Conversion Kit (Premium Massage Model) for Reverie RC-WM-102 Legacy Bases (See Pic) -Used for a lost/broken remote. 13 Button Backlit Controls Movement/Massage/Presets
$349.00
was $399.00 Save 13%
In stock: 5 available
This universal kit converts old generation Reverie wireless bed base control boxes and includes a new wireless remote to control your bed base with advanced features like presets, one touch flat, and massage with three intensities and wave modes. Used to replace a lost or broken remote when there are no more replacements available or in budget or to upgrade a basic remote with only a few buttons.
This kit includes all the wiring and harnesses needed to make your conversion. Total installation should take no more than 5 minutes but it does require tipping the bed on its side. If you want to ensure that this model is compatible, match your original remote
We send detailed instructions but you just need to plug in your motor plugs under the bed. Then secure the boxes to your frame with our zip cables we provide, plug the new power cord in, and you’re good to go!
Kit Includes:
1) Conversion Control Box with Wire Harnesses and a Power Supply Cable/Transformer Box
1) Wireless 13 Button Remote Control with flashlight and backlighting- Simply plug in the kit after it’s installed and the remote will work. Each remote uses three AAA batteries (included since we program this prior to shipping.). You can only have one remote paired with one box at a time. If you want to buy a 2nd remote to use as a backup, we sell them for $70 each.
We also offer this remote and control box without the massage buttons and hookups for less if you dont have massage motors on your base or if you don't use massage or wanted to save money:
1) 9 Button Backlit Remote/Universal Conversion Kit for Adjustable Beds (Most newer Beds- Your Motors must be 24v-29V) -Used for a lost/broken/discontinued remote. Head Up/Down & Foot Up/Down 3 Preset (adjustablebedremotes.com)
Leggett And Platt Softline Pro-Motion, Swingline, Sleep Number Flex Fit Wired, Series III, or 1st Gen Brio (new Black And White Version- Top Right Pic)
SKU 00073
was $129.00
Save 8%
$119.00
Leggett & Platt Signature, Simplicity 2.0, or certain 100 Or 300 Brio Series Remote- Disc. Model, See PicsLeggett & Platt Signature, Simplicity 2.0, or certain 100 Or 300 Brio Series Remote- Disc. Model, See Pics
SKU 00034
$179.00
Serta Perfect Position II New 3 Preset Version Remote
SKU 00021
was $279.00
Save 11%
$249.00
Serta Motion Perfect 1.0, Motion Essentials 1.0 and Nuflex Older Gen or New Gen Reverie ECB2208C1 3 Piece Power Cord SetSerta Motion Perfect 1.0, Motion Essentials 1.0 and Nuflex Older Gen or New Gen Reverie ECB2208C1 3 Piece Power Cord Set
SKU 00104
was $119.00
Save 17%
$99.00
Replacement Wireless Remote Compatible with  Beautyrest Smartmotion 2.0 or 3.0 Beds (Smart Motion) Grey Remote Shown Right
SKU 00066
was $149.00
Save 20%
$119.00
Replacement 3pc Conversion Kit w Wireless Remote Compatible with the Discontinued BedTech or Moto Sleep (Motto Sleep) CH13 ZG XSF300 RemoteReplacement 3pc Conversion Kit w Wireless Remote Compatible with the Discontinued BedTech or Moto Sleep (Motto Sleep) CH13 ZG XSF300 Remote
SKU 00238
was $399.00
Save 38%
$249.00
Serta Perfect Position II BASIC ONE VIBE Old Generation E02 -K1, E91SS, New 2020 Raven Version (see Pics)Serta Perfect Position II BASIC ONE VIBE Old Generation E02 -K1, E91SS, New 2020 Raven Version (see Pics)
SKU 00146
$299.00
Linak Authentic OEM Power Cord Set Compatible with Serta Motion Essentials 2, Motion Slim, Leggett & Platt 100 Series II, S-cape, Renew Basic And Plus Series, & Beautyrest Simple Motion BasesLinak Authentic OEM Power Cord Set Compatible with Serta Motion Essentials 2, Motion Slim, Leggett & Platt 100 Series II, S-cape, Renew Basic And Plus Series, & Beautyrest Simple Motion Bases
SKU 00053
was $169.00
Save 47%
$89.00
Remote Compatible with Rize Beds- Discontinued -Contemporary/Relaxer Remote TRUN2-FM Replacement- See Our Conversion Kit
SKU 00261
$299.00
Out of stock
Replacement Remote Compatible with Interflex Silver or Old Gen Specific Simmons Corded Bases (Must Look The Same- includes Cord)
SKU 10040
$399.00
Replacement Remote Compatible with Sleep Number Flex Fit or Select Comfort Shipshape Swingline Corded Bases NEW White OEM VersionReplacement Remote Compatible with Sleep Number Flex Fit or Select Comfort Shipshape Swingline Corded Bases NEW White OEM Version
SKU 00156
$299.00
Reverie OSO O300T ERC143A01 (143A01 ) Wireless Remote 2.4 GHz
SKU 00090
was $139.00
Save 3%
$135.00
Replacement Wireless Remote Compatible with BedTech or Motosleep Moto CH10 ZG Bases
SKU 00237
$229.00
Out of stock
Leggett & Platt S-Cape (scape) 2.0 Zero Clearance Version (Not Old Gen 1.0 or 2.0 Black Remote- See Other Listing) w Flashlight Button
SKU 10079
was $299.00
Save 20%
$239.00
E95 Scape (S-cape) -Only Compatible with Certain Old Gen Craftmatic, and Certain Okimat or Hb310 Leggett Or Sealy Remotes
SKU 00100
was $299.00
Save 17%
$249.00
Serta Motion Essentials II (2nd) Gen hb12012-00 M-120 Linak Wired Remote (Alt black version avail. for $60 less!)Serta Motion Essentials II (2nd) Gen hb12012-00 M-120 Linak Wired Remote (Alt black version avail. for $60 less!)
SKU 00002
was $179.00
Save 11%
$159.00
Out of stock
Serta Motion Perfect, Essentials (Not 2nd Gen), Custom, Plus, Air, New Gen Ergomotion, Ease/Tempur, Matt Firm 50/okin 300/600 & Richmat/Reverie 29v Power Box/Plug (Doesn’t inc. input cord)
SKU 00132
was $99.00
Save 30%
$69.00
Replacement Remote Compatible with Rize Privia/Contemporary II/Avante Remote TRURC-N5 Compatible with New R4 Sealy - Discontinued, See Our New Universal Conversion Kit Replacement Remote Compatible with Rize Privia/Contemporary II/Avante Remote TRURC-N5 Compatible with New R4 Sealy - Discontinued, See Our New Universal Conversion Kit
SKU 00279
$299.00
Out of stock
Replacement Remote Compatible with Beautyrest Smartmotion 1.0 (New Value Grey Remote - See 2nd Picture For the Remote You’ll Get) Smart MotionReplacement Remote Compatible with Beautyrest Smartmotion 1.0 (New Value Grey Remote - See 2nd Picture For the Remote You’ll Get) Smart Motion
SKU 10089
was $149.00
Save 20%
$119.00
Richmat HJH13D, E300 Or HJH55, Compatible with Revive LS2000, Classic Brands (New White Wireless Remote by Mlily) Works With HJC18 No Massage Control BoxesRichmat HJH13D, E300 Or HJH55, Compatible with Revive LS2000, Classic Brands (New White Wireless Remote by Mlily) Works With HJC18 No Massage Control Boxes
SKU 00286
was $159.00
Save 15%
$135.00
Reverie 7t or R400/450 And R550 (non-Pillow Tilt) RC-WM-111 Wireless LED Remote- CHECK PROCESSOR BOX BEFORE ORDERINGReverie 7t or R400/450 And R550 (non-Pillow Tilt) RC-WM-111 Wireless LED Remote- CHECK PROCESSOR BOX BEFORE ORDERING
SKU 00067
$299.00
Ergomotion 6 Button 5 PIN (not 7) Corded Remote
SKU 10087
$149.00
Reverie 3E RC-WM-109 Wireless Remote
SKU 00026
$349.00
Okin Massage Control Box Replaces Keeson Kesson Control Box Model Number MC121 MC122 (mc121bs, Mc122sc)
SKU 00290
$199.00
Scape Converter Kit w/Plug and #7453 Adapters. Works for the Interflex Titanium, Gold, and certain Englander Or Orthomatic remotesScape Converter Kit w/Plug and #7453 Adapters. Works for the Interflex Titanium, Gold, and certain Englander Or Orthomatic remotes
SKU 00108
$849.00
Replacement Remote Compatible with Sleep Number Flex Fit or Select Comfort Ship Shape Corded Bases OEM Version
SKU 00283
$299.00
Reverie RC-WM-E02 (New Version) Replacement Remote
SKU 00273
was $140.00
Save 15%
$119.00
Replacement Wireless Remote Compatible with Beautyrest Leggett Old Gen Renew or Certain Older Gen Model T-120 or M-120 (Linak- Not Richmat New Silver T120 or M120 Version Only) Basic Wireless Bases
SKU 00054
$169.00
Serta Perfect Position 1st Gen Converter Kit w/New Remote, Plug and Adapters
SKU 00119
$849.00
Ergomotion and Certain Kingsdown V400 4 Pin (NOT 6) Remote Replacement
SKU 00107
$346.95
SKU 00058
was $249.00
Save 24%
$189.00
Lifestyles S-cape E95 (New Scape Black Version) Value RemoteLifestyles S-cape E95 (New Scape Black Version) Value Remote
SKU 00020
$249.00
Replacement Remote Compatible with Idealbeds 5i/custom Wireless Remote (New Name brand Replacement Remote With All The Same Features- ideal)Replacement Remote Compatible with Idealbeds 5i/custom Wireless Remote (New Name brand Replacement Remote With All The Same Features- ideal)
SKU 00277
was $149.00
Save 20%
$119.00
Reverie 3E Mesh RC-WM-113 (replaces -117) Wireless Remote 3EM- Used Showroom Model w/o Battery Cover Option Avail For $75Reverie 3E Mesh RC-WM-113 (replaces -117) Wireless Remote 3EM- Used Showroom Model w/o Battery Cover Option Avail For $75
SKU 00027
was $129.00
Save 23%
$99.00
E95 Scape Converter Kit w/Plug and #3133 Short Adapters
SKU 00118
$799.00
Replacement Remote Compatible with Bnkdt By Wayfair Blissful Nights, Ergomotion Sherwood Bedding, Or Sapphire Sleep Series Bases- New Alt VersionReplacement Remote Compatible with Bnkdt By Wayfair Blissful Nights, Ergomotion Sherwood Bedding, Or Sapphire Sleep Series Bases- New Alt Version
SKU 00306
$149.00
Ergomotion E4 Series WIRED 2 Piece Conversion Kit- See Pics- New Wireless White Remote & Control BoxErgomotion E4 Series WIRED 2 Piece Conversion Kit- See Pics- New Wireless White Remote & Control Box
SKU 00115
was $299.00
Save 10%
$269.00
Leggett & Platt Scape HF Massage And Certain Model MF 900 Remote- Physical Button OEM Version (original Glass Front Version Discontinued)Leggett & Platt Scape HF Massage And Certain Model MF 900 Remote- Physical Button OEM Version (original Glass Front Version Discontinued)
SKU 10088
was $149.00
Save 20%
$119.00
Ergomotion 5 Button 7 PIN (not 5) Corded Remote
SKU 10086
$159.00
Authentic Okin Replacement Power Cord Compatible with Beautyrest Luxury, Advance, or Smartmotion (Smart Motion) 1.0/2.0/3.0 Beds- 3 Piece Set Inc Input Cord
SKU 00048
was $109.00
Save 27%
$80.00
Reverie or Purple Powerbase 8Q Or 8X RC-WM-e53 Replacement Remote
SKU 00079
was $149.00
Save 9%
$135.00
Leggett & Platt Brio 30 Series Wired RemoteLeggett & Platt Brio 30 Series Wired Remote
SKU 00150
was $129.00
Save 8%
$119.00
Serta Motion Air Headboard Kit- Match Remote Picture 1st! (Remotes Sold Seperatly)Serta Motion Air Headboard Kit- Match Remote Picture 1st! (Remotes Sold Seperatly)
SKU 10100
was $149.00
Save 34%
$99.00
Conversion Kit 2 Piece for the Disc. Leggett & Platt S-Cape (scape) 1.0, 1.0+, 500, 700 or Simplicity 2.0 Remote - See Pictures. Inc. New Control Box, & Grey Remote w/Massage/Presets (No Pillow Tilt) Conversion Kit 2 Piece for the Disc. Leggett & Platt S-Cape (scape) 1.0, 1.0+, 500, 700 or Simplicity 2.0 Remote - See Pictures. Inc. New Control Box, & Grey Remote w/Massage/Presets (No Pillow Tilt)
SKU 00031
was $299.00
Save 17%
$249.00
Serta Motion Slim or Leggett 100 Series (New Black or Silver Version w/Light Original MFG) Replacement Remote
SKU 00008
was $179.00
Save 47%
$95.00
Reverie 3E Tech RC-WM-E57 Wireless (New Grey Version) RemoteReverie 3E Tech RC-WM-E57 Wireless (New Grey Version) Remote
SKU 00030
was $129.00
Save 23%
$99.00
Replacement Remote Compatible with Mattress Firm En300 MF300 Series Richmat 8 Button White Version See Pics (Not Black and White Leggett Stand Up or Leggett 7 Button Top Line) Works With ML190 /NL200Replacement Remote Compatible with Mattress Firm En300 MF300 Series Richmat 8 Button White Version See Pics (Not Black and White Leggett Stand Up or Leggett 7 Button Top Line) Works With ML190 /NL200
SKU 00278
was $159.00
Save 25%
$119.00
Replacement Remote Compatible with Mattress Firm 300 Series Topline 7 Button Phoenix Mecano Leggett Brand (Not Richmat 8 Button or Black/White Standup) Remote
SKU 00141
$229.00
Silver Replacement Remote Compatible With Leggett & Platt S-Cape (scape) 700 or Performance Remote w/pillow Tilt Buttons - See Second Picture for the One You Will ReceiveSilver Replacement Remote Compatible With Leggett & Platt S-Cape (scape) 700 or Performance Remote w/pillow Tilt Buttons - See Second Picture for the One You Will Receive
SKU 00033
$499.00
Reverie R600/ R650 Dual Tilt Wireless Rechargeable Remote LED Versions (or Value Non-led Version w/AAA Batteries for $129)
SKU 00069
$449.00
