Ergomotion and Certain Kingsdown V400 4 Pin (NOT 6) Remote Replacement
$346.95
In stock: 3 available
Check behind your battery cover to verify if you have 4 white pins labeled 1-4 that can be moved up or down… not A-D or 6. These are model specific replacements.
We also sell Conversion Kit for $50 less at this link that will require swapping out the control box under the bed, but the other advantage of this is that you can purchase a second remote for only $119 and have them synchronized together and all future remotes would only be $119: https://www.adjustablebedremotes.com/#!/Replacement-2-Piece-Conversion-Kit-Compatible-w-Simmons-Nuflex-or-Softide-5100-8100-no-Lumbar-Support-6-Pin-New-Grey-Version-Remote-Replaces-Lost-or-Broken-Remote/p/186483330
SKU 10113
was $399.00
Save 8%
$369.00
