This kit converts Sealy Reflection 4 and Stearns and Foster Reflections (Reflexion) 7 bed base control boxes with an easy-to-install 3 step process and includes a new wireless remote to control your bed base with advanced features like backlit lights, and a flashlight. Used to replace a lost or broken remote when there are no more replacements available or in budget or to upgrade a basic remote with only a few buttons.
This kit includes 2 custom ports to allow you to simply plug in your existing motors from your existing wiring.
Kit Includes:
1) Conversion Control Box and a Power Supply Cable/Transformer Box - Simply plug in your existing cords and plug in the unit!
1) Wireless Remote Control with flashlight and backlighting- Simply plug in the kit after it’s installed and the remote will work. Each remote uses three AAA batteries (included since we program this prior to shipping.). You can only have one remote paired with one box at a time. If you want to buy a 2nd remote to use as a backup, we sell them for $70 each.
A Surge Protector. This can be a power strip or single box, but its important to make sure the words "Surge Protector" or some variant are on the unit. Usually you can buy both at walmart but the power strip without surge protection is a dollar or two less. Here is a combo strip/protector for $10 on Amazon: https://www.amazon.com/dp/B08466BVJV?ref_=cm_sw_r_...
We also offer this remote and control box with the massage buttons, and or preset features and hookups for $70+ more
