Conversion Kit- 2 Boxes and One Synced Remote (Basic Model) Compatible with Rize/Deltadrive/Plus/Privia/Craftmatic/Ruoey Lung -Used for a lost remote. Backlit Controls Movement/NO PRESETS OR MASSAGE
$329.00
was $475.00 Save 31%
In stock: 1 available
This universal kit converts Mantua Rize Craftmatic or Reverie by Ruoey Lung bed base control boxes and includes a new wireless remote to control your bed base with advanced features like backlit lighting, a flashlight, and massage with three intensities and wave modes. Used to replace a lost or broken remote when there are no more replacements available or in budget or to upgrade a basic remote with only a few buttons. This is a double control box kit with one remote paired to each unit (designed for split king beds where a couple wants both sides to move together)
This kit includes all the wiring and ports needed to make your conversion. Simply unplug your four motors from the existing control box under your bed and plug them into our new unit. All of the remotes showed above used control boxes with five pin connection ports. As long as your box has massage and head and foot motors with five pins in the plugs then this will work. (See above picture)
Total installation should take no more than 5 minutes but it does require tipping the bed on its side or sliding under the bed to secure the new unit once plugged in.Kit Includes:
1) Conversion Control Box with Wire Harnesses and a Power Supply Cable/Transformer Box - Simply plug in the old cords into our new box
1) Wireless 17 Button Remote Control with flashlight and backlighting- Simply plug in the kit after it’s installed and the remote will work. Each remote uses three AAA batteries (included since we program this prior to shipping.). You can only have one remote paired with one box at a time or if you reach out to us we can pair one remote to two boxes if you want to synchronize your king split base. If you want to buy a 2nd remote to use as a backup, we sell them for $70 each.
We also offer this remote and control box without the massage buttons and hookups (if you didn’t want the extra buttons which won’t work to be on the remote even though it doesn’t hurt anything) or with massage but a universal wiring harness (if you don’t mind taking a few more minutes and cutting and stripping your massage and motor wires under your bed) for $50 less
Here:
https://www.adjustablebedremotes.com/#!/Conversion-Kit-Non-Massage-Deluxe-Model-for-Reverie-Rize-Privia-Reflexion-R4-R7-Or-Craftmatic-4-Pin-Bases-See-Pic-Used-for-a-lost-broken-remote-9-Button-Backlit-Controls-Movement-Presets/p/471875579
Or Here:
https://www.adjustablebedremotes.com/#!/13-Button-Remote-Universal-Conversion-Kit-for-Old-Adjustable-Beds-Most-newer-Beds-motors-must-be-24v-29V-Used-for-a-lost-broken-discon-remote-Head-Up-Down-&-Foot-Up-Down-3-Presets-&-Wave-Massage/p/471655154/category=0
If you need to have your presets functioning... we feature this kit here for $20 more.
Remote Conversion Kit (Premium Model) for Sealy R4 R7, Rize or Privia Craftmatic Manuta by Ruoey Lung -Used for a lost/broken remote. 13 Button Backlit Controls Movement/Massage/Presets (adjustablebedremotes.com)
Replacement Compatible with Certain iDealbeds (ideal) 4i/c, Certain Craftmatic Legacy, or Leggett & Platt Style Plus, Williamsburg, Frankfurt K-132  18 Button Remote- Make Sure Your Buttons Match Replacement Compatible with Certain iDealbeds (ideal) 4i/c, Certain Craftmatic Legacy, or Leggett & Platt Style Plus, Williamsburg, Frankfurt K-132  18 Button Remote- Make Sure Your Buttons Match
SKU 00102
was $149.00
Save 20%
$119.00
Replacement Remote Compatible with Sealy Old Generation Or Certain Old WRLS 2 VIB Dual Massage
SKU 00126
was $269.00
Save 7%
$249.00
Linak Or Easy Rest Easyrest Premier Wired (Now New Wireless Version - See Pics) Remote and Wireless Adapter by Leggett and Platt (We Have a Few Corded Remotes Left For $150 Less)Linak Or Easy Rest Easyrest Premier Wired (Now New Wireless Version - See Pics) Remote and Wireless Adapter by Leggett and Platt (We Have a Few Corded Remotes Left For $150 Less)
SKU 00072
$279.00
Leggett & Platt 100 Series II or Newer Gen 7 Button T-120 Adjustable Bed Replacement Remote for T120 Bases- New Gen Black w/Replaceable Batteries - Black or Silver VersionLeggett & Platt 100 Series II or Newer Gen 7 Button T-120 Adjustable Bed Replacement Remote for T120 Bases- New Gen Black w/Replaceable Batteries - Black or Silver Version
SKU 00035
was $149.00
Save 36%
$95.00
Okin Input Section Only for Power Cord Compatible with Serta/Sealy/Beautyrest (Motion Perfect 2/3/4, Motion Essentials 3/4/5, iSeries, Motion Plus/Air, Motion Custom 2/3, Ease, Extend, SmartmotionOkin Input Section Only for Power Cord Compatible with Serta/Sealy/Beautyrest (Motion Perfect 2/3/4, Motion Essentials 3/4/5, iSeries, Motion Plus/Air, Motion Custom 2/3, Ease, Extend, Smartmotion
SKU 10082
was $79.00
Save 13%
$69.00
Conversion Kit Compatible with Homelegance or Hofish Adjustable Base Remote Conversion Kit Compatible with Homelegance or Hofish Adjustable Base Remote
SKU 00142
was $209.00
Save 5%
$199.00
Reverie RC-WM-E02 (New Version) Replacement Remote
SKU 00273
was $140.00
Save 15%
$119.00
Reverie 3E RC-WM-109 Wireless Remote
SKU 00026
$349.00
Out of stock
Replacement Remote Compatible with Bnkdt By Wayfair Blissful Nights, Ergomotion Sherwood Bedding, Or Sapphire Sleep Series Bases- New Alt VersionReplacement Remote Compatible with Bnkdt By Wayfair Blissful Nights, Ergomotion Sherwood Bedding, Or Sapphire Sleep Series Bases- New Alt Version
SKU 00306
$149.00
Leggett & Platt Brio 30 Series Wired RemoteLeggett & Platt Brio 30 Series Wired Remote
SKU 00150
was $129.00
Save 8%
$119.00
E95 Scape (S-cape) -Only Compatible with Certain Old Gen Craftmatic, and Certain Okimat or Hb310 Leggett Or Sealy Remotes
SKU 00100
was $299.00
Save 17%
$249.00
Serta Motion Essentials and Ergo Black 1st Gen 1.0 (New 2 Pc Conversion Kit Version) Remote ReplacementSerta Motion Essentials and Ergo Black 1st Gen 1.0 (New 2 Pc Conversion Kit Version) Remote Replacement
SKU 00001
was $299.00
Save 40%
$179.00
Leggett BASIC ONE VIBE Remote Compatible with Old Generation E02 -K1, E91SS, Certain Sealy, Sleep Comfort & Lifestyles Silhouette and Other Models (see Pics)Leggett BASIC ONE VIBE Remote Compatible with Old Generation E02 -K1, E91SS, Certain Sealy, Sleep Comfort & Lifestyles Silhouette and Other Models (see Pics)
SKU 00140
$299.00
Scape Converter Kit w/Plug and #7453 Adapters. Works for the Interflex Titanium, Gold, and certain Englander Or Orthomatic remotesScape Converter Kit w/Plug and #7453 Adapters. Works for the Interflex Titanium, Gold, and certain Englander Or Orthomatic remotes
SKU 00108
$849.00
Leggett and Platt Old Gen Raven (New 3 Preset Version) MR2T8TVZG-PM Or Series V/ V Elite E95 Scape Remote- Mr2tLeggett and Platt Old Gen Raven (New 3 Preset Version) MR2T8TVZG-PM Or Series V/ V Elite E95 Scape Remote- Mr2t
SKU 00105
$249.00
Leggett & Platt Prodigy 1.0 Remote Conversion Kit w Massage Functionality (No Presets or Limits- The Old Remote Is Discontinued) Also Talk to Us About Kits w/o Massage For LessLeggett & Platt Prodigy 1.0 Remote Conversion Kit w Massage Functionality (No Presets or Limits- The Old Remote Is Discontinued) Also Talk to Us About Kits w/o Massage For Less
SKU 00083
was $279.00
Save 11%
$249.00
Power Cord Compatible with Certain Model Leggett 50 Series, and Matt Firm 300/600 3 Piece Set
SKU 00181
was $109.00
Save 9%
$99.00
Okin Massage/Lumbar/Bluetooth/USB Motion Custom Control Box
SKU 10090
was $359.00
Save 3%
$349.00
Ergomotion Pure Contour Gold Remote
SKU 00167
$159.00
Leggett and Platt Bas-x 2.0 Series Leggett Corded Remote
SKU 00164
was $129.00
Save 8%
$119.00
Adjustamagic Leggett E-90, E-91, or E-92, - New Gen Cord Replacement (e91, e92, e90)Adjustamagic Leggett E-90, E-91, or E-92, - New Gen Cord Replacement (e91, e92, e90)
SKU 10099
$55.00
Replacement Remote Compatible with Sealy Premier X-10 (x10) E97 Dual Vibe RemoteReplacement Remote Compatible with Sealy Premier X-10 (x10) E97 Dual Vibe Remote
SKU 00125
$599.00
Adjustamagic, Interflex Wired 2 Button, or Leggett 1st Series, Bronze, Silver, or Gold 10 Foot Cord Replacement OnlyAdjustamagic, Interflex Wired 2 Button, or Leggett 1st Series, Bronze, Silver, or Gold 10 Foot Cord Replacement Only
SKU 10055
$55.00
Ergomotion 5 Button 7 PIN (not 5) Corded Remote
SKU 10086
$159.00
Leggett and Platt Wallhugger S-Cape (New Black Version- Wall Hugger) Old Gen E-95 WRLS 2 VIB Raven RemoteLeggett and Platt Wallhugger S-Cape (New Black Version- Wall Hugger) Old Gen E-95 WRLS 2 VIB Raven Remote
SKU 00019
was $349.00
Save 29%
$249.00
Reverie R600/ R650 Dual Tilt Wireless Rechargeable Remote LED Versions (or Value Non-led Version w/AAA Batteries for $129)
SKU 00069
$449.00
Richmat HJH55 (New Version- see pics) Remote Compatible with Classic Brands As Seen On Wayfair or Nectar- Works With Certain HJC18 Massage Control Boxes as Shown Richmat HJH55 (New Version- see pics) Remote Compatible with Classic Brands As Seen On Wayfair or Nectar- Works With Certain HJC18 Massage Control Boxes as Shown
SKU 10096
was $159.00
Save 25%
$119.00
Ergomotion E4 Series WIRED 2 Piece Conversion Kit- See Pics- New Wireless White Remote & Control BoxErgomotion E4 Series WIRED 2 Piece Conversion Kit- See Pics- New Wireless White Remote & Control Box
SKU 00115
was $299.00
Save 10%
$269.00
Serta Perfect Position II New 3 Preset Version Remote
SKU 00021
was $279.00
Save 11%
$249.00
E95 Scape Control Box Only
SKU 10042
$279.00
Reverie 7t or R400/450 And R550 (non-Pillow Tilt) RC-WM-111 Wireless LED Remote- CHECK PROCESSOR BOX BEFORE ORDERINGReverie 7t or R400/450 And R550 (non-Pillow Tilt) RC-WM-111 Wireless LED Remote- CHECK PROCESSOR BOX BEFORE ORDERING
SKU 00067
$299.00
Replacement Remote Compatible with Select Comfort/Sleep Number Flex Fit (flexfit) Precision/Precision+ (New Black Version)Replacement Remote Compatible with Select Comfort/Sleep Number Flex Fit (flexfit) Precision/Precision+ (New Black Version)
SKU 00088
was $299.00
Save 17%
$249.00
Replacement Wireless Remote Compatible with BedTech X2 Corded Bases (btx2)
SKU 10085
was $159.00
Save 15%
$135.00
Ergomotion V/400 Series 6 Pin New 2 Pc Conversion Kit - See PicsErgomotion V/400 Series 6 Pin New 2 Pc Conversion Kit - See Pics
SKU 00071
was $349.00
Save 23%
$269.00
Ergomotion E6 Remote
SKU 00093
was $149.00
Save 20%
$119.00
Leggett & Platt Sunrise Remote
SKU 00077
$159.00
Replacement Wireless Remote Compatible with  Beautyrest Smartmotion 2.0 or 3.0 Beds (Smart Motion) Grey Remote Shown Right
SKU 00066
was $149.00
Save 20%
$119.00
SKU 00055
was $139.00
Save 14%
$119.00
Replacement Remote Compatible with MR2 Scape for Ergo Raven Bases by Tempurpedic GSMR2
SKU 00023
$249.00
Reverie 8T/9T or R600 R650 RC-WM-110 or Personal Comfort Flex 9 Wireless Remote with Lumbar FeatureReverie 8T/9T or R600 R650 RC-WM-110 or Personal Comfort Flex 9 Wireless Remote with Lumbar Feature
SKU 00044
was $149.00
Save 7%
$139.00
Serta Pivot RC-HW-107 Corded Remote
SKU 00062
$169.00
Replacement Remote Compatible with Mattress Firm 300 Series Topline 7 Button Phoenix Mecano Leggett Brand (Not Richmat 8 Button or Black/White Standup) Remote
SKU 00141
$229.00
Learn Cord For Certain Linak Bases
SKU 00275
$99.00
Replacement Remote Compatible with Tempurpedic B3111-220 Ergo Series TES Wired Remote RC-HW-106 Or Rc-hw-110
SKU 00024
was $149.00
Save 20%
$119.00
Ergomotion E4 or Tempur (must Match Picture Exactly) WIRED 2 Piece Conversion Kit- New Wireless White Remote & Control Box, See PicsErgomotion E4 or Tempur (must Match Picture Exactly) WIRED 2 Piece Conversion Kit- New Wireless White Remote & Control Box, See Pics
SKU 00116
was $299.00
Save 43%
$169.00
Serta Motion Plus Headboard Brackets Set (All Sizes) make sure to match the picture of the remote on the second pageSerta Motion Plus Headboard Brackets Set (All Sizes) make sure to match the picture of the remote on the second page
SKU 00094
was $119.00
Save 17%
$99.00
Leggett And Platt D-Series (D Series) Converter Kit w/Plug, New Motors, and Adapters #4b8900Leggett And Platt D-Series (D Series) Converter Kit w/Plug, New Motors, and Adapters #4b8900
SKU 00143
$399.00
Leggett & Platt S-Cape (scape) 1.0+, Performance +, or Matt. Firm 500 Series Remote- DISCONTINUED- You’ll Receive The Version with a Light Button And Non Functioning Pillow Tilt Buttons (700 Series)Leggett & Platt S-Cape (scape) 1.0+, Performance +, or Matt. Firm 500 Series Remote- DISCONTINUED- You’ll Receive The Version with a Light Button And Non Functioning Pillow Tilt Buttons (700 Series)
SKU 00032
$499.00
Conversion Kit 3 Pc With New Model Remote- Simply unplug your motors and plug them In- MASSAGE VERSION Compatible w Ashley Sierra Sleep HHC Moto (Motto) Sleep CH11, M9X6, M9X8, And M9X9Conversion Kit 3 Pc With New Model Remote- Simply unplug your motors and plug them In- MASSAGE VERSION Compatible w Ashley Sierra Sleep HHC Moto (Motto) Sleep CH11, M9X6, M9X8, And M9X9
SKU 00060
was $299.00
Save 33%
$199.00
Ergomotion and Certain Kingsdown V400 4 Pin (NOT 6) Remote Replacement
SKU 00107
$346.95
