Conversion Kit Extra Box $ Power Source Add-On (no Remote Included- Non-Massage Basic Model) Compatible with Reverie, Rize TRUWR-P2, Privia, Customatic, Tempur Up, Etc
$119.00
was $299.00 Save 60%
In stock: 6 available
This is an add-on kit to connect 2/2 of a split king together. Compatibility requires an existing Kit and Remote
This listing includes
Serta Motion Custom II/III Remote - We Also Have a Value Remote Available For $40 Less w/o LumbarSerta Motion Custom II/III Remote - We Also Have a Value Remote Available For $40 Less w/o Lumbar
SKU 00013
was $199.00
Save 15%
$169.00
Serta iSeries (New Serta Logo) Okin Remote
SKU 00016
was $149.00
Save 34%
$99.00
Reverie RC-WM-103, RC-WM-107, RC-WM-108 and Select Model RC-WM-103 Orthomattress Rcwm103 (buttons Must Match Exactly) ERC108 Replacement RemoteReverie RC-WM-103, RC-WM-107, RC-WM-108 and Select Model RC-WM-103 Orthomattress Rcwm103 (buttons Must Match Exactly) ERC108 Replacement Remote
SKU 00127
was $139.00
Save 29%
$99.00
Leggett & Platt Scape HF Massage And Certain Model MF 900 Remote- Physical Button OEM Version (original Glass Front Version Discontinued)Leggett & Platt Scape HF Massage And Certain Model MF 900 Remote- Physical Button OEM Version (original Glass Front Version Discontinued)
SKU 10088
was $149.00
Save 20%
$119.00
Leggett And Platt Series II Silver Corded Remote (Must Look The Same -includes Cord)
SKU 10050
$399.00
Serta Pivot RC-HW-107 Corded Remote
SKU 00062
$169.00
Okimat 2 Okin Remote Compatible with New Gen Craftmatic/Comfort Base Remote, 258A Model Electropedic, or Saatva Lineal Bases- Must Match Back Of Old Remote Exactly w Oval Button above AAAs Okimat 2 Okin Remote Compatible with New Gen Craftmatic/Comfort Base Remote, 258A Model Electropedic, or Saatva Lineal Bases- Must Match Back Of Old Remote Exactly w Oval Button above AAAs
SKU 00209
$339.00
Replacement Wireless Remote Compatible with Beautyrest Leggett Old Gen Renew or Certain Older Gen Model T-120 or M-120 (Linak- Not Richmat New Silver T120 or M120 Version Only) Basic Wireless Bases
SKU 00054
$169.00
Ergomotion E4 or Tempur (must Match Picture Exactly) WIRED 2 Piece Conversion Kit- New Wireless White Remote & Control Box, See PicsErgomotion E4 or Tempur (must Match Picture Exactly) WIRED 2 Piece Conversion Kit- New Wireless White Remote & Control Box, See Pics
SKU 00116
was $299.00
Save 43%
$169.00
Replacement Wireless Remote Compatible with  Beautyrest Smartmotion 1.0 (New Serta Grey Remote) Smart Motion Bases
SKU 00063
was $169.00
Save 30%
$119.00
Ergomotion V/400 Series 6 Pin New 2 Pc Conversion Kit - See PicsErgomotion V/400 Series 6 Pin New 2 Pc Conversion Kit - See Pics
SKU 00071
was $349.00
Save 23%
$269.00
Leggett And Platt Series 1 Lifestyle Corded Remote (includes Cord)
SKU 10049
$289.00
E95 Scape Converter Kit w/Plug and #3133 Short Adapters
SKU 00118
$799.00
Leggett & Platt S-Cape (scape) Version 2.0 or Simplicity 3.0 Remote
SKU 00075
was $369.00
Save 19%
$299.00
Out of stock
Leggett And Platt D-Series (D Series) Converter Kit w/Plug, New Motors, and Adapters #4b8900Leggett And Platt D-Series (D Series) Converter Kit w/Plug, New Motors, and Adapters #4b8900
SKU 00143
$399.00
Replacement Remote Compatible with Sealy BASIC ONE VIBE E97 Old Generation Single Vibe (see Pics and Massage Info Below)
SKU 00124
$299.00
Ergomotion E4 Series WIRED 2 Piece Conversion Kit- See Pics- New Wireless White Remote & Control BoxErgomotion E4 Series WIRED 2 Piece Conversion Kit- See Pics- New Wireless White Remote & Control Box
SKU 00115
was $299.00
Save 10%
$269.00
Replacement Remote Compatible with Mattress Firm 600 MF600 or Pillow Tilt Prodigy Basses (Make Sure You’re Getting The Correct One). Value Option Available For $260 Less.
SKU 00162
$499.00
Replacement Remote Compatible with Ashley Sierra Sleep M9X4 (x4) Bases
SKU 00059
$179.00
Leggett & Platt Symmetry Richmat HJH37 Remote
SKU 00208
was $169.00
Save 36%
$109.00
Ergomotion/Blissful Nights/InKline/Essence/Motion Air 5 or 6 Button Wireless Remote (Value Grey Remote Available For $119)Ergomotion/Blissful Nights/InKline/Essence/Motion Air 5 or 6 Button Wireless Remote (Value Grey Remote Available For $119)
SKU 00272
$159.00
Replacement Remote Compatible with Bnkdt By Wayfair Blissful Nights, Ergomotion Sherwood Bedding, Or Sapphire Sleep Series Bases- New Alt VersionReplacement Remote Compatible with Bnkdt By Wayfair Blissful Nights, Ergomotion Sherwood Bedding, Or Sapphire Sleep Series Bases- New Alt Version
SKU 00306
$149.00
Reverie R600/ R650 Dual Tilt Wireless Rechargeable Remote LED Versions (or Value Non-led Version w/AAA Batteries for $129)
SKU 00069
$449.00
Whisper Power Replacement Remote Compatible with Certain Craftmatic Craft 1 Bases NEW GEN (MUST READ BELOW TO VERIFY MODEL- DONT JUST GO OFF THE PICTURE ON THIS ONE)Whisper Power Replacement Remote Compatible with Certain Craftmatic Craft 1 Bases NEW GEN (MUST READ BELOW TO VERIFY MODEL- DONT JUST GO OFF THE PICTURE ON THIS ONE)
SKU 00147
was $299.00
Save 7%
$279.00
Ergomotion 5 Button 7 PIN (not 5) Corded Remote
SKU 10086
$159.00
Serta Motion Select (Light Gray Version) Remote
SKU 00039
was $139.00
Save 29%
$99.00
Serta Motion Essentials and Ergo Black 1st Gen 1.0 (New 2 Pc Conversion Kit Version) Remote ReplacementSerta Motion Essentials and Ergo Black 1st Gen 1.0 (New 2 Pc Conversion Kit Version) Remote Replacement
SKU 00001
was $299.00
Save 40%
$179.00
Replacement Remote Compatible with Ashley Sierra Sleep M9x5 (X5)(not X7) For a less Expensive Option on Future Replacements, See our Conversion Kit
SKU 00056
was $209.00
Save 14%
$179.00
Ergomotion 6 Button Wired Remote Replacement Conversion Kit (New Control Box And Remote)Ergomotion 6 Button Wired Remote Replacement Conversion Kit (New Control Box And Remote)
SKU 00112
was $299.00
Save 17%
$249.00
Replacement Remote Compatible with Mattress Firm En300 MF300 Series Richmat 8 Button White Version See Pics (Not Black and White Leggett Stand Up or Leggett 7 Button Top Line) Works With ML190 /NL200Replacement Remote Compatible with Mattress Firm En300 MF300 Series Richmat 8 Button White Version See Pics (Not Black and White Leggett Stand Up or Leggett 7 Button Top Line) Works With ML190 /NL200
SKU 00278
was $159.00
Save 25%
$119.00
Linak Or Easy Rest Easyrest Premier Wired (Now New Wireless Version - See Pics) Remote and Wireless Adapter by Leggett and Platt (We Have a Few Corded Remotes Left For $150 Less)Linak Or Easy Rest Easyrest Premier Wired (Now New Wireless Version - See Pics) Remote and Wireless Adapter by Leggett and Platt (We Have a Few Corded Remotes Left For $150 Less)
SKU 00072
$279.00
Richmat HJH55 (New Version- See Description) Compatible with Mattress 600 or 3000 Silver or Black, Enso, Classic Brands Innova NU203CB, PostureCloud- Works with Certain HJC18  Boxes - Mf3000Richmat HJH55 (New Version- See Description) Compatible with Mattress 600 or 3000 Silver or Black, Enso, Classic Brands Innova NU203CB, PostureCloud- Works with Certain HJC18  Boxes - Mf3000
SKU 00256
was $159.00
Save 21%
$125.00
Serta Motion Essentials II (2nd) Gen hb12012-00 M-120 Linak Wired Remote (Alt black version avail. for $60 less!)Serta Motion Essentials II (2nd) Gen hb12012-00 M-120 Linak Wired Remote (Alt black version avail. for $60 less!)
SKU 00002
was $179.00
Save 11%
$159.00
Out of stock
Replacement Wireless Remote Compatible with BedTech, Bob’s, or Moto Sleep (Motto Sleep) CH04-ZG BasesReplacement Wireless Remote Compatible with BedTech, Bob’s, or Moto Sleep (Motto Sleep) CH04-ZG Bases
SKU 10083
$199.00
Adjustamagic, Interflex Wired 2 Button, or Leggett 1st Series, Bronze, Silver, or Gold 10 Foot Cord Replacement OnlyAdjustamagic, Interflex Wired 2 Button, or Leggett 1st Series, Bronze, Silver, or Gold 10 Foot Cord Replacement Only
SKU 10055
$55.00
Reverie OSO O400 ERC144A01 Wireless Remote
SKU 00089
was $149.00
Save 9%
$135.00
Reverie 2E/3E Head Only 2 or 3 Button Corded RemoteReverie 2E/3E Head Only 2 or 3 Button Corded Remote
SKU 00281
was $139.00
Save 14%
$119.00
Reverie RC-WM-E02 (New Version) Replacement Remote
SKU 00273
was $140.00
Save 15%
$119.00
Replacement Remote Compatible with Sleep Number Flex Fit (flexfit) BASIC ONE VIBE Non-LCD Version (see Pics)
SKU 00152
$299.00
Replacement Remote Compatible with Interflex Silver or Old Gen Specific Simmons Corded Bases (Must Look The Same- includes Cord)
SKU 10040
$399.00
Interflex Bronze Lifestyle Corded Remote (includes Cord)
SKU 00011
$349.00
Serta Motion Signature (New Version -Lift/Massage) RC-WM-E01 Replacement Remote
SKU 00038
was $140.00
Save 29%
$99.00
Leggett & Platt 100 Series II or Newer Gen 7 Button T-120 Adjustable Bed Replacement Remote for T120 Bases- New Gen Black w/Replaceable Batteries - Black or Silver VersionLeggett & Platt 100 Series II or Newer Gen 7 Button T-120 Adjustable Bed Replacement Remote for T120 Bases- New Gen Black w/Replaceable Batteries - Black or Silver Version
SKU 00035
was $149.00
Save 36%
$95.00
Okin Massage Control Box Replaces Keeson Kesson Control Box Model Number MC121 MC122 (mc121bs, Mc122sc)
SKU 00290
$199.00
Lifestyles S-cape E95 (New Scape Black Version) Value RemoteLifestyles S-cape E95 (New Scape Black Version) Value Remote
SKU 00020
$249.00
Replacement 2 Piece Conversion Kit Compatible w Simmons Nuflex or Softide 5100/8100 (no Lumbar Support) 6 Pin - New Grey Version Remote- Replaces Lost or Broken RemoteReplacement 2 Piece Conversion Kit Compatible w Simmons Nuflex or Softide 5100/8100 (no Lumbar Support) 6 Pin - New Grey Version Remote- Replaces Lost or Broken Remote
SKU 00080
was $329.00
Save 24%
$249.00
Replacement Remote Compatible with Ashley 2 Button Sierra Sleep M8X (M8x132 or M8x142) Moto Sleep HHC HSW302
SKU 00163
$149.00
Reverie or Purple Powerbase 8Q Or 8X RC-WM-e53 Replacement Remote
SKU 00079
was $149.00
Save 9%
$135.00
Replacement Wireless Remote Compatible with BedTech or Motosleep Moto CH10 ZG Bases
SKU 00237
$229.00
Out of stock
Ergomotion and Certain Kingsdown V400 4 Pin (NOT 6) Remote Replacement
SKU 00107
$346.95
