Conversion Kit Compatible with Homelegance or Hofish Adjustable Base Remote
$199.00
was $209.00 Save 5%
In stock: 16 available
This is a two piece conversion kit for the Remote pictured in the listing. You will receive a new control box and a new wireless remote with the same features as the originaly. The remote will be slightly different shape but all of the functionality will be the same but we have a flashlight button and one touch flat on our new remote!
We will provide installation instructions but it is as easy as unplugging two cords from under the bed and plugging them into our new unit. We will Pre-program the remote for you so once you plug in your unit and put AAA batteries in the remote, you will be good to go. This also includes a brand new power supply
SKU 10113
was $399.00
Save 8%
$369.00
