Remote Generic Conversion Kit (Basic Model w Massage) Compatible w/Legacy Tempur-pedic Ergo Premier or Grand -Used for a lost/broken remote. 12 Button Backlit Controls - No Presets TES200
$229.00
was $359.00 Save 36%
In stock: 19 available
Because the original remotes and parts have been discontinued, replacing a lost or broken old generation Remote requires converting the electronics with one of these conversion kits which includes a new gen wireless remote to control your bed base. We have several different kits available per base depending on budget and required functionality. This universal kit converts Tempurpedic Premier, and Grand bed base control boxes with an easy-to-install 3 step process to control your bed base with massage with three intensities and wave modes. Used to replace a lost or broken remote when there are no more replacements available or in budget (some termpurpedic bases had three massage motors but new gen control boxes only feature a head and foot massage so most just leave the 3rd unplugged or you can splice two together if you prefer)
Simply plug and play
Kit Includes:
1) Conversion Control Box with Wire Harnesses and a Power Supply Cable/Transformer Box
1) Wireless 12 Button Remote Control with flashlight and backlighting- Simply plug in the kit after it’s installed and the remote will work. (The presets and one touch flat button will not work on this model... see the premier kit if that is needed for extra cost. Each remote uses three AAA batteries (included since we program this prior to shipping.). You can only have one remote paired with one box at a time. If you want to buy a 2nd remote to use as a backup, we sell them for $70 each.
Recommend
We also offer this remote and control box without the massage buttons for less Just contact us if interested
Leggett & Platt Prodigy 1.0 Remote Conversion Kit w Massage Functionality (No Presets or Limits- The Old Remote Is Discontinued) Also Talk to Us About Kits w/o Massage For LessLeggett & Platt Prodigy 1.0 Remote Conversion Kit w Massage Functionality (No Presets or Limits- The Old Remote Is Discontinued) Also Talk to Us About Kits w/o Massage For Less
SKU 00083
was $279.00
Save 11%
$249.00
Reverie R600/ R650 Dual Tilt Wireless Rechargeable Remote LED Versions (or Value Non-led Version w/AAA Batteries for $129)
SKU 00069
$449.00
Ergomotion Softide 8100 Or 8300 Remote- Discontinued- See Our New Conversion Kit
SKU 00111
$249.00
Out of stock
Leggett & Platt Premier Series Remote
SKU 00216
$249.00
Ergomotion E4 Series WIRED 2 Piece Conversion Kit- See Pics- New Wireless White Remote & Control BoxErgomotion E4 Series WIRED 2 Piece Conversion Kit- See Pics- New Wireless White Remote & Control Box
SKU 00115
was $299.00
Save 10%
$269.00
Reverie 7t or R400/450 And R550 (non-Pillow Tilt) RC-WM-111 Wireless LED Remote- CHECK PROCESSOR BOX BEFORE ORDERINGReverie 7t or R400/450 And R550 (non-Pillow Tilt) RC-WM-111 Wireless LED Remote- CHECK PROCESSOR BOX BEFORE ORDERING
SKU 00067
$299.00
Ergomotion Softide 5100/8100 Remote- Discontinued… See Our New Conversion Kit Ergomotion Softide 5100/8100 Remote- Discontinued… See Our New Conversion Kit
SKU 00091
was $299.00
Save 10%
$269.00
Out of stock
Serta Motion Signature (New Version -Lift/Massage) RC-WM-E01 Replacement Remote
SKU 00038
was $140.00
Save 29%
$99.00
Adjustamagic Leggett E-90, E-91, or E-92, - New Gen Cord Replacement (e91, e92, e90)Adjustamagic Leggett E-90, E-91, or E-92, - New Gen Cord Replacement (e91, e92, e90)
SKU 10099
$55.00
Leggett & Platt Scape HF Massage And Certain Model MF 900 Remote- Physical Button OEM Version (original Glass Front Version Discontinued)Leggett & Platt Scape HF Massage And Certain Model MF 900 Remote- Physical Button OEM Version (original Glass Front Version Discontinued)
SKU 10088
was $149.00
Save 20%
$119.00
Whisper Power Replacement Remote Compatible with Certain Craftmatic Craft 1 Bases NEW GEN (MUST READ BELOW TO VERIFY MODEL- DONT JUST GO OFF THE PICTURE ON THIS ONE)Whisper Power Replacement Remote Compatible with Certain Craftmatic Craft 1 Bases NEW GEN (MUST READ BELOW TO VERIFY MODEL- DONT JUST GO OFF THE PICTURE ON THIS ONE)
SKU 00147
was $299.00
Save 7%
$279.00
Leggett And Platt D-Series (D Series) Converter Kit w/Plug, New Motors, and Adapters #4b8900Leggett And Platt D-Series (D Series) Converter Kit w/Plug, New Motors, and Adapters #4b8900
SKU 00143
$399.00
SKU 00055
was $139.00
Save 14%
$119.00
Ergomotion V/400 Series 6 Pin New 2 Pc Conversion Kit - See PicsErgomotion V/400 Series 6 Pin New 2 Pc Conversion Kit - See Pics
SKU 00071
was $349.00
Save 23%
$269.00
Ergomotion Pure Contour Gold Remote
SKU 00167
$159.00
Remote Compatible with Rize Beds- Discontinued -Contemporary/Relaxer Remote TRUN2-FM Replacement- See Our Conversion Kit
SKU 00261
$299.00
Out of stock
Serta Motion Perfect IV (4 4th Gen) Remote
SKU 00017
was $169.00
Save 30%
$119.00
Adjustamagic, Interflex Wired 2 Button, or Leggett 1st Series, Bronze, Silver, or Gold 10 Foot Cord Replacement OnlyAdjustamagic, Interflex Wired 2 Button, or Leggett 1st Series, Bronze, Silver, or Gold 10 Foot Cord Replacement Only
SKU 10055
$55.00
Replacement Remote Compatible with Idealbeds 5i/custom Wireless Remote (New Name brand Replacement Remote With All The Same Features- ideal)Replacement Remote Compatible with Idealbeds 5i/custom Wireless Remote (New Name brand Replacement Remote With All The Same Features- ideal)
SKU 00277
was $149.00
Save 20%
$119.00
Ergomotion E4+ WIRELESS Remote- New Grey VersionErgomotion E4+ WIRELESS Remote- New Grey Version
SKU 00218
was $149.00
Save 20%
$119.00
Replacement Remote Compatible with Mattress Firm 50 II Series, Bas-X HC, K-110 or 0776 Somos Bed (Somosbeds) 200 Series Leggett Corded Remote
SKU 00099
was $159.00
Save 38%
$99.00
Reverie 2E/3E Head Only 2 or 3 Button Corded RemoteReverie 2E/3E Head Only 2 or 3 Button Corded Remote
SKU 00281
was $139.00
Save 14%
$119.00
Serta Motion Essentials 3 (III) 3rd Gen Wireless Remote
SKU 00007
was $145.00
Save 25%
$109.00
Leggett & Platt Signature, Simplicity 2.0, or certain 100 Or 300 Brio Series Remote- Disc. Model, See PicsLeggett & Platt Signature, Simplicity 2.0, or certain 100 Or 300 Brio Series Remote- Disc. Model, See Pics
SKU 00034
$179.00
Leggett And Platt Series II Silver Corded Remote (Must Look The Same -includes Cord)
SKU 10050
$399.00
Mlily Adjustables MS200 TwXL (Buy 2 to make a Split King) Size 750lb Capacity Adjustable Bed w/Free ShippingMlily Adjustables MS200 TwXL (Buy 2 to make a Split King) Size 750lb Capacity Adjustable Bed w/Free Shipping
SKU 00173
was $799.00
Save 19%
$649.00
Replacement Remote Compatible with Tempurpedic B3111-220 Ergo Series TES Wired Remote RC-HW-106 Or Rc-hw-110
SKU 00024
was $149.00
Save 20%
$119.00
Ergomotion 6 Button Wired Remote Replacement Conversion Kit (New Control Box And Remote)Ergomotion 6 Button Wired Remote Replacement Conversion Kit (New Control Box And Remote)
SKU 00112
was $299.00
Save 17%
$249.00
Reverie 8T/9T or R600 R650 RC-WM-110 or Personal Comfort Flex 9 Wireless Remote with Lumbar FeatureReverie 8T/9T or R600 R650 RC-WM-110 or Personal Comfort Flex 9 Wireless Remote with Lumbar Feature
SKU 00044
was $149.00
Save 7%
$139.00
Replacement Remote Compatible with Sealy BASIC ONE VIBE E97 Old Generation Single Vibe (see Pics and Massage Info Below)
SKU 00124
$299.00
Leggett & Platt Symmetry Richmat HJH37 Remote
SKU 00208
was $169.00
Save 36%
$109.00
Serta/Ergomotion Motion Essentials 1 (1st), 3 (III 3rd), 4 (IV 4th) and 5 (V 5th), 6 (VI) BaseLogic, iSeries Headboard Brackets Set (All Sizes)Serta/Ergomotion Motion Essentials 1 (1st), 3 (III 3rd), 4 (IV 4th) and 5 (V 5th), 6 (VI) BaseLogic, iSeries Headboard Brackets Set (All Sizes)
SKU 00046
was $129.00
Save 31%
$89.00
Serta Perfect Position 1st Gen Converter Kit w/New Remote, Plug and Adapters
SKU 00119
$849.00
Original White Reverie 3E Wired RC-HW-105 or RC-HW-106 Corded Remote- Use Promo Code “TES” To Save $40 For The Black New Gen Option Shown In The 2nd Picture Original White Reverie 3E Wired RC-HW-105 or RC-HW-106 Corded Remote- Use Promo Code “TES” To Save $40 For The Black New Gen Option Shown In The 2nd Picture
SKU 00025
$199.00
Out of stock
Replacement Wireless Remote Compatible with BedTech or Motosleep Moto CH10 ZG Bases
SKU 00237
$229.00
Out of stock
Ergomotion E9 or Sherwood E9 Replacement RemoteErgomotion E9 or Sherwood E9 Replacement Remote
SKU 00217
$159.00
Serta iSeries (New Serta Logo) Okin Remote
SKU 00016
was $149.00
Save 34%
$99.00
Serta Motion Slim or Leggett 100 Series (New Black or Silver Version w/Light Original MFG) Replacement Remote
SKU 00008
was $179.00
Save 47%
$95.00
Replacement Remote Compatible with Sleep Number Flex Fit (flexfit) BASIC ONE VIBE Non-LCD Version (see Pics)
SKU 00152
$299.00
Adjusta-Magic E92 (e-92), Wired Contour Premier, and Replacement For Certain Wired Craft 1 Craftmatic Corded RemotesAdjusta-Magic E92 (e-92), Wired Contour Premier, and Replacement For Certain Wired Craft 1 Craftmatic Corded Remotes
SKU 00051
$399.00
Serta Motion Essentials II (2nd) Gen hb12012-00 M-120 Linak Wired Remote (Alt black version avail. for $60 less!)Serta Motion Essentials II (2nd) Gen hb12012-00 M-120 Linak Wired Remote (Alt black version avail. for $60 less!)
SKU 00002
was $179.00
Save 11%
$159.00
Out of stock
Ergomotion Quest 2.0 Adjustable Remote
SKU 00287
was $199.00
Save 15%
$169.00
Old Gen Nuflex and Serta Motion Perfect Massage Combination Splitter Cord (2 Sets to Sync/Split Four Massage Units Down To 2)
SKU 10080
$49.00
Conversion Kit 3 Pc With New Model Remote- Simply unplug your motors and plug them In- MASSAGE VERSION Compatible w Ashley Sierra Sleep HHC Moto (Motto) Sleep CH11, M9X6, M9X8, And M9X9Conversion Kit 3 Pc With New Model Remote- Simply unplug your motors and plug them In- MASSAGE VERSION Compatible w Ashley Sierra Sleep HHC Moto (Motto) Sleep CH11, M9X6, M9X8, And M9X9
SKU 00060
was $299.00
Save 33%
$199.00
Adjusta-Magic E90 (e-90) Corded Remote (New Version With A Few Extra Buttons)Adjusta-Magic E90 (e-90) Corded Remote (New Version With A Few Extra Buttons)
SKU 00049
$299.00
Serta Perfect Position II BASIC ONE VIBE Old Generation E02 -K1, E91SS, New 2020 Raven Version (see Pics)Serta Perfect Position II BASIC ONE VIBE Old Generation E02 -K1, E91SS, New 2020 Raven Version (see Pics)
SKU 00146
$299.00
Linak Authentic OEM Power Cord Set Compatible with Serta Motion Essentials 2, Motion Slim, Leggett & Platt 100 Series II, S-cape, Renew Basic And Plus Series, & Beautyrest Simple Motion BasesLinak Authentic OEM Power Cord Set Compatible with Serta Motion Essentials 2, Motion Slim, Leggett & Platt 100 Series II, S-cape, Renew Basic And Plus Series, & Beautyrest Simple Motion Bases
SKU 00053
was $169.00
Save 47%
$89.00
Replacement Wireless Remote Compatible with  Beautyrest Smartmotion 1.0 (New Serta Grey Remote) Smart Motion Bases
SKU 00063
was $169.00
Save 30%
$119.00
Replacement Power Cord Compatible with certain model Sealy and Tempurpedic Extend, Ergo & Ease 1.0/2.0/3.0 - 3 Piece Set
SKU 00042
was $109.00
Save 13%
$95.00
Leg Kit Compatible with Serta Motion Essentials/iSeries (all Gens But The 2nd)/Perfect, Certain Blissful Nights, and Sealy or Beautyrest New Gen 3-9” (4 Legs Total) 1st GenLeg Kit Compatible with Serta Motion Essentials/iSeries (all Gens But The 2nd)/Perfect, Certain Blissful Nights, and Sealy or Beautyrest New Gen 3-9” (4 Legs Total) 1st Gen
SKU 00270
was $99.00
Save 20%
$79.00
