Conversion Kit- 2 Boxes and One Synced Remote (Premium Model) Compatible with Rize/Deltadrive/Plus/Privia/Craftmatic/Ruoey Lung -Used for a lost remote. Backlit Controls Movement/Massage - No Presets
$449.00
was $579.00 Save 22%
In stock: 3 available
This universal kit converts Mantua Rize Craftmatic or Reverie by Ruoey Lung bed base control boxes and includes a new wireless remote to control your bed base with advanced features like backlit lighting, a flashlight, and massage with three intensities and wave modes. Used to replace a lost or broken remote when there are no more replacements available or in budget or to upgrade a basic remote with only a few buttons. This is a double control box kit with one remote paired to each unit (designed for split king beds where a couple wants both sides to move together)
This kit includes all the wiring and ports needed to make your conversion. Simply unplug your four motors from the existing control box under your bed and plug them into our new unit. All of the remotes showed above used control boxes with five pin connection ports. As long as your box has massage and head and foot motors with five pins in the plugs then this will work. (See above picture)
Total installation should take no more than 5 minutes but it does require tipping the bed on its side or sliding under the bed to secure the new unit once plugged in.Kit Includes:
1) Conversion Control Box with Wire Harnesses and a Power Supply Cable/Transformer Box - Simply plug in the old cords into our new box
1) Wireless 17 Button Remote Control with flashlight and backlighting- Simply plug in the kit after it’s installed and the remote will work. Each remote uses three AAA batteries (included since we program this prior to shipping.). You can only have one remote paired with one box at a time or if you reach out to us we can pair one remote to two boxes if you want to synchronize your king split base. If you want to buy a 2nd remote to use as a backup, we sell them for $70 each.
We also offer this remote and control box without the massage buttons and hookups (if you didn’t want the extra buttons which won’t work to be on the remote even though it doesn’t hurt anything) or with massage but a universal wiring harness (if you don’t mind taking a few more minutes and cutting and stripping your massage and motor wires under your bed) for $50 less
Here:
https://www.adjustablebedremotes.com/#!/Conversion-Kit-Non-Massage-Deluxe-Model-for-Reverie-Rize-Privia-Reflexion-R4-R7-Or-Craftmatic-4-Pin-Bases-See-Pic-Used-for-a-lost-broken-remote-9-Button-Backlit-Controls-Movement-Presets/p/471875579
Or Here:
https://www.adjustablebedremotes.com/#!/13-Button-Remote-Universal-Conversion-Kit-for-Old-Adjustable-Beds-Most-newer-Beds-motors-must-be-24v-29V-Used-for-a-lost-broken-discon-remote-Head-Up-Down-&-Foot-Up-Down-3-Presets-&-Wave-Massage/p/471655154/category=0
If you need to have your presets functioning... we feature this kit here for $20 more.
Remote Conversion Kit (Premium Model) for Sealy R4 R7, Rize or Privia Craftmatic Manuta by Ruoey Lung -Used for a lost/broken remote. 13 Button Backlit Controls Movement/Massage/Presets (adjustablebedremotes.com)
Richmat HJH55 (New Version- See Description) Compatible with Mattress 600 or 3000 Silver or Black, Enso, Classic Brands Innova NU203CB, PostureCloud- Works with Certain HJC18  Boxes - Mf3000
SKU 00256
was $159.00
Save 21%
$125.00
E95 Scape (S-cape) -Only Compatible with Certain Old Gen Craftmatic, and Certain Okimat or Hb310 Leggett Or Sealy Remotes
SKU 00100
$749.00
Reverie Oasis ERC117 Wireless Remote (New 4M Multi Button Version)
SKU 00092
was $149.00
Save 13%
$129.00
Replacement Remote Compatible with Sealy Premier X-10 (x10) E97 Dual Vibe Remote
SKU 00125
$549.00
Remote Compatible with Rize Beds- Discontinued -Contemporary/Relaxer Remote TRUN2-FM Replacement- See Our Conversion Kit
SKU 00261
$299.00
Out of stock
Reverie 3E Tech RC-WM-114 Or R350LP ERC114W00 Wireless Remote- Also We Have a Used Showroom Model Avail For $75
SKU 00029
was $129.00
Save 8%
$119.00
Serta Motion Perfect, Essentials (Not 2nd Gen), Custom, Plus, Air, New Gen Ergomotion, Ease/Tempur, Matt Firm 50/okin 300/600 & Richmat/Reverie 29v Power Box/Plug (Doesn’t inc. input cord)
SKU 00132
was $99.00
Save 30%
$69.00
Ergomotion Pure Contour Gold Remote
SKU 00167
$159.00
Replacement Remote Compatible with Sealy BASIC ONE VIBE E97 Old Generation Single Vibe (see Pics and Massage Info Below)
SKU 00124
$299.00
Replacement Remote Compatible with Ashley Sierra Sleep M9X4 (x4) Bases
SKU 00059
$179.00
Replacement Wireless Remote Compatible with BedTech or Motosleep Moto CH10 ZG Bases
SKU 00237
$229.00
Out of stock
Leggett And Platt Softline Pro-Motion, Swingline, Sleep Number Flex Fit Wired, Series III, or 1st Gen Brio (new Black And White Version- Top Right Pic)
SKU 00073
was $129.00
Save 8%
$119.00
Power Cord Box Compatible with Serta Motion Essentials 2, Motion Slim, Leggett And Platt 100 Series II, S-cape, 500, 700 Series, and Beautyrest Simple Motion or Renew Old Gen L-132 OW Linak
SKU 10111
was $109.00
Save 28%
$79.00
Replacement Compatible with Certain iDealbeds (ideal) 4i/c, Certain Craftmatic Legacy, or Leggett & Platt Style Plus, Williamsburg, Frankfurt K-132  18 Button Remote- Make Sure Your Buttons Match
SKU 00102
was $149.00
Save 20%
$119.00
Adjusta-Magic E90 (e-90) Corded Remote (New Version With A Few Extra Buttons)
SKU 00049
$299.00
Richmat 7 Button HJH13D Wireless Remote Compatible with FlexEzz, Enso, Metro Mattress, Bedtech, and X5 iLift by Richmat
SKU 00252
was $159.00
Save 28%
$115.00
3 Pc Conversion Kit Replacement Remote Set Compatible with Coaster, Serta, or Ergomotion (4 Pin -New Black Version- 8 Pin Motor Cord For Head (Plus & Play) and Lever Nut for Foot and Massage
SKU 10062
was $329.00
Save 30%
$229.00
Leggett & Platt Sunrise Remote
SKU 00077
$159.00
Conversion Kit 2 Piece for the Disc. Leggett & Platt S-Cape (scape) 1.0, 1.0+, 500, 700 or Simplicity 2.0 Remote - See Pictures. Inc. New Control Box, & Grey Remote w/Massage/Presets (No Pillow Tilt)
SKU 00031
was $299.00
Save 17%
$249.00
Serta Motion Current Gen (Motion Perfect 2/3/4, Motion Essentials 3/4/5, iSeries, Air, Motion Plus, Motion Custom 2/3) Power Cord 3 Piece Set w Input Cord
SKU 00047
was $109.00
Save 27%
$80.00
Okin Control Box CU358 with Input Section
SKU 00289
was $199.00
Save 10%
$179.00
Leggett & Platt Simplicity HF Remote- Physical Button OEM Version Also Avail For $119- Ask For Info
SKU 10107
was $189.00
Save 11%
$169.00
Serta Motion Perfect 1.0, Motion Essentials 1.0 and Nuflex Older Gen or New Gen Reverie ECB2208C1 3 Piece Power Cord Set
SKU 00104
was $119.00
Save 17%
$99.00
Reverie 2E/3E Head Only 2 or 3 Button Corded Remote
SKU 00281
was $139.00
Save 14%
$119.00
Replacement Remote Compatible with Certain Model Craftmatic Legacy (l132 L-132 Series) Linak Bed Remotes- See Our Universal Conversion Kits
SKU 00043
$549.00
Headboard Kit Compatible with
Mattress Firm 50 and 0776 series Leggett and Platt (Not Enso) All Sizes Headboard Brackets Set
Headboard Kit Compatible with Mattress Firm 50 and 0776 series Leggett and Platt (Not Enso) All Sizes Headboard Brackets Set
SKU 00134
$219.00
Replacement Remote Compatible with Living Comfort, Euro Sleep, and WRLS 2 VIBE Adjustable Bed Remote Replacement
SKU 00305
$749.00
Replacement Remote Compatible with Select Comfort/Sleep Number Flex Fit (flexfit) Precision/Precision+ (New Black Version)
SKU 00088
$749.00
Replacement 2 Piece Conversion Kit Compatible w Simmons Nuflex or Softide 5100/8100 (no Lumbar Support) 6 Pin - New Grey Version Remote- Replaces Lost or Broken Remote
SKU 00080
was $329.00
Save 24%
$249.00
Replacement Wireless Remote Compatible with BedTech BT3000 and Bt3000LP and Certain Richmat Easy Rest Revive Living Spaces White Wireless Remote (Bed Tech 3000)
SKU 00249
was $159.00
Save 25%
$119.00
Leggett and Platt Replacement Remote Compatible with Old Blue Craftmatic, or Sealy Swingline Blue Wired Remote (Swing Line) - New Black Version
SKU 00129
was $149.00
Save 20%
$119.00
Ergomotion E4 Series WIRED 2 Piece Conversion Kit- See Pics- New Wireless White Remote & Control Box
SKU 00115
was $299.00
Save 10%
$269.00
Replacement Power Cord Compatible with  Beautyrest Luxury, Advance, or Smartmotion (Smart Motion) 1.0/2.0/3.0 Beds- 3 Piece Set Inc Input Cord
SKU 00048
was $109.00
Save 27%
$80.00
Replacement Remote Compatible with Leggett and Platt Basis C3 or Sleep Comfort (New 3 Preset Version) Scape
SKU 00087
$549.00
Reverie 5i, 5D, 7S, R400 or 450, or 4M Replacement Remote
SKU 00028
was $139.00
Save 14%
$119.00
Leggett & Platt Brio 40 Series Remote
SKU 00158
$169.00
Ergomotion Softide 5100/8100 Remote- Discontinued… See Our New Conversion Kit
SKU 00091
was $299.00
Save 10%
$269.00
Out of stock
Replacement Remote Compatible with Idealbeds 5i/custom Wireless Remote (New Name brand Replacement Remote With All The Same Features- ideal)
SKU 00277
was $149.00
Save 20%
$119.00
Replacement Remote Compatible with InKline White Noise 5 Button or Black 6 Button Bases
SKU 10095
$149.00
Replacement Remote Compatible with Beautyrest Smartmotion 1.0 (New Value Extend Grey Multi Button Remote - See 2nd Picture For The Remote You’ll Get) Smart Motion
SKU 10089
was $149.00
Save 20%
$119.00
SKU 00055
was $139.00
Save 14%
$119.00
Ergomotion and Certain Kingsdown V400 4 Pin (NOT 6) Remote Replacement
SKU 00107
$299.00
Serta Motion Slim or Leggett 100 Series (New Black or Silver Version w/Light Original MFG) Replacement Remote
SKU 00008
was $179.00
Save 28%
$129.00
Leggett & Platt Scape HF Massage And Certain Model MF 900 Remote- Physical Button OEM Version (original Glass Front Version Discontinued)
SKU 10088
was $149.00
Save 20%
$119.00
Okin Massage/Lumbar/Bluetooth/USB Control Box
SKU 10090
was $359.00
Save 17%
$299.00
Ergomotion Pure Contour Silver, Gold, or Elite or certain model OKIN Enso Value Remote
SKU 00117
was $149.00
Save 20%
$119.00
Replacement Remote Compatible with Mattress Firm 600 MF600 Pillow Tilt Remote (Make Sure You’re Getting The Correct One). Value Option Available For $260 Less.
SKU 00162
$499.00
Okimat 2 Okin Remote Compatible with New Gen Craftmatic/Comfort Base Remote, 258A Model Electropedic, or Saatva Lineal Bases- Must Match Back Of Old Remote Exactly w Oval Button above AAAs
SKU 00209
$339.00
Serta Motion Essentials 6th Gen Wireless Remote
SKU 00004
$149.00
Lifestyles S-cape E95 (New Scape Black Version) Remote
SKU 00020
$749.00
