6 Button BASIC MODEL Spare Remote (Must Also Have a Matching Conversion Kit)
$70.00
was $140.00 Save 50%
In stock: 17 available
This is the add-on listing for those who are buying or have already purchased our BASIC Universal Bed Remote Kit that we sell on this website. If you buy this later after you have installed our conversion kit, we will provide easy instructions to program the new remote (simply push two buttons on the remote)
Note; you can only pair one remote at a time per box OR pair one remote to two boxes if you have two of our conversion kit boxes per split king bed.
Wireless 8 Button (up, down head and foot, both up and down (same as flat), flashlight Remote
Each remote uses three AAA batteries
#ukit
Leggett & Platt Raven K-120 K120 And Richmat (not Linak) M120 White Remote
SKU 00036
was $149.00
Save 20%
$119.00
Ergomotion Softide 5100/8100 Remote- Discontinued… See Our New Conversion Kit Ergomotion Softide 5100/8100 Remote- Discontinued… See Our New Conversion Kit
SKU 00091
was $299.00
Save 10%
$269.00
Out of stock
Reverie 3E Mesh RC-WM-113 (replaces -117) Wireless Remote 3EM- Used Showroom Model w/o Battery Cover Option Avail For $75Reverie 3E Mesh RC-WM-113 (replaces -117) Wireless Remote 3EM- Used Showroom Model w/o Battery Cover Option Avail For $75
SKU 00027
was $129.00
Save 23%
$99.00
Adjusta-Magic E92 (e-92), Wired Contour Premier, and Replacement For Certain Wired Craft 1 Craftmatic Corded RemotesAdjusta-Magic E92 (e-92), Wired Contour Premier, and Replacement For Certain Wired Craft 1 Craftmatic Corded Remotes
SKU 00051
$399.00
Serta Motion Signature (New Version -Lift/Massage) RC-WM-E01 Replacement Remote
SKU 00038
was $140.00
Save 29%
$99.00
Authentic Okin Serta Motion Current Gen (Motion Perfect 2/3/4, Motion Essentials 3/4/5, iSeries, Air, Motion Plus, Motion Custom 2/3) Power Cord 3 Piece Set w Input Cord
SKU 00047
was $109.00
Save 27%
$80.00
Reverie RC-WM-E02 (New Version) Replacement Remote
SKU 00273
was $140.00
Save 15%
$119.00
Serta Pivot RC-HW-107 Corded Remote
SKU 00062
$169.00
Old Gen Nuflex and Serta Motion Perfect Massage Combination Splitter Cord (2 Sets to Sync/Split Four Massage Units Down To 2)
SKU 10080
$49.00
Conversion Kit Compatible with Homelegance or Hofish Adjustable Base Remote Conversion Kit Compatible with Homelegance or Hofish Adjustable Base Remote
SKU 00142
was $209.00
Save 5%
$199.00
Serta Perfect Position III New 3 Preset Version Remote
SKU 00040
was $299.00
Save 17%
$249.00
Ergomotion E6 Remote
SKU 00093
was $149.00
Save 20%
$119.00
Ergomotion Softide 8100 Or 8300 Remote- Discontinued- See Our New Conversion Kit
SKU 00111
$249.00
Out of stock
Okin Massage/Lumbar/Bluetooth/USB Motion Custom Control Box
SKU 10090
was $359.00
Save 3%
$349.00
Reverie 3E RC-WM-109 Wireless Remote
SKU 00026
$349.00
Out of stock
Silver Replacement Remote Compatible With Leggett & Platt S-Cape (scape) 700 or Performance Remote w/pillow Tilt Buttons - See Second Picture for the One You Will ReceiveSilver Replacement Remote Compatible With Leggett & Platt S-Cape (scape) 700 or Performance Remote w/pillow Tilt Buttons - See Second Picture for the One You Will Receive
SKU 00033
$499.00
Ergomotion E400 Series Remote- New Grey VersionErgomotion E400 Series Remote- New Grey Version
SKU 00219
was $149.00
Save 20%
$119.00
Whisper Power Replacement Remote Compatible with Certain Craftmatic Craft 1 Bases NEW GEN (MUST READ BELOW TO VERIFY MODEL- DONT JUST GO OFF THE PICTURE ON THIS ONE)Whisper Power Replacement Remote Compatible with Certain Craftmatic Craft 1 Bases NEW GEN (MUST READ BELOW TO VERIFY MODEL- DONT JUST GO OFF THE PICTURE ON THIS ONE)
SKU 00147
was $299.00
Save 7%
$279.00
Replacement White Wireless Remote Compatible with BedTech BT2500 Or Genesis (Bed Tech 2500) BasesReplacement White Wireless Remote Compatible with BedTech BT2500 Or Genesis (Bed Tech 2500) Bases
SKU 00251
was $159.00
Save 21%
$125.00
Adjusta-Magic E91 (e-91) Or Certain Craftmatic Classic Corded Remotes Replacement (see 2nd Picture)Adjusta-Magic E91 (e-91) Or Certain Craftmatic Classic Corded Remotes Replacement (see 2nd Picture)
SKU 00050
$299.00
Replacement Remote Compatible with Beautyrest Smartmotion 1.0 (New Value Grey Remote - See 2nd Picture For the Remote You’ll Get) Smart MotionReplacement Remote Compatible with Beautyrest Smartmotion 1.0 (New Value Grey Remote - See 2nd Picture For the Remote You’ll Get) Smart Motion
SKU 10089
was $149.00
Save 20%
$119.00
Replacement Compatible with Certain iDealbeds (ideal) 4i/c, Certain Craftmatic Legacy, or Leggett & Platt Style Plus, Williamsburg, Frankfurt K-132  18 Button Remote- Make Sure Your Buttons Match Replacement Compatible with Certain iDealbeds (ideal) 4i/c, Certain Craftmatic Legacy, or Leggett & Platt Style Plus, Williamsburg, Frankfurt K-132  18 Button Remote- Make Sure Your Buttons Match
SKU 00102
was $149.00
Save 20%
$119.00
Serta Perfect Position II BASIC ONE VIBE Old Generation E02 -K1, E91SS, New 2020 Raven Version (see Pics)Serta Perfect Position II BASIC ONE VIBE Old Generation E02 -K1, E91SS, New 2020 Raven Version (see Pics)
SKU 00146
$299.00
Replacement Remote Compatible with InKline White Noise 5 Button or Black 6 Button BasesReplacement Remote Compatible with InKline White Noise 5 Button or Black 6 Button Bases
SKU 10095
$149.00
Leggett & Platt Symmetry Richmat HJH37 Remote
SKU 00208
was $169.00
Save 36%
$109.00
Ergomotion E4 or Tempur (must Match Picture Exactly) WIRED 2 Piece Conversion Kit- New Wireless White Remote & Control Box, See PicsErgomotion E4 or Tempur (must Match Picture Exactly) WIRED 2 Piece Conversion Kit- New Wireless White Remote & Control Box, See Pics
SKU 00116
was $299.00
Save 43%
$169.00
Reverie 7t or R400/450 And R550 (non-Pillow Tilt) RC-WM-111 Wireless LED Remote- CHECK PROCESSOR BOX BEFORE ORDERINGReverie 7t or R400/450 And R550 (non-Pillow Tilt) RC-WM-111 Wireless LED Remote- CHECK PROCESSOR BOX BEFORE ORDERING
SKU 00067
$299.00
Replacement Remote Compatible with Rize Privia/Contemporary II/Avante Remote TRURC-N5 Compatible with New R4 Sealy - Discontinued, See Our New Universal Conversion Kit Replacement Remote Compatible with Rize Privia/Contemporary II/Avante Remote TRURC-N5 Compatible with New R4 Sealy - Discontinued, See Our New Universal Conversion Kit
SKU 00279
$299.00
Out of stock
Leggett And Platt D-Series (D Series) Converter Kit w/Plug, New Motors, and Adapters #4b8900Leggett And Platt D-Series (D Series) Converter Kit w/Plug, New Motors, and Adapters #4b8900
SKU 00143
$399.00
Replacement Remote Compatible with Tempurpedic Ergo Power or Extend Remote- 30 Day Return -Scratched but tested working perfectly fineReplacement Remote Compatible with Tempurpedic Ergo Power or Extend Remote- 30 Day Return -Scratched but tested working perfectly fine
SKU 00121
was $139.00
Save 22%
$109.00
Leggett and Platt Old Gen Raven (New 3 Preset Version) MR2T8TVZG-PM Or Series V/ V Elite E95 Scape Remote- Mr2tLeggett and Platt Old Gen Raven (New 3 Preset Version) MR2T8TVZG-PM Or Series V/ V Elite E95 Scape Remote- Mr2t
SKU 00105
$249.00
Adjusta-Magic Signature (New 3 Preset- See The 2nd Picture For The Remote You’ll Receive) Or Healthy Back Standard RemoteAdjusta-Magic Signature (New 3 Preset- See The 2nd Picture For The Remote You’ll Receive) Or Healthy Back Standard Remote
SKU 00037
$249.00
Replacement Remote Compatible with Mattress Firm 300 Series Topline 7 Button Phoenix Mecano Leggett Brand (Not Richmat 8 Button or Black/White Standup) Remote
SKU 00141
$229.00
Replacement Remote Compatible with Certain Model Craftmatic Legacy (l132 L-132 Series) Linak Bed Remotes- See Our Universal Conversion Kits
SKU 00043
$549.00
Replacement Remote Compatible with Mattress Firm 600 MF600 or Pillow Tilt Prodigy Basses (Make Sure You’re Getting The Correct One). Value Option Available For $260 Less.
SKU 00162
$499.00
Leggett & Platt Simplicity HF Remote- Physical Button OEM Version Also Avail For $119- Ask For Info
SKU 10107
was $189.00
Save 11%
$169.00
Reverie OSO O300T ERC143A01 (143A01 ) Wireless Remote 2.4 GHz
SKU 00090
was $139.00
Save 3%
$135.00
SKU 00058
was $249.00
Save 24%
$189.00
Richmat HJH55 (New Version- See Description) Compatible with Mattress 600 or 3000 Silver or Black, Enso, Classic Brands Innova NU203CB, PostureCloud- Works with Certain HJC18  Boxes - Mf3000Richmat HJH55 (New Version- See Description) Compatible with Mattress 600 or 3000 Silver or Black, Enso, Classic Brands Innova NU203CB, PostureCloud- Works with Certain HJC18  Boxes - Mf3000
SKU 00256
was $159.00
Save 21%
$125.00
Ergomotion E6+ Custom with Light Button (New Grey Version) Remote
SKU 10043
was $149.00
Save 7%
$139.00
Replacement Wireless Remote Compatible with BedTech X2 Corded Bases (btx2)
SKU 10085
was $159.00
Save 15%
$135.00
Reverie RC-WM-103, RC-WM-107, RC-WM-108 and Select Model RC-WM-103 Orthomattress Rcwm103 (buttons Must Match Exactly) ERC108 Replacement RemoteReverie RC-WM-103, RC-WM-107, RC-WM-108 and Select Model RC-WM-103 Orthomattress Rcwm103 (buttons Must Match Exactly) ERC108 Replacement Remote
SKU 00127
was $139.00
Save 29%
$99.00
Adjusta-Magic E90 (e-90) Corded Remote (New Version With A Few Extra Buttons)Adjusta-Magic E90 (e-90) Corded Remote (New Version With A Few Extra Buttons)
SKU 00049
$299.00
Reverie 5i, 5D, 7S, R400 or 450, or 4M Replacement Remote
SKU 00028
was $139.00
Save 29%
$99.00
Interflex Bronze Lifestyle Corded Remote (includes Cord)
SKU 00011
$349.00
Replacement Remote Compatible with Sealy Reflections (Reflexion) 4 R4 Remote TRURC-N5 Replacement Remote- Discontinued, See Our New Universal Conversion Kit
SKU 10109
$319.00
Out of stock
E95 Scape (S-cape) -Only Compatible with Certain Old Gen Craftmatic, and Certain Okimat or Hb310 Leggett Or Sealy Remotes
SKU 00100
was $299.00
Save 17%
$249.00
Mlily Adjustables MS300 Queen Size Dual Massage 750lb Capacity Adjustable Bed w/Free Shipping Special Order Eta 1 WkMlily Adjustables MS300 Queen Size Dual Massage 750lb Capacity Adjustable Bed w/Free Shipping Special Order Eta 1 Wk
SKU 00168
was $1 049.00
Save 5%
$999.99
Ergomotion E9 or Sherwood E9 Replacement RemoteErgomotion E9 or Sherwood E9 Replacement Remote
SKU 00217
$159.00
Reverie OSO O200 ERC014A01 Wired Remote
SKU 00220
was $149.00
Save 27%
$109.00
