$99.00
Scape Converter Kit w/Plug and #7453 Adapters. Works for the Interflex Titanium, Gold, and certain Englander Or Orthomatic remotes
SKU 00108
$849.00
E95 Scape Control Box Only
SKU 10042
$279.00
Silver Replacement Remote Compatible With Leggett & Platt S-Cape (scape) 700 or Performance Remote w/pillow Tilt Buttons - See Second Picture for the One You Will Receive
SKU 00033
$499.00
RC-WM-101 Replacement Remote Compatible with Tempurpedic Ergo Advanced (New Gray RC-WM-119 Version) Remote
SKU 00022
was $149.00
Save 20%
$119.00
Leggett & Platt S-Cape (scape) 2.0 Zero Clearance Version (Not Old Gen 2.0 Black Remote- See Other Listing) w Flashlight Button
SKU 10079
was $199.00
Save 25%
$149.00
Ergomotion Pure Contour Silver, Gold, or Elite or certain model OKIN Enso Value Remote
SKU 00117
was $149.00
Save 20%
$119.00
SKU 00058
was $249.00
Save 20%
$199.00
Reverie or Purple Powerbase 8Q Or 8X RC-WM-e53 Replacement Remote
SKU 00079
was $149.00
Save 9%
$135.00
Ergomotion E6 (New Grey version) Remote
SKU 00093
was $149.00
Save 20%
$119.00
Leg Kit Compatible with Serta Motion Essentials (all Gens But The 2nd)/Perfect, Certain Blissful Nights, and Sealy or Beautyrest New Gen 3-9” (4 Legs Total) 1st Gen
SKU 00270
was $99.00
Save 20%
$79.00
Replacement Wireless Remote Compatible with  Beautyrest Advance Motion Bases- Value Remote w More Functionality Available For $40 Less
SKU 00144
$159.00
