Remote Conversion Kit (Basic Model with Massage) Compatible with Rize or Privia Craftmatic Manuta by Ruoey Lung-Used for a lost/broken remote. 13 Button Backlit Controls Movement/Massage- NO PRESETS
$219.00
was $359.00 Save 39%
In stock: 2 available
This universal kit converts Mantua Rize Craftmatic or Reverie by Ruoey Lung bed base control boxes and includes a new wireless remote to control your bed base with advanced features like backlit lighting, a flashlight, and massage with three intensities and wave modes. Used to replace a lost or broken remote when there are no more replacements available
THIS KIT WILL NOT WORK WITH PRESETS LIKE ONE TOUCH FLAT OR MEMORY POSITIONS, we do have a kit that allows for that feature for a bit more if needed.
This kit includes all the wiring and ports needed to make your conversion. Simply unplug your four motors from the existing control box under your bed and plug them into our new unit. All of the remotes showed above used control boxes with four pin connection ports. As long as your box has massage and head and foot motors with four pins in the plugs and your remotes looked similar then this will work. (See above picture)
Total installation should take no more than 5 minutes but it does require plugging in your head and foot motors from under your bed. Kit Includes:
1) Wireless Remote Control with flashlight and backlighting. (Presets, Flat, and Memory Buttons will not work) Each remote uses three AAA batteries (included since we program this prior to shipping.). You can only have one remote paired with one box at a time. If you want to buy a 2nd remote to use as a backup, we sell them for $70 each.
We also offer this remote and control box without the memory features for $179 if interested.
Ergomotion Softide 2100 WIRELESS Remote - NEW 2 Pc Conversion kit - See attachedErgomotion Softide 2100 WIRELESS Remote - NEW 2 Pc Conversion kit - See attached
SKU 00113
was $299.00
Save 27%
$219.00
Serta Motion Perfect IV (4 4th Gen) Remote
SKU 00017
was $169.00
Save 30%
$119.00
Old Gen Nuflex and Serta Motion Perfect Massage Combination Splitter Cord (2 Sets to Sync/Split Four Massage Units Down To 2)
SKU 10080
$49.00
Serta iSeries (New Serta Logo) Okin Remote
SKU 00016
was $149.00
Save 34%
$99.00
Leggett & Platt C-Series (C Series 9644) Universal Conversion Kit (old Model Disc.)Leggett & Platt C-Series (C Series 9644) Universal Conversion Kit (old Model Disc.)
SKU 00257
was $199.00
Save 10%
$179.00
Replacement Remote Compatible with Sleep Number Or Select Comfort Flex Fit And Flex Fit+ Plus (flexfit) DUAL VIBE Non-LCD Version (see Pics)
SKU 00154
was $249.00
Save 4%
$239.00
Replacement Remote Compatible with Living Comfort, Euro Sleep, and WRLS 2 VIBE Adjustable Bed Remote ReplacementReplacement Remote Compatible with Living Comfort, Euro Sleep, and WRLS 2 VIBE Adjustable Bed Remote Replacement
SKU 00305
$349.00
Leggett & Platt Prodigy PT Massage HF and Pillow Tilt Remote Alternative w Physical Buttons- See 2nd Pic. Note, Your Original Remote Must Match Exactly This Picture and Cannot Have Bluetooth LogosLeggett & Platt Prodigy PT Massage HF and Pillow Tilt Remote Alternative w Physical Buttons- See 2nd Pic. Note, Your Original Remote Must Match Exactly This Picture and Cannot Have Bluetooth Logos
SKU 10108
$199.00
Reverie 3E Tech RC-WM-E57 Wireless (New Grey Version) RemoteReverie 3E Tech RC-WM-E57 Wireless (New Grey Version) Remote
SKU 00030
was $129.00
Save 23%
$99.00
Mlily Adjustables MS200 TwXL (Buy 2 to make a Split King) Size 750lb Capacity Adjustable Bed w/Free ShippingMlily Adjustables MS200 TwXL (Buy 2 to make a Split King) Size 750lb Capacity Adjustable Bed w/Free Shipping
SKU 00173
was $799.00
Save 19%
$649.00
Replacement Wireless Remote Compatible with Beautyrest Leggett Old Gen Renew or Certain Older Gen Model T-120 or M-120 (Linak- Not Richmat New Silver T120 or M120 Version Only) Basic Wireless Bases
SKU 00054
$169.00
Serta Pivot RC-HW-107 Corded Remote
SKU 00062
$169.00
Adjusta-Magic E92 (e-92), Wired Contour Premier, and Replacement For Certain Wired Craft 1 Craftmatic Corded RemotesAdjusta-Magic E92 (e-92), Wired Contour Premier, and Replacement For Certain Wired Craft 1 Craftmatic Corded Remotes
SKU 00051
$399.00
HHC XSF200 Moto Sleep (Motto Sleep) CH11-HM Massage Remote- Important, Does Not Work With Ch 11 – HMAS M9x8 Bed Bases- See Our Other Listing
SKU 00131
$199.00
Replacement Remote Compatible with InKline White Noise 5 Button or Black 6 Button BasesReplacement Remote Compatible with InKline White Noise 5 Button or Black 6 Button Bases
SKU 10095
$149.00
Leggett & Platt Symmetry Richmat HJH37 Remote
SKU 00208
was $169.00
Save 36%
$109.00
Serta Motion Essentials II (2nd) Gen hb12012-00 M-120 Linak Wired Remote (Alt black version avail. for $60 less!)Serta Motion Essentials II (2nd) Gen hb12012-00 M-120 Linak Wired Remote (Alt black version avail. for $60 less!)
SKU 00002
was $179.00
Save 11%
$159.00
Out of stock
Authentic Okin Replacement Power Cord Compatible with Beautyrest Luxury, Advance, or Smartmotion (Smart Motion) 1.0/2.0/3.0 Beds- 3 Piece Set Inc Input Cord
SKU 00048
was $109.00
Save 27%
$80.00
Ergomotion E6 Remote
SKU 00093
was $149.00
Save 20%
$119.00
Replacement Wireless Remote Compatible with Beautyrest Black Luxury Or Motion Restore BasesReplacement Wireless Remote Compatible with Beautyrest Black Luxury Or Motion Restore Bases
SKU 00145
was $149.00
Save 30%
$105.00
Replacement Remote Compatible with Adjusta-Magic Signature BASIC ONE VIBE Old Generation E02 -K1, E91SS, Certain Sleep Comfort & Lifestyles Silhouette (see Pics)
SKU 00151
$299.00
Richmat HJH55 (New Version- see pics) Remote Compatible with Classic Brands As Seen On Wayfair or Nectar- Works With Certain HJC18 Massage Control Boxes as Shown Richmat HJH55 (New Version- see pics) Remote Compatible with Classic Brands As Seen On Wayfair or Nectar- Works With Certain HJC18 Massage Control Boxes as Shown
SKU 10096
was $159.00
Save 25%
$119.00
Ergomotion 6 Button 5 PIN (not 7) Corded Remote
SKU 10087
$149.00
Replacement Remote Compatible with Tempurpedic B3111-220 Ergo Series TES Wired Remote RC-HW-106 Or Rc-hw-110
SKU 00024
was $149.00
Save 20%
$119.00
Reverie OSO O300 ERC239A01 (erc239) 433 MHz Oso300 Wireless Remote
SKU 00166
was $149.00
Save 7%
$139.00
Leggett & Platt Scape HF Massage And Certain Model MF 900 Remote- Physical Button OEM Version (original Glass Front Version Discontinued)Leggett & Platt Scape HF Massage And Certain Model MF 900 Remote- Physical Button OEM Version (original Glass Front Version Discontinued)
SKU 10088
was $149.00
Save 20%
$119.00
Original White Reverie 3E Wired RC-HW-105 or RC-HW-106 Corded Remote- Use Promo Code “TES” To Save $40 For The Black New Gen Option Shown In The 2nd Picture Original White Reverie 3E Wired RC-HW-105 or RC-HW-106 Corded Remote- Use Promo Code “TES” To Save $40 For The Black New Gen Option Shown In The 2nd Picture
SKU 00025
$199.00
Out of stock
Reverie 3E Mesh RC-WM-113 (replaces -117) Wireless Remote 3EM- Used Showroom Model w/o Battery Cover Option Avail For $75Reverie 3E Mesh RC-WM-113 (replaces -117) Wireless Remote 3EM- Used Showroom Model w/o Battery Cover Option Avail For $75
SKU 00027
was $129.00
Save 23%
$99.00
Reverie Oasis ERC117 Wireless Remote (New 4M Multi Button Version)
SKU 00092
was $149.00
Save 34%
$99.00
Reverie 5i, 5D, 7S, R400 or 450, or 4M Replacement Remote
SKU 00028
was $139.00
Save 29%
$99.00
Serta Motion Select (Light Gray Version) Remote
SKU 00039
was $139.00
Save 29%
$99.00
Replacement Remote Compatible with Bnkdt By Wayfair Blissful Nights, Ergomotion Sherwood Bedding, Or Sapphire Sleep Series Bases- New Alt VersionReplacement Remote Compatible with Bnkdt By Wayfair Blissful Nights, Ergomotion Sherwood Bedding, Or Sapphire Sleep Series Bases- New Alt Version
SKU 00306
$149.00
SKU 00055
was $139.00
Save 14%
$119.00
Leggett & Platt S-Cape (scape) 2.0 Zero Clearance Version (Not Old Gen 1.0 or 2.0 Black Remote- See Other Listing) w Flashlight Button
SKU 10079
was $299.00
Save 20%
$239.00
Ergomotion V/400 Series 6 Pin New 2 Pc Conversion Kit - See PicsErgomotion V/400 Series 6 Pin New 2 Pc Conversion Kit - See Pics
SKU 00071
was $349.00
Save 23%
$269.00
Okin Input Section Only for Power Cord Compatible with Serta/Sealy/Beautyrest (Motion Perfect 2/3/4, Motion Essentials 3/4/5, iSeries, Motion Plus/Air, Motion Custom 2/3, Ease, Extend, SmartmotionOkin Input Section Only for Power Cord Compatible with Serta/Sealy/Beautyrest (Motion Perfect 2/3/4, Motion Essentials 3/4/5, iSeries, Motion Plus/Air, Motion Custom 2/3, Ease, Extend, Smartmotion
SKU 10082
was $79.00
Save 13%
$69.00
Replacement Remote Compatible with Sealy Premier X-10 (x10) E97 Dual Vibe RemoteReplacement Remote Compatible with Sealy Premier X-10 (x10) E97 Dual Vibe Remote
SKU 00125
$599.00
Ergomotion E4 Series WIRED 2 Piece Conversion Kit- See Pics- New Wireless White Remote & Control BoxErgomotion E4 Series WIRED 2 Piece Conversion Kit- See Pics- New Wireless White Remote & Control Box
SKU 00115
was $299.00
Save 10%
$269.00
Leggett & Platt S-Cape (scape) Version 2.0 or Simplicity 3.0 Remote
SKU 00075
was $369.00
Save 19%
$299.00
Out of stock
Serta Motion Signature (New Version -Lift/Massage) RC-WM-E01 Replacement Remote
SKU 00038
was $140.00
Save 29%
$99.00
Ergomotion E4+ WIRELESS Remote- New Grey VersionErgomotion E4+ WIRELESS Remote- New Grey Version
SKU 00218
was $149.00
Save 20%
$119.00
Replacement Power Cord Compatible with certain model Sealy and Tempurpedic Extend, Ergo & Ease 1.0/2.0/3.0 - 3 Piece Set
SKU 00042
was $109.00
Save 13%
$95.00
Power Cord Compatible with Certain Model Leggett 50 Series, and Matt Firm 300/600 3 Piece Set
SKU 00181
was $109.00
Save 9%
$99.00
Replacement Remote Compatible with Ashley Sierra Sleep M9X9 Or Black Moto Sleep ZG3 X9 Bases
SKU 00061
was $299.00
Save 17%
$249.00
Replacement Remote Compatible with Certain MLily, Sven & Son, Classic Brands, or Idle Sleep NL300/nl300u Bases -Works With HJC18 Massage or NU203CB Control Boxes (Style May Vary)Replacement Remote Compatible with Certain MLily, Sven & Son, Classic Brands, or Idle Sleep NL300/nl300u Bases -Works With HJC18 Massage or NU203CB Control Boxes (Style May Vary)
SKU 10045
was $159.00
Save 15%
$135.00
MLily Or Idle Sleep NL200/nl200u Remote Control -Works With HJC18 Control Boxes
SKU 10054
was $159.00
Save 25%
$119.00
Replacement Remote Compatible with Sleep Number/ Select Comfort 12 Button Flexfit 3 (Flex Fit) 360 Version
SKU 00309
was $199.00
Save 30%
$139.00
Ergomotion Pure Contour Silver, Gold, or Elite or certain model OKIN Enso Value Remote
SKU 00117
was $149.00
Save 20%
$119.00
MLily NU400 or NP2W+ Remote Control -Works With HJC18 And HJH55 Massage Control BoxesMLily NU400 or NP2W+ Remote Control -Works With HJC18 And HJH55 Massage Control Boxes
SKU 10048
was $159.00
Save 9%
$145.00
Richmat HJH13D, E300 Or HJH55, Compatible with Revive LS2000, Classic Brands (New White Wireless Remote by Mlily) Works With HJC18 No Massage Control BoxesRichmat HJH13D, E300 Or HJH55, Compatible with Revive LS2000, Classic Brands (New White Wireless Remote by Mlily) Works With HJC18 No Massage Control Boxes
SKU 00286
was $159.00
Save 15%
$135.00
