This universal kit converts Mantua Rize Craftmatic, Boyd, or Reverie by Ruoey Lung bed base control boxes and includes a new wireless remote to control your bed base with advanced features like presets, one touch flat, and massage with three intensities and wave modes. Used to replace a lost or broken remote when there are no more replacements available or in budget or to upgrade a basic remote with only a few buttons.
This kit includes all the wiring and ports needed to make your conversion. Simply unplug your four motors from the existing control box under your bed and plug them into our new unit. All of the remotes showed above used control boxes with four pin connection ports. As long as your box has massage and head and foot motors with five pins in the plugs then this will work. (See above picture)
Total installation should take no more than 5 minutes but it does require tipping the bed on its side or sliding under the bed to secure the new unit once plugged in.Kit Includes:
1) Conversion Control Box with Wire Harnesses and a Power Supply Cable/Transformer Box - Simply plug in the old cords into our new box
1) Wireless 13 Button Remote Control with flashlight and backlighting- Simply plug in the kit after it’s installed and the remote will work. Each remote uses three AAA batteries (included since we program this prior to shipping.). You can only have one remote paired with one box at a time or if you reach out to us we can pair one remote to two boxes if you want to synchronize your king split base. If you want to buy a 2nd remote to use as a backup, we sell them for $70 each.
We also offer this remote and control box without the massage buttons and hookups (if you didn’t want the extra buttons which won’t work to be on the remote even though it doesn’t hurt anything) or with massage but a universal wiring harness (if you don’t mind taking a few more minutes and cutting and stripping your massage and motor wires under your bed) for $50 less
Here:
Or Here:
