Replacement Remote Compatible with Sealy BASIC ONE VIBE E97 Old Generation Single Vibe (see Pics and Massage Info Below)
$299.00
In stock: 13 available
This has now been replaced with the black remote as pictured made by the OEM. If you had a dual massage bed you need to view our other Sealy listings if you want it to operate both massage units. On certain units, some of the buttons will be interchanged and thought the massage will turn in, none of the buttons will turn it off without unplugging the bed due to an old processing unit. Unfortunately the only fix for this would be to replace the control box. Also, there is no way to know before hand if this will happen or not on your unit. The control box would be $200-$300 if you wanted to add that. A great workaround besides labeling the buttons differently for reference to use the massage motor would be to plug your bed into a smart phone Wireless Adapter so that you could turn off the power and cut the massage if needed
SKU 10113
was $399.00
Save 8%
$369.00
