Replacement Remote Compatible with Ashley Sierra Sleep M9x5 (X5)(not X7) For a less Expensive Option on Future Replacements, See our Conversion Kit
$179.00
was $209.00 Save 14%
In stock: 13 available
This and the X7 Remote look exactly the same but run on different frequencies. You can look under your bed frame for a sticker with your proper model number to identify it before ordering.
You can also order a Conversion Kit from us if you’re unsure of which one you need first the same price If this looked the same as your older Remote, but you no longer have the M9X sticker under the bed.. Or if you just wanted to save a little extra on future replacements as down the road, converted Remotes are half the price. Reach out to us if you have questions on that
SKU 10113
was $399.00
Save 8%
$369.00
