Conversion Kit- 2 Boxes and One Synced Remote (Premium Model) Compatible with Rize/Deltadrive/Plus/Privia/Craftmatic/Ruoey Lung -Used for a lost remote. Backlit Controls Movement/Massage - No Presets
$449.00
was $579.00 Save 22%
In stock: 3 available
This universal kit converts Mantua Rize Craftmatic or Reverie by Ruoey Lung bed base control boxes and includes a new wireless remote to control your bed base with advanced features like backlit lighting, a flashlight, and massage with three intensities and wave modes. Used to replace a lost or broken remote when there are no more replacements available or in budget or to upgrade a basic remote with only a few buttons. This is a double control box kit with one remote paired to each unit (designed for split king beds where a couple wants both sides to move together)
This kit includes all the wiring and ports needed to make your conversion. Simply unplug your four motors from the existing control box under your bed and plug them into our new unit. All of the remotes showed above used control boxes with five pin connection ports. As long as your box has massage and head and foot motors with five pins in the plugs then this will work. (See above picture)
Total installation should take no more than 5 minutes but it does require tipping the bed on its side or sliding under the bed to secure the new unit once plugged in.Kit Includes:
1) Conversion Control Box with Wire Harnesses and a Power Supply Cable/Transformer Box - Simply plug in the old cords into our new box
1) Wireless 17 Button Remote Control with flashlight and backlighting- Simply plug in the kit after it’s installed and the remote will work. Each remote uses three AAA batteries (included since we program this prior to shipping.). You can only have one remote paired with one box at a time or if you reach out to us we can pair one remote to two boxes if you want to synchronize your king split base. If you want to buy a 2nd remote to use as a backup, we sell them for $70 each.
We also offer this remote and control box without the massage buttons and hookups (if you didn’t want the extra buttons which won’t work to be on the remote even though it doesn’t hurt anything) or with massage but a universal wiring harness (if you don’t mind taking a few more minutes and cutting and stripping your massage and motor wires under your bed) for $50 less
Here:
https://www.adjustablebedremotes.com/#!/Conversion-Kit-Non-Massage-Deluxe-Model-for-Reverie-Rize-Privia-Reflexion-R4-R7-Or-Craftmatic-4-Pin-Bases-See-Pic-Used-for-a-lost-broken-remote-9-Button-Backlit-Controls-Movement-Presets/p/471875579
Or Here:
https://www.adjustablebedremotes.com/#!/13-Button-Remote-Universal-Conversion-Kit-for-Old-Adjustable-Beds-Most-newer-Beds-motors-must-be-24v-29V-Used-for-a-lost-broken-discon-remote-Head-Up-Down-&-Foot-Up-Down-3-Presets-&-Wave-Massage/p/471655154/category=0
If you need to have your presets functioning... we feature this kit here for $20 more.
Remote Conversion Kit (Premium Model) for Sealy R4 R7, Rize or Privia Craftmatic Manuta by Ruoey Lung -Used for a lost/broken remote. 13 Button Backlit Controls Movement/Massage/Presets (adjustablebedremotes.com)
Linak Authentic OEM Power Cord Set Compatible with Serta Motion Essentials 2, Motion Slim, Leggett & Platt 100 Series II, S-cape, Renew Basic And Plus Series, & Beautyrest Simple Motion BasesLinak Authentic OEM Power Cord Set Compatible with Serta Motion Essentials 2, Motion Slim, Leggett & Platt 100 Series II, S-cape, Renew Basic And Plus Series, & Beautyrest Simple Motion Bases
SKU 00053
was $169.00
Save 47%
$89.00
Replacement Wireless Remote Compatible with  Beautyrest Advance Motion Bases- Value Remote w More Functionality Available For $40 Less
SKU 00144
was $179.00
Save 11%
$159.00
Remote Replacement Compatible with S-Cape E95 (E-95), Adjusta-Sleep, Certain Old Gen Craftmatic, WRLS 2 VIB, and Certain Contour Premier, Sleep Comfort, Eurosleep, Simmons Series 2000, or Craft 1Remote Replacement Compatible with S-Cape E95 (E-95), Adjusta-Sleep, Certain Old Gen Craftmatic, WRLS 2 VIB, and Certain Contour Premier, Sleep Comfort, Eurosleep, Simmons Series 2000, or Craft 1
SKU 00018
$349.00
Leggett & Platt Signature, Simplicity 2.0, or certain 100 Or 300 Brio Series Remote- Disc. Model, See PicsLeggett & Platt Signature, Simplicity 2.0, or certain 100 Or 300 Brio Series Remote- Disc. Model, See Pics
SKU 00034
$179.00
Replacement Wireless Remote Compatible with BedTech BT3000 and Bt3000LP and Certain Richmat Flexeez Easy Rest Revive Living Spaces White Wireless Remote (Bed Tech 3000)Replacement Wireless Remote Compatible with BedTech BT3000 and Bt3000LP and Certain Richmat Flexeez Easy Rest Revive Living Spaces White Wireless Remote (Bed Tech 3000)
SKU 00249
was $159.00
Save 25%
$119.00
Replacement White Wireless Remote Compatible with BedTech BT2500 Or Genesis (Bed Tech 2500) BasesReplacement White Wireless Remote Compatible with BedTech BT2500 Or Genesis (Bed Tech 2500) Bases
SKU 00251
was $159.00
Save 21%
$125.00
Replacement Remote Compatible with Living Comfort, Euro Sleep, and WRLS 2 VIBE Adjustable Bed Remote ReplacementReplacement Remote Compatible with Living Comfort, Euro Sleep, and WRLS 2 VIBE Adjustable Bed Remote Replacement
SKU 00305
$349.00
Ergomotion Pure Contour Gold Remote
SKU 00167
$159.00
Leggett & Platt S-Cape (scape) 2.0 Zero Clearance Version (Not Old Gen 1.0 or 2.0 Black Remote- See Other Listing) w Flashlight Button
SKU 10079
was $299.00
Save 20%
$239.00
Replacement Remote Compatible with Beautyrest Smartmotion 1.0 (New Value Grey Remote - See 2nd Picture For the Remote You’ll Get) Smart MotionReplacement Remote Compatible with Beautyrest Smartmotion 1.0 (New Value Grey Remote - See 2nd Picture For the Remote You’ll Get) Smart Motion
SKU 10089
was $149.00
Save 20%
$119.00
Reverie 3E Mesh RC-WM-113 (replaces -117) Wireless Remote 3EM- Used Showroom Model w/o Battery Cover Option Avail For $75Reverie 3E Mesh RC-WM-113 (replaces -117) Wireless Remote 3EM- Used Showroom Model w/o Battery Cover Option Avail For $75
SKU 00027
was $129.00
Save 23%
$99.00
Leggett & Platt Premier Series Remote
SKU 00216
$249.00
Serta Motion Essentials 6th Gen Wireless Remote
SKU 00004
$149.00
Replacement Remote Compatible with Sleep Number Or Select Comfort Flex Fit And Flex Fit+ Plus (flexfit) DUAL VIBE Non-LCD Version (see Pics)
SKU 00154
was $249.00
Save 4%
$239.00
Serta Motion Essentials and Ergo Black 1st Gen 1.0 (New 2 Pc Conversion Kit Version) Remote ReplacementSerta Motion Essentials and Ergo Black 1st Gen 1.0 (New 2 Pc Conversion Kit Version) Remote Replacement
SKU 00001
was $299.00
Save 40%
$179.00
Replacement Remote Compatible with Sealy Reflections (Reflexion) 4 R4 Remote TRURC-N5 Replacement Remote- Discontinued, See Our New Universal Conversion Kit
SKU 10109
$319.00
Out of stock
Leggett & Platt 100 Series II or Newer Gen 7 Button T-120 Adjustable Bed Replacement Remote for T120 Bases- New Gen Black w/Replaceable Batteries - Black or Silver VersionLeggett & Platt 100 Series II or Newer Gen 7 Button T-120 Adjustable Bed Replacement Remote for T120 Bases- New Gen Black w/Replaceable Batteries - Black or Silver Version
SKU 00035
was $149.00
Save 36%
$95.00
Replacement Remote Compatible with Sealy Ease 1.0 2.0 3.0 or 4.0 - New 6 Button Serta VersionReplacement Remote Compatible with Sealy Ease 1.0 2.0 3.0 or 4.0 - New 6 Button Serta Version
SKU 00248
was $169.00
Save 47%
$89.00
Serta Motion Perfect 1.0, Motion Essentials 1.0 and Nuflex Older Gen or New Gen Reverie ECB2208C1 3 Piece Power Cord SetSerta Motion Perfect 1.0, Motion Essentials 1.0 and Nuflex Older Gen or New Gen Reverie ECB2208C1 3 Piece Power Cord Set
SKU 00104
was $119.00
Save 17%
$99.00
Replacement Remote Compatible with MR2 Scape for Ergo Raven Bases by Tempurpedic GSMR2
SKU 00023
$249.00
Leggett & Platt Brio 40 Series Remote
SKU 00158
$169.00
Reverie OSO O200 ERC014A01 Wired Remote
SKU 00220
was $149.00
Save 27%
$109.00
Replacement Remote Compatible with Sleep Number Flex Fit or Select Comfort Shipshape Swingline Corded Bases NEW White OEM VersionReplacement Remote Compatible with Sleep Number Flex Fit or Select Comfort Shipshape Swingline Corded Bases NEW White OEM Version
SKU 00156
$299.00
Conversion Kit Compatible with Homelegance or Hofish Adjustable Base Remote Conversion Kit Compatible with Homelegance or Hofish Adjustable Base Remote
SKU 00142
was $209.00
Save 5%
$199.00
Replacement White Wireless Remote Compatible with  BedTech BT4000 (Bed Tech) Bases- Use The 3000 If You Don’t Need Pillow TiltReplacement White Wireless Remote Compatible with  BedTech BT4000 (Bed Tech) Bases- Use The 3000 If You Don’t Need Pillow Tilt
SKU 00250
was $159.00
Save 9%
$145.00
Ergomotion Softide 2100 WIRELESS Remote - NEW 2 Pc Conversion kit - See attachedErgomotion Softide 2100 WIRELESS Remote - NEW 2 Pc Conversion kit - See attached
SKU 00113
was $299.00
Save 27%
$219.00
Replacement Remote Compatible with Idealbeds 5i/custom Wireless Remote (New Name brand Replacement Remote With All The Same Features- ideal)Replacement Remote Compatible with Idealbeds 5i/custom Wireless Remote (New Name brand Replacement Remote With All The Same Features- ideal)
SKU 00277
was $149.00
Save 20%
$119.00
Adjusta-Magic E91 (e-91) Or Certain Craftmatic Classic Corded Remotes Replacement (see 2nd Picture)Adjusta-Magic E91 (e-91) Or Certain Craftmatic Classic Corded Remotes Replacement (see 2nd Picture)
SKU 00050
$299.00
Reverie 7t or R400/450 And R550 (non-Pillow Tilt) RC-WM-111 Wireless LED Remote- CHECK PROCESSOR BOX BEFORE ORDERINGReverie 7t or R400/450 And R550 (non-Pillow Tilt) RC-WM-111 Wireless LED Remote- CHECK PROCESSOR BOX BEFORE ORDERING
SKU 00067
$299.00
Serta Perfect Position II New 3 Preset Version Remote
SKU 00021
was $279.00
Save 11%
$249.00
Serta Motion Select (Light Gray Version) Remote
SKU 00039
was $139.00
Save 29%
$99.00
Ergomotion E4+ WIRELESS Remote- New Grey VersionErgomotion E4+ WIRELESS Remote- New Grey Version
SKU 00218
was $149.00
Save 20%
$119.00
Conversion Kit 2 Piece for the Disc. Leggett & Platt S-Cape (scape) 1.0, 1.0+, 500, 700 or Simplicity 2.0 Remote - See Pictures. Inc. New Control Box, & Grey Remote w/Massage/Presets (No Pillow Tilt) Conversion Kit 2 Piece for the Disc. Leggett & Platt S-Cape (scape) 1.0, 1.0+, 500, 700 or Simplicity 2.0 Remote - See Pictures. Inc. New Control Box, & Grey Remote w/Massage/Presets (No Pillow Tilt)
SKU 00031
was $299.00
Save 17%
$249.00
Reverie OSO O300 ERC239A01 (erc239) 433 MHz Oso300 Wireless Remote
SKU 00166
was $149.00
Save 7%
$139.00
Adjustamagic Leggett E-90, E-91, or E-92, - New Gen Cord Replacement (e91, e92, e90)Adjustamagic Leggett E-90, E-91, or E-92, - New Gen Cord Replacement (e91, e92, e90)
SKU 10099
$55.00
Serta Motion Perfect IV (4 4th Gen) Remote
SKU 00017
was $169.00
Save 30%
$119.00
Replacement Compatible with Certain iDealbeds (ideal) 4i/c, Certain Craftmatic Legacy, or Leggett & Platt Style Plus, Williamsburg, Frankfurt K-132  18 Button Remote- Make Sure Your Buttons Match Replacement Compatible with Certain iDealbeds (ideal) 4i/c, Certain Craftmatic Legacy, or Leggett & Platt Style Plus, Williamsburg, Frankfurt K-132  18 Button Remote- Make Sure Your Buttons Match
SKU 00102
was $149.00
Save 20%
$119.00
Replacement Wireless Remote Compatible with  Beautyrest Smartmotion 2.0 or 3.0 Beds (Smart Motion) Grey Remote Shown Right
SKU 00066
was $149.00
Save 20%
$119.00
Power Cord Compatible with Certain Model Leggett 50 Series, and Matt Firm 300/600 3 Piece Set
SKU 00181
was $109.00
Save 9%
$99.00
Conversion Kit Compatible with Boyd Specialty Sleep Adjusta Flex 5 Button Corded Remote (new 3 Pc Conversion Kit Version, See Pics)Conversion Kit Compatible with Boyd Specialty Sleep Adjusta Flex 5 Button Corded Remote (new 3 Pc Conversion Kit Version, See Pics)
SKU 10061
was $199.00
Save 10%
$179.00
Replacement Remote Compatible with Rize Privia/Contemporary II/Avante Remote TRURC-N5 Compatible with New R4 Sealy - Discontinued, See Our New Universal Conversion Kit Replacement Remote Compatible with Rize Privia/Contemporary II/Avante Remote TRURC-N5 Compatible with New R4 Sealy - Discontinued, See Our New Universal Conversion Kit
SKU 00279
$299.00
Out of stock
E95 Scape (S-cape) -Only Compatible with Certain Old Gen Craftmatic, and Certain Okimat or Hb310 Leggett Or Sealy Remotes
SKU 00100
was $299.00
Save 17%
$249.00
MLily Or Idle Sleep NL200/nl200u Remote Control -Works With HJC18 Control Boxes
SKU 10054
was $159.00
Save 25%
$119.00
Leggett & Platt Simplicity HF Remote- Physical Button OEM Version Also Avail For $119- Ask For Info
SKU 10107
was $189.00
Save 11%
$169.00
Replacement Remote Compatible with InKline White Noise 5 Button or Black 6 Button BasesReplacement Remote Compatible with InKline White Noise 5 Button or Black 6 Button Bases
SKU 10095
$149.00
Replacement Remote Compatible with Mattress Firm En300 MF300 Series Richmat 8 Button White Version See Pics (Not Black and White Leggett Stand Up or Leggett 7 Button Top Line) Works With ML190 /NL200Replacement Remote Compatible with Mattress Firm En300 MF300 Series Richmat 8 Button White Version See Pics (Not Black and White Leggett Stand Up or Leggett 7 Button Top Line) Works With ML190 /NL200
SKU 00278
was $159.00
Save 25%
$119.00
Replacement Remote Compatible with Leggett and Platt Basis C3 or Sleep Comfort (New 3 Preset Version) Scape
SKU 00087
$349.00
Replacement Remote Compatible with Mattress Firm 300 Series Topline 7 Button Phoenix Mecano Leggett Brand (Not Richmat 8 Button or Black/White Standup) Remote
SKU 00141
$229.00
Serta Perfect Position II BASIC ONE VIBE Old Generation E02 -K1, E91SS, New 2020 Raven Version (see Pics)Serta Perfect Position II BASIC ONE VIBE Old Generation E02 -K1, E91SS, New 2020 Raven Version (see Pics)
SKU 00146
$299.00
Learn Cord For Certain Linak Bases
SKU 00275
$99.00
