$119.00
was $139.00 Save 14%
In stock: 30 available
As of 2020, the original Ease remote has been replaced by these new OEM versions from an upgraded model that may gives access to 3 new presets depending on your control box. As long as your original remote looked like one of those shown in the picture, this replacement will work without issue. Because the Ease frame did not feature massage or an underbed light, those buttons will not operate anything on the new remote but you may now have new access to the preset buttons and a more damage and scratch resistant remote.
Replacement Headboard Kit Compatible with Sealy Tempurpedic Ergo Extend Or Ease 1.0, 2.0, 3.0, or 4.0 Headboard Brackets Set (All Sizes)
SKU 00096
was $129.00
Save 23%
$99.00
Okin Input Section Only for Power Cord Compatible with Serta/Sealy/Beautyrest (Motion Perfect 2/3/4, Motion Essentials 3/4/5, iSeries, Motion Plus/Air, Motion Custom 2/3, Ease, Extend, SmartmotionOkin Input Section Only for Power Cord Compatible with Serta/Sealy/Beautyrest (Motion Perfect 2/3/4, Motion Essentials 3/4/5, iSeries, Motion Plus/Air, Motion Custom 2/3, Ease, Extend, Smartmotion
SKU 10082
was $79.00
Save 13%
$69.00
SKU 10113
was $399.00
Save 8%
$369.00
Replacement Remote Compatible with Sealy Ease 1.0 2.0 3.0 or 4.0 - New 6 Button Serta Version
SKU 00248
was $169.00
Save 41%
$99.00
Replacement Power Cord Compatible with certain model Sealy and Tempurpedic Extend, Ergo & Ease 1.0/2.0/3.0 - 3 Piece Set
SKU 00042
was $109.00
Save 13%
$95.00
