$189.00
was $249.00 Save 24%
In stock: 10 available
This and the X5 Remote look exactly the same but run on different frequencies. You can look under your bed frame for a sticker with your proper model number to identify it before ordering or call us for help! If you have your old remote still, the model number will end in FB
 If you are unsure, you can purchase our Conversion Kit which will replace the control box and give you a new remote with more functionality and will save your money down the road if you ever need to replace your remote again:
https://www.adjustablebedremotes.com/#!/Ashley-Sierra-Sleep-M9X5-or-M9X7-Conversion-Kit-with-New-Model-Remote-X7-Or-X5/p/494040849
SKU 10113
was $399.00
Save 8%
$369.00
