Remote Generic Conversion Kit (Deluxe Model) Compatible with Legacy Tempur-pedic Plus -Used for a lost/broken remote. 9 Button Backlit Controls Movement/Presets- No Massage
$219.00
was $339.00 Save 35%
In stock: 1 available
This kit converts certain Tempurpedic bed base control boxes with an easy-to-install 3 step process and includes a new wireless remote to control your bed base with advanced features like presets, one touch flat, and customizable position buttons. Used to replace a lost or broken remote when there are no more replacements available or in budget -match your remote
Simply plug and play
Kit Includes:
1) Conversion Control Box with Wire Harnesses and a Power Supply Cable/Transformer Box
1) Wireless 9 button (or 13 depending on stock, the extra buttons would simply not work withoutan adapter massage upgrade cabble) Remote Control with flashlight and backlighting- Simply plug in the kit after it’s installed and the remote will work. Each remote uses three AAA batteries (included since we program this prior to shipping.). You can only have one remote paired with one box at a time. If you want to buy a 2nd remote to use as a backup, we sell them for $70 each.
Recommend
We also offer this remote and control box with a wireless bridge to connect to a smart phone app and the ability to program two remotes to one b9. for a $100 upgrade. Only one remote compare at a time to this control box.. Just contact us if interested
Richmat HJH13D, E300 Or HJH55, Compatible with Revive LS2000, Classic Brands (New White Wireless Remote by Mlily) Works With HJC18 No Massage Control BoxesRichmat HJH13D, E300 Or HJH55, Compatible with Revive LS2000, Classic Brands (New White Wireless Remote by Mlily) Works With HJC18 No Massage Control Boxes
SKU 00286
was $159.00
Save 15%
$135.00
Leggett And Platt Series 1 Lifestyle Corded Remote (includes Cord)
SKU 10049
$289.00
Richmat HJH55 (New Version- see pics) Remote Compatible with Classic Brands As Seen On Wayfair or Nectar- Works With Certain HJC18 Massage Control Boxes as Shown Richmat HJH55 (New Version- see pics) Remote Compatible with Classic Brands As Seen On Wayfair or Nectar- Works With Certain HJC18 Massage Control Boxes as Shown
SKU 10096
was $159.00
Save 25%
$119.00
Replacement Wireless Remote Compatible with BedTech X2 Corded Bases (btx2)
SKU 10085
was $159.00
Save 15%
$135.00
SKU 00058
was $249.00
Save 24%
$189.00
Ergomotion 6 Button Wired Remote Replacement Conversion Kit (New Control Box And Remote)Ergomotion 6 Button Wired Remote Replacement Conversion Kit (New Control Box And Remote)
SKU 00112
was $299.00
Save 17%
$249.00
Leggett and Platt Old Gen Raven (New 3 Preset Version) MR2T8TVZG-PM Or Series V/ V Elite E95 Scape Remote- Mr2tLeggett and Platt Old Gen Raven (New 3 Preset Version) MR2T8TVZG-PM Or Series V/ V Elite E95 Scape Remote- Mr2t
SKU 00105
$249.00
Replacement Remote Compatible with Certain MLily, Sven & Son, Classic Brands, or Idle Sleep NL300/nl300u Bases -Works With HJC18 Massage or NU203CB Control Boxes (Style May Vary)Replacement Remote Compatible with Certain MLily, Sven & Son, Classic Brands, or Idle Sleep NL300/nl300u Bases -Works With HJC18 Massage or NU203CB Control Boxes (Style May Vary)
SKU 10045
was $159.00
Save 15%
$135.00
Serta Motion Air Headboard Kit- Match Remote Picture 1st! (Remotes Sold Seperatly)Serta Motion Air Headboard Kit- Match Remote Picture 1st! (Remotes Sold Seperatly)
SKU 10100
was $149.00
Save 34%
$99.00
Ergomotion Pure Contour Gold Remote
SKU 00167
$159.00
Ergomotion 5 Button 7 PIN (not 5) Corded Remote
SKU 10086
$159.00
SKU 00055
was $139.00
Save 14%
$119.00
Original White Reverie 3E Wired RC-HW-105 or RC-HW-106 Corded Remote- Use Promo Code “TES” To Save $40 For The Black New Gen Option Shown In The 2nd Picture Original White Reverie 3E Wired RC-HW-105 or RC-HW-106 Corded Remote- Use Promo Code “TES” To Save $40 For The Black New Gen Option Shown In The 2nd Picture
SKU 00025
$199.00
Out of stock
Leggett & Platt Falcon 2.0+ Remote
SKU 00076
was $179.00
Save 58%
$75.00
Ergomotion E4+ WIRELESS Remote- New Grey VersionErgomotion E4+ WIRELESS Remote- New Grey Version
SKU 00218
was $149.00
Save 20%
$119.00
Lifestyles S-cape E95 (New Scape Black Version) Value RemoteLifestyles S-cape E95 (New Scape Black Version) Value Remote
SKU 00020
$249.00
Conversion Kit Compatible with Homelegance or Hofish Adjustable Base Remote Conversion Kit Compatible with Homelegance or Hofish Adjustable Base Remote
SKU 00142
was $209.00
Save 5%
$199.00
Leggett & Platt Premier Series Remote
SKU 00216
$249.00
RC-WM-101 Replacement Remote Compatible with Tempurpedic Ergo Advanced (New Gray RC-WM-119 Version) Remote
SKU 00022
was $149.00
Save 20%
$119.00
Replacement Remote Compatible with InKline White Noise 5 Button or Black 6 Button BasesReplacement Remote Compatible with InKline White Noise 5 Button or Black 6 Button Bases
SKU 10095
$149.00
Replacement Remote Compatible with Sleep Number Flex Fit (flexfit) BASIC ONE VIBE Non-LCD Version (see Pics)
SKU 00152
$299.00
Replacement Wireless Remote Compatible with Beautyrest Black Luxury Or Motion Restore BasesReplacement Wireless Remote Compatible with Beautyrest Black Luxury Or Motion Restore Bases
SKU 00145
was $149.00
Save 30%
$105.00
Replacement Remote Compatible with Living Comfort, Euro Sleep, and WRLS 2 VIBE Adjustable Bed Remote ReplacementReplacement Remote Compatible with Living Comfort, Euro Sleep, and WRLS 2 VIBE Adjustable Bed Remote Replacement
SKU 00305
$349.00
Ergomotion Softide 2100 Remote 3 Piece Wireless Conversion Kit Ergomotion Softide 2100 Remote 3 Piece Wireless Conversion Kit
SKU 00114
was $299.00
Save 27%
$219.00
Replacement Wireless Remote Compatible with BedTech or Motosleep Moto CH10 ZG Bases
SKU 00237
$229.00
Out of stock
Leggett And Platt Softline Pro-Motion, Swingline, Sleep Number Flex Fit Wired, Series III, or 1st Gen Brio (new Black And White Version- Top Right Pic)
SKU 00073
was $129.00
Save 8%
$119.00
Leggett & Platt Brio 30 Series Wired RemoteLeggett & Platt Brio 30 Series Wired Remote
SKU 00150
was $129.00
Save 8%
$119.00
Replacement Remote Compatible with Sealy Reflections (Reflexion) 4 R4 Remote TRURC-N5 Replacement Remote- Discontinued, See Our New Universal Conversion Kit
SKU 10109
$319.00
Out of stock
Leggett & Platt C-Series (C Series 9644) Universal Conversion Kit (old Model Disc.)Leggett & Platt C-Series (C Series 9644) Universal Conversion Kit (old Model Disc.)
SKU 00257
was $199.00
Save 10%
$179.00
E95 Scape Control Box Only
SKU 10042
$279.00
Mlily Adjustables MS300 Queen Size Dual Massage 750lb Capacity Adjustable Bed w/Free Shipping Special Order Eta 1 WkMlily Adjustables MS300 Queen Size Dual Massage 750lb Capacity Adjustable Bed w/Free Shipping Special Order Eta 1 Wk
SKU 00168
was $1 049.00
Save 5%
$999.99
Ergomotion E4 or Tempur (must Match Picture Exactly) WIRED 2 Piece Conversion Kit- New Wireless White Remote & Control Box, See PicsErgomotion E4 or Tempur (must Match Picture Exactly) WIRED 2 Piece Conversion Kit- New Wireless White Remote & Control Box, See Pics
SKU 00116
was $299.00
Save 43%
$169.00
Ergomotion V/400 Series 6 Pin New 2 Pc Conversion Kit - See PicsErgomotion V/400 Series 6 Pin New 2 Pc Conversion Kit - See Pics
SKU 00071
was $349.00
Save 23%
$269.00
Ergomotion 6 Button 5 PIN (not 7) Corded Remote
SKU 10087
$149.00
Ergomotion Softide 2100 WIRELESS Remote - NEW 2 Pc Conversion kit - See attachedErgomotion Softide 2100 WIRELESS Remote - NEW 2 Pc Conversion kit - See attached
SKU 00113
was $299.00
Save 27%
$219.00
Replacement Wireless Remote Compatible with  Beautyrest Smartmotion 2.0 or 3.0 Beds (Smart Motion) Grey Remote Shown Right
SKU 00066
was $149.00
Save 20%
$119.00
Okin Input Section Only for Power Cord Compatible with Serta/Sealy/Beautyrest (Motion Perfect 2/3/4, Motion Essentials 3/4/5, iSeries, Motion Plus/Air, Motion Custom 2/3, Ease, Extend, SmartmotionOkin Input Section Only for Power Cord Compatible with Serta/Sealy/Beautyrest (Motion Perfect 2/3/4, Motion Essentials 3/4/5, iSeries, Motion Plus/Air, Motion Custom 2/3, Ease, Extend, Smartmotion
SKU 10082
was $79.00
Save 13%
$69.00
Adjustamagic, Interflex Wired 2 Button, or Leggett 1st Series, Bronze, Silver, or Gold 10 Foot Cord Replacement OnlyAdjustamagic, Interflex Wired 2 Button, or Leggett 1st Series, Bronze, Silver, or Gold 10 Foot Cord Replacement Only
SKU 10055
$55.00
Replacement Remote Compatible with Ashley Sierra Sleep M9X9 Or Black Moto Sleep ZG3 X9 Bases
SKU 00061
was $299.00
Save 17%
$249.00
Richmat HJH55 (New Version- See Description) Compatible with Mattress 600 or 3000 Silver or Black, Enso, Classic Brands Innova NU203CB, PostureCloud- Works with Certain HJC18  Boxes - Mf3000Richmat HJH55 (New Version- See Description) Compatible with Mattress 600 or 3000 Silver or Black, Enso, Classic Brands Innova NU203CB, PostureCloud- Works with Certain HJC18  Boxes - Mf3000
SKU 00256
was $159.00
Save 21%
$125.00
Leggett & Platt Signature, Simplicity 2.0, or certain 100 Or 300 Brio Series Remote- Disc. Model, See PicsLeggett & Platt Signature, Simplicity 2.0, or certain 100 Or 300 Brio Series Remote- Disc. Model, See Pics
SKU 00034
$179.00
Mlily Adjustables MS200 TwXL (Buy 2 to make a Split King) Size 750lb Capacity Adjustable Bed w/Free ShippingMlily Adjustables MS200 TwXL (Buy 2 to make a Split King) Size 750lb Capacity Adjustable Bed w/Free Shipping
SKU 00173
was $799.00
Save 19%
$649.00
Leggett & Platt S-Cape (scape) 1.0+, Performance +, or Matt. Firm 500 Series Remote- DISCONTINUED- You’ll Receive The Version with a Light Button And Non Functioning Pillow Tilt Buttons (700 Series)Leggett & Platt S-Cape (scape) 1.0+, Performance +, or Matt. Firm 500 Series Remote- DISCONTINUED- You’ll Receive The Version with a Light Button And Non Functioning Pillow Tilt Buttons (700 Series)
SKU 00032
$499.00
Replacement Remote Compatible with Tempurpedic Ergo Power or Extend Remote- 30 Day Return -Scratched but tested working perfectly fineReplacement Remote Compatible with Tempurpedic Ergo Power or Extend Remote- 30 Day Return -Scratched but tested working perfectly fine
SKU 00121
was $139.00
Save 22%
$109.00
Replacement Remote Compatible with Bnkdt By Wayfair Blissful Nights, Ergomotion Sherwood Bedding, Or Sapphire Sleep Series Bases- New Alt VersionReplacement Remote Compatible with Bnkdt By Wayfair Blissful Nights, Ergomotion Sherwood Bedding, Or Sapphire Sleep Series Bases- New Alt Version
SKU 00306
$149.00
Reverie 2E/3E Head Only 2 or 3 Button Corded RemoteReverie 2E/3E Head Only 2 or 3 Button Corded Remote
SKU 00281
was $139.00
Save 14%
$119.00
Ergomotion E4 Series WIRED 2 Piece Conversion Kit- See Pics- New Wireless White Remote & Control BoxErgomotion E4 Series WIRED 2 Piece Conversion Kit- See Pics- New Wireless White Remote & Control Box
SKU 00115
was $299.00
Save 10%
$269.00
Reverie OSO O300 ERC239A01 (erc239) 433 MHz Oso300 Wireless Remote
SKU 00166
was $149.00
Save 7%
$139.00
Replacement Remote Compatible with Ashley 2 Button Sierra Sleep M8X (M8x132 or M8x142) Moto Sleep HHC HSW302
SKU 00163
$149.00
Replacement 3pc Conversion Kit w Wireless Remote Compatible with the Discontinued BedTech or Moto Sleep (Motto Sleep) CH13 ZG XSF300 RemoteReplacement 3pc Conversion Kit w Wireless Remote Compatible with the Discontinued BedTech or Moto Sleep (Motto Sleep) CH13 ZG XSF300 Remote
SKU 00238
was $399.00
Save 38%
$249.00
