Replacement Remote Compatible with Rize Privia/Contemporary II/Avante Remote TRURC-N5 Compatible with New R4 Sealy - Discontinued, See Our New Universal Conversion Kit
$299.00
The original remotes have been discontinued by the manufacture.
We now offer several different conversion kits for $179-$349 that will include a new remote and control box. you can order either a basic four button or deluxe 9 or 13 button version that you would have to cut and strip your motor wires or a premium option where you simply unplug your motor cords and plug them into our new unit. Here are some links with that information
Basic: plug-In $179 (no presets, just up and down head and foot)
https://www.adjustablebedremotes.com/#!/Conversion-Kit-Non-Massage-Deluxe-Model-for-Reverie-Rize-TRUWR-P2-Privia-or-Craftmatic-4-Pin-Bases-Replace-lost-broken-remotes-Backlit-Controls-and-Flashlight-No-Presets/p/504505625
Deluxe: wire-in $249 (includes custom one touch  presets and one touch flat)
https://www.adjustablebedremotes.com/#!/9-Button-DELUXE-MODEL-Remote-Universal-Conversion-Kit-for-Adjustable-Beds-Most-newer-Beds-Your-Motors-must-be-24v-29v-Used-for-a-lost-broken-remote-Head-Up-Down-&-Foot-Up-Down-Backlit-White-Ver/p/473487140/category=0
Deluxe: plug-in $269 (includes custom presets/1 touch flat)
https://www.adjustablebedremotes.com/#!/Conversion-Kit-Non-Massage-Deluxe-Model-for-Reverie-Rize-Privia-Sealy-Reflection-Reflexion-R4-R7-Or-Craftmatic-4-Pin-Bases-Replace-lost-broken-remotes-13-Button-Backlit-Controls-&-Presets/p/478395158
Premium w massage: plug-in $299 (no movement presets but does include massage modes)
https://www.adjustablebedremotes.com/#!/Remote-Conversion-Kit-Premium-Model-for-Rize-or-Privia-Craftmatic-Manuta-by-Ruoey-Lung-Used-for-a-lost-broken-remote-13-Button-Backlit-Controls-Movement-Massage-NO-PRESETS-ON-THIS-MODEL-$50-More/p/471643941
Premium w massage: wire-in $299 (includes custom presets / 1 touch flat)
https://www.adjustablebedremotes.com/#!/9-Button-Plus-Massage-13-Total-PREMIUM-MODEL-Remote-Universal-Conversion-Kit-for-Adjustable-Beds-Most-newer-Beds-24v-29v-Motors-Used-for-a-lost-broken-remote-Head-Up-Down-&-Foot-Up-Down/p/471655154/category=0
Premium w massage: plug-in $349 (includes custom presets)
https://www.adjustablebedremotes.com/#!/Remote-Conversion-Kit-Premium-Model-for-Rize-or-Privia-Craftmatic-Manuta-by-Ruoey-Lung-Used-for-a-lost-broken-remote-13-Button-Backlit-Controls-Movement-Massage-Presets-Allow-a-Few-Days-To-Make/p/471643941
SKU 10113
was $399.00
Save 8%
$369.00
