Remote Conversion Kit (Premium Model) Compatible with Sealy R4 Stearns Foster R7, Rize, Boyd, Privia Craftmatic Mantua by Ruoey Lung -Used for a lost/broken remote. 13 Button Movement/Massage/Preset
$349.00
was $359.00 Save 3%
In stock: 20 available
This universal kit converts Mantua Rize Craftmatic, Boyd, or Reverie by Ruoey Lung bed base control boxes and includes a new wireless remote to control your bed base with advanced features like presets, one touch flat, and massage with three intensities and wave modes. Used to replace a lost or broken remote when there are no more replacements available or in budget or to upgrade a basic remote with only a few buttons.
This kit includes all the wiring and ports needed to make your conversion. Simply unplug your four motors from the existing control box under your bed and plug them into our new unit. All of the remotes showed above used control boxes with four pin connection ports. As long as your box has massage and head and foot motors with five pins in the plugs then this will work. (See above picture)
Total installation should take no more than 5 minutes but it does require tipping the bed on its side or sliding under the bed to secure the new unit once plugged in.Kit Includes:
1) Conversion Control Box with Wire Harnesses and a Power Supply Cable/Transformer Box - Simply plug in the old cords into our new box
1) Wireless 13 Button Remote Control with flashlight and backlighting- Simply plug in the kit after it’s installed and the remote will work. Each remote uses three AAA batteries (included since we program this prior to shipping.). You can only have one remote paired with one box at a time or if you reach out to us we can pair one remote to two boxes if you want to synchronize your king split base. If you want to buy a 2nd remote to use as a backup, we sell them for $70 each.
We also offer this remote and control box without the massage buttons and hookups (if you didn’t want the extra buttons which won’t work to be on the remote even though it doesn’t hurt anything) or with massage but a universal wiring harness (if you don’t mind taking a few more minutes and cutting and stripping your massage and motor wires under your bed) for $50 less
Here:
https://www.adjustablebedremotes.com/#!/Conversion-Kit-Non-Massage-Deluxe-Model-for-Reverie-Rize-Privia-Reflexion-R4-R7-Or-Craftmatic-4-Pin-Bases-See-Pic-Used-for-a-lost-broken-remote-9-Button-Backlit-Controls-Movement-Presets/p/471875579
Or Here:
https://www.adjustablebedremotes.com/#!/13-Button-Remote-Universal-Conversion-Kit-for-Old-Adjustable-Beds-Most-newer-Beds-motors-must-be-24v-29V-Used-for-a-lost-broken-discon-remote-Head-Up-Down-&-Foot-Up-Down-3-Presets-&-Wave-Massage/p/471655154/category=0
Replacement Remote Compatible with Select Comfort/Sleep Number Flex Fit (flexfit) Precision/Precision+ (New Black Version)
SKU 00088
$549.00
Reverie 3E Tech RC-WM-E57 Wireless (New Grey Version) Remote
SKU 00030
was $129.00
Save 8%
$119.00
Leggett & Platt Prodigy 1.0 Remote Conversion Kit w Massage Functionality (No Presets or Limits- The Old Remote Is Discontinued) Also Talk to Us About Kits w/o Massage For Less
SKU 00083
was $279.00
Save 11%
$249.00
Replacement Remote Compatible with Living Comfort, Euro Sleep, and WRLS 2 VIBE Adjustable Bed Remote Replacement
SKU 00305
$549.00
Ergomotion Softide 8100 Or 8300 Remote- Discontinued- See Our New Conversion Kit
SKU 00111
$249.00
Out of stock
Replacement Wireless Remote Compatible with  Beautyrest Simple Motion Beds (New Black With Light button Non Logo Version)
SKU 00276
was $135.00
Save 12%
$119.00
Mlily Adjustables M200 TwXL (Buy 2 to make a Split King) Size 750lb Capacity Adjustable Bed w/Free Shipping
SKU 00173
was $799.00
Save 44%
$449.00
Richmat HJH55 (New Version- see pics) Remote Compatible with Classic Brands As Seen On Wayfair or Nectar- Works With Certain HJC18 Massage Control Boxes as Shown
SKU 10096
was $159.00
Save 9%
$145.00
Lifestyles S-cape E95 (New Scape Black Version) Remote
SKU 00020
$549.00
SKU 00055
was $139.00
Save 14%
$119.00
Old Gen Nuflex and Serta Motion Perfect Massage Combination Splitter Single Cord (You Need 2 Sets If Pairing/Splitting Four Massage Units Down To 2)
SKU 10080
$20.00
Replacement Wireless Remote Compatible with Serta or Beautyrest Motion Air (New Black Version) Bases
SKU 10057
$159.00
Leggett & Platt Signature, Simplicity 2.0, or certain 100 Or 300 Brio Series Remote- Disc. Model, See Pics
SKU 00034
$179.00
Conversion Kit Compatible with Boyd Specialty Sleep Adjusta Flex 5 Button Corded Remote (new 3 Pc Conversion Kit Version, See Pics)
SKU 10061
was $199.00
Save 10%
$179.00
Leggett And Platt D-Series (D Series) Converter Kit w/Plug, New Motors, and Adapters #4b8900
SKU 00143
$399.00
Leggett & Platt Falcon 2.0+ Remote
SKU 00076
was $179.00
Save 11%
$159.00
Leggett and Platt Old Gen Raven (New 3 Preset Version) MR2T8TVZG-PM Or Series V/ V Elite E95 Scape Remote- Mr2t
SKU 00105
$549.00
Conversion Kit 3 Pc With New Model Remote- Simply unplug your motors and plug them In- MASSAGE VERSION Compatible w Ashley Sierra Sleep HHC Moto (Motto) Sleep CH11, M9X6, M9X8, And M9X9
SKU 00060
was $299.00
Save 33%
$199.00
Adjusta-Magic E91 (e-91) Or Certain Craftmatic Classic Corded Remotes Replacement (see 2nd Picture)
SKU 00050
$239.00
Interflex Bronze Lifestyle Corded Remote (includes Cord)
SKU 00011
$289.00
Serta Motion Signature (New Version -Lift/Massage) RC-WM-E01 Replacement Remote
SKU 00038
was $140.00
Save 15%
$119.00
Replacement Remote Compatible with InKline White Noise 5 Button or Black 6 Button Bases
SKU 10095
$149.00
Serta Motion Current Gen (Motion Perfect 2/3/4, Motion Essentials 3/4/5, iSeries, Air, Motion Plus, Motion Custom 2/3) Power Cord 3 Piece Set w Input Cord
SKU 00047
was $109.00
Save 27%
$80.00
Ergomotion Softide 5100/8100 Remote- Discontinued… See Our New Conversion Kit
SKU 00091
was $299.00
Save 10%
$269.00
Out of stock
Replacement Remote Compatible with Mattress Firm 300 Series Topline 7 Button Phoenix Mecano Leggett Brand (Not Richmat 8 Button or Black/White Standup) Remote
SKU 00141
$229.00
Ergomotion E4+ WIRELESS Remote- New Grey Version
SKU 00218
was $149.00
Save 20%
$119.00
Leggett & Platt Raven K-120 White Remote
SKU 00036
was $149.00
Save 20%
$119.00
Remote Replacement Compatible with S-Cape E95 (E-95), Adjusta-Sleep, Certain Old Gen Craftmatic, WRLS 2 VIB, and Certain Contour Premier, Sleep Comfort, Eurosleep, Simmons Series 2000, or Craft 1
SKU 00018
$549.00
Ergomotion/Blissful Nights/InKline/Essence/Motion Air 5 or 6 Button Wireless Remote (Value Grey Remote Available For $135)
SKU 00272
$149.00
Serta Perfect Position III New 3 Preset Version Remote
SKU 00040
$349.00
Replacement White Wireless Remote Compatible with BedTech BT2500 Or Genesis (Bed Tech 2500) Bases
SKU 00251
was $159.00
Save 21%
$125.00
Replacement Remote Compatible with Sealy Reflections (Reflexion) 4 R4 Remote TRURC-N5 Replacement Remote- Discontinued, See Our New Universal Conversion Kit
SKU 10109
$319.00
Out of stock
Replacement Wireless Remote Compatible with  Beautyrest Smartmotion 1.0 (New Serta Grey Remote - We Also Have a Value OEM Part For $40 Less) Smart Motion Bases
SKU 00063
was $169.00
Save 6%
$159.00
3 Pc Conversion Kit Replacement Remote Set Compatible with Coaster, Serta, or Ergomotion (4 Pin -New Black Version- 8 Pin Motor Cord For Head (Plus & Play) and Lever Nut for Foot and Massage
SKU 10062
was $329.00
Save 24%
$249.00
Serta Motion Perfect 1.0, Motion Essentials 1.0 and Nuflex Older Gen or New Gen Reverie ECB2208C1 3 Piece Power Cord Set
SKU 00104
was $119.00
Save 17%
$99.00
Reverie 2E/3E Head Only 2 or 3 Button Corded Remote
SKU 00281
was $139.00
Save 14%
$119.00
SKU 00058
was $249.00
Save 20%
$199.00
MLily NU400 or NP2W+ Remote Control -Works With HJC18 And HJH55 Massage Control Boxes
SKU 10048
was $159.00
Save 9%
$145.00
Replacement Remote Compatible with Ashley Sierra Sleep M9X4 (x4) Bases
SKU 00059
$179.00
Serta Pivot RC-HW-107 Corded Remote
SKU 00062
was $129.00
Save 8%
$119.00
Leggett and Platt MR2T8TVZG with Massage Speed Scape Raven Remote- Don’t Just Match Remotes- Also Check Your Learn Button Before Ordering- MR2t TV
SKU 10044
$299.00
Replacement Remote Compatible with Mattress Firm 600 MF600 Pillow Tilt Remote (Make Sure You’re Getting The Correct One). Value Option Available For $260 Less.
SKU 00162
$499.00
Replacement Remote Compatible with Sleep Number Flex Fit or Select Comfort Shipshape Swingline Corded Bases NEW White OEM Version
SKU 00156
$299.00
Replacement Wireless Remote Compatible with  Beautyrest and In Motion (inMotion) Old Gen Renew Plus Bases - ALSO AVAIL Blue FOR $20 Less
SKU 00101
$249.00
Replacement Remote Compatible with Sealy Ease 1.0 2.0 3.0 or 4.0 - New 6 Button Serta Version
SKU 00248
was $169.00
Save 6%
$159.00
Replacement 2 Piece Conversion Kit Compatible w Simmons Nuflex or Softide 5100/8100 (no Lumbar Support) 6 Pin - New Grey Version Remote- Replaces Lost or Broken Remote
SKU 00080
was $329.00
Save 24%
$249.00
Reverie RC-WM-103, RC-WM-107, RC-WM-108 and Select Model RC-WM-103 Orthomattress Rcwm103 (buttons Must Match Exactly) ERC108 Replacement Remote
SKU 00127
was $139.00
Save 14%
$119.00
Replacement Remote Compatible with Ashley Sierra Sleep M9x5 (X5)(not X7) For a less Expensive Option, See our Conversion Kit
SKU 00056
was $209.00
Save 19%
$169.00
Replacement Remote Compatible with Adjusta-Magic Signature BASIC ONE VIBE Old Generation E02 -K1, E91SS, Certain Sleep Comfort & Lifestyles Silhouette (see Pics)
SKU 00151
$299.00
Leggett & Platt Simplicity HF Remote- Physical Button OEM Version Also Avail For $119- Ask For Info
SKU 10107
was $189.00
Save 11%
$169.00
