Replacement White Wireless Remote Compatible with BedTech BT2500 Or Genesis (Bed Tech 2500) Bases
$125.00
was $159.00 Save 21%
In stock: 15 available
This will only work with the BT2500 or genesis Richmat bases that featured the identical remote as pictured. If your original remote had additional rows or any other different button icons or words this may not work. You will receive a remote that looks similar to the one on the right that is manufactured by the same company and will give you access to the head and foot motors and a one touch flat and memory position button, in addition to a flashlight and massage functionality. If you’re older Remote did not have head and foot massage, the new remote will not give you added massage functionality.
SKU 10113
was $399.00
Save 8%
$369.00
