Ergomotion 6 Button Wired Remote Replacement Conversion Kit (New Control Box And Remote)
$249.00
was $299.00 Save 17%
In stock: 5 available
These are model specific. As of 2020 the mfg has discontinued the old remotes and released this 2 pc conversion kit. If you can’t match your old remote or owners manual contact us for help looking up serial numbers
SKU 10113
was $399.00
Save 8%
$369.00
