Remote Generic Conversion Kit (Deluxe Model) Compatible with Legacy Tempur-pedic Ergo Premier / Grand -Used for a lost/broken remote. 9 Button Backlit Controls Movement/Presets- No Massage Tes 200
$219.00
was $339.00 Save 35%
In stock: 10 available
Because the original remotes and parts have been discontinued, replacing a lost or broken old generation Remote requires converting the electronics with one of these conversion kits which includes a new gen wireless remote to control your bed base. We have several different kits available per base depending on budget and required functionality. universal kit converts Tempurpedic Premier, and Grand bed base control boxes with an easy-to-install 3 step process and includes advanced features like presets, one touch flat, and customizable position buttons. Used to replace a lost or broken remote when there are no more replacements available or in budget (some termpurpedic bases had three massage motors but new gen control boxes only feature a head and foot massage so most just leave the 3rd unplugged or you can splice two together if you prefer)
Simply plug and play
Kit Includes:
1) Conversion Control Box with Wire Harnesses and a Power Supply Cable/Transformer Box
1) Wireless 9 button (or 13 depending on stock, the extra buttons would simply not work withoutan adapter massage upgrade cabble) Remote Control with flashlight and backlighting- Simply plug in the kit after it’s installed and the remote will work. Each remote uses three AAA batteries (included since we program this prior to shipping.). You can only have one remote paired with one box at a time. If you want to buy a 2nd remote to use as a backup, we sell them for $70 each.
Recommend
We also offer this remote and control box with the massage buttons and hookups for $70 more if you want. Just contact us if interested
Replacement Remote Compatible with Beautyrest Smartmotion 1.0 (New Value Grey Remote - See 2nd Picture For the Remote You’ll Get) Smart MotionReplacement Remote Compatible with Beautyrest Smartmotion 1.0 (New Value Grey Remote - See 2nd Picture For the Remote You’ll Get) Smart Motion
SKU 10089
was $149.00
Save 20%
$119.00
Replacement Remote Compatible with Rize Privia/Contemporary II/Avante Remote TRURC-N5 Compatible with New R4 Sealy - Discontinued, See Our New Universal Conversion Kit Replacement Remote Compatible with Rize Privia/Contemporary II/Avante Remote TRURC-N5 Compatible with New R4 Sealy - Discontinued, See Our New Universal Conversion Kit
SKU 00279
$299.00
Out of stock
Leggett & Platt Brio 40 Series Remote
SKU 00158
$169.00
Replacement Remote Compatible with Sleep Number Or Select Comfort Flex Fit And Flex Fit+ Plus (flexfit) DUAL VIBE Non-LCD Version (see Pics)
SKU 00154
was $249.00
Save 4%
$239.00
Replacement White Wireless Remote Compatible with BedTech BT2500 Or Genesis (Bed Tech 2500) BasesReplacement White Wireless Remote Compatible with BedTech BT2500 Or Genesis (Bed Tech 2500) Bases
SKU 00251
was $159.00
Save 21%
$125.00
Ergomotion Softide 2100 Remote 3 Piece Wireless Conversion Kit Ergomotion Softide 2100 Remote 3 Piece Wireless Conversion Kit
SKU 00114
was $299.00
Save 27%
$219.00
Adjusta-Magic Signature (New 3 Preset- See The 2nd Picture For The Remote You’ll Receive) Or Healthy Back Standard RemoteAdjusta-Magic Signature (New 3 Preset- See The 2nd Picture For The Remote You’ll Receive) Or Healthy Back Standard Remote
SKU 00037
$249.00
Leggett & Platt Symmetry Richmat HJH37 Remote
SKU 00208
was $169.00
Save 36%
$109.00
Conversion Kit 2 Piece for the Disc. Leggett & Platt S-Cape (scape) 1.0, 1.0+, 500, 700 or Simplicity 2.0 Remote - See Pictures. Inc. New Control Box, & Grey Remote w/Massage/Presets (No Pillow Tilt) Conversion Kit 2 Piece for the Disc. Leggett & Platt S-Cape (scape) 1.0, 1.0+, 500, 700 or Simplicity 2.0 Remote - See Pictures. Inc. New Control Box, & Grey Remote w/Massage/Presets (No Pillow Tilt)
SKU 00031
was $299.00
Save 17%
$249.00
Leggett And Platt D-Series (D Series) Converter Kit w/Plug, New Motors, and Adapters #4b8900Leggett And Platt D-Series (D Series) Converter Kit w/Plug, New Motors, and Adapters #4b8900
SKU 00143
$399.00
Leggett BASIC ONE VIBE Remote Compatible with Old Generation E02 -K1, E91SS, Certain Sealy, Sleep Comfort & Lifestyles Silhouette and Other Models (see Pics)Leggett BASIC ONE VIBE Remote Compatible with Old Generation E02 -K1, E91SS, Certain Sealy, Sleep Comfort & Lifestyles Silhouette and Other Models (see Pics)
SKU 00140
$299.00
Ergomotion 6 Button 5 PIN (not 7) Corded Remote
SKU 10087
$149.00
Headboard Kit Compatible with Mattress Firm 50 and 0776 series Leggett and Platt (Not Enso) All Sizes Headboard Brackets Set 4b9462Headboard Kit Compatible with Mattress Firm 50 and 0776 series Leggett and Platt (Not Enso) All Sizes Headboard Brackets Set 4b9462
SKU 00134
was $199.00
Save 30%
$139.00
Mlily NP2W, Richmat NU200 or NU202U, Lady Americana, Or Lucid L300 200 Wireless RemoteMlily NP2W, Richmat NU200 or NU202U, Lady Americana, Or Lucid L300 200 Wireless Remote
SKU 10047
was $159.00
Save 19%
$129.00
Leggett & Platt Promotion 2.0 Remote
SKU 00133
was $149.00
Save 20%
$119.00
Serta Pivot RC-HW-107 Corded Remote
SKU 00062
$169.00
Lifestyles S-cape E95 (New Scape Black Version) Value RemoteLifestyles S-cape E95 (New Scape Black Version) Value Remote
SKU 00020
$249.00
Linak Authentic OEM Power Cord Set Compatible with Serta Motion Essentials 2, Motion Slim, Leggett & Platt 100 Series II, S-cape, Renew Basic And Plus Series, & Beautyrest Simple Motion BasesLinak Authentic OEM Power Cord Set Compatible with Serta Motion Essentials 2, Motion Slim, Leggett & Platt 100 Series II, S-cape, Renew Basic And Plus Series, & Beautyrest Simple Motion Bases
SKU 00053
was $169.00
Save 47%
$89.00
Leggett & Platt Scape HF Massage And Certain Model MF 900 Remote- Physical Button OEM Version (original Glass Front Version Discontinued)Leggett & Platt Scape HF Massage And Certain Model MF 900 Remote- Physical Button OEM Version (original Glass Front Version Discontinued)
SKU 10088
was $149.00
Save 20%
$119.00
Leggett And Platt Series 1 Lifestyle Corded Remote (includes Cord)
SKU 10049
$289.00
Leggett and Platt Old Gen Raven (New 3 Preset Version) MR2T8TVZG-PM Or Series V/ V Elite E95 Scape Remote- Mr2tLeggett and Platt Old Gen Raven (New 3 Preset Version) MR2T8TVZG-PM Or Series V/ V Elite E95 Scape Remote- Mr2t
SKU 00105
$249.00
Serta Motion Essentials II (2nd) Gen hb12012-00 M-120 Linak Wired Remote (Alt black version avail. for $60 less!)Serta Motion Essentials II (2nd) Gen hb12012-00 M-120 Linak Wired Remote (Alt black version avail. for $60 less!)
SKU 00002
was $179.00
Save 11%
$159.00
Out of stock
Replacement Remote Compatible with Ashley Sierra Sleep M9X9 Or Black Moto Sleep ZG3 X9 Bases
SKU 00061
was $299.00
Save 17%
$249.00
Serta/Ergomotion Motion Essentials 1 (1st), 3 (III 3rd), 4 (IV 4th) and 5 (V 5th), 6 (VI) BaseLogic, iSeries Headboard Brackets Set (All Sizes)Serta/Ergomotion Motion Essentials 1 (1st), 3 (III 3rd), 4 (IV 4th) and 5 (V 5th), 6 (VI) BaseLogic, iSeries Headboard Brackets Set (All Sizes)
SKU 00046
was $129.00
Save 31%
$89.00
Leg Kit Compatible with Serta Motion Essentials/iSeries (all Gens But The 2nd)/Perfect, Certain Blissful Nights, and Sealy or Beautyrest New Gen 3-9” (4 Legs Total) 1st GenLeg Kit Compatible with Serta Motion Essentials/iSeries (all Gens But The 2nd)/Perfect, Certain Blissful Nights, and Sealy or Beautyrest New Gen 3-9” (4 Legs Total) 1st Gen
SKU 00270
was $99.00
Save 20%
$79.00
Leggett & Platt Sunrise Remote
SKU 00077
$159.00
Replacement Remote Compatible with Sealy Premier X-10 (x10) E97 Dual Vibe RemoteReplacement Remote Compatible with Sealy Premier X-10 (x10) E97 Dual Vibe Remote
SKU 00125
$599.00
Old Gen Nuflex and Serta Motion Perfect Massage Combination Splitter Cord (2 Sets to Sync/Split Four Massage Units Down To 2)
SKU 10080
$49.00
Whisper Power Replacement Remote Compatible with Certain Craftmatic Craft 1 Bases NEW GEN (MUST READ BELOW TO VERIFY MODEL- DONT JUST GO OFF THE PICTURE ON THIS ONE)Whisper Power Replacement Remote Compatible with Certain Craftmatic Craft 1 Bases NEW GEN (MUST READ BELOW TO VERIFY MODEL- DONT JUST GO OFF THE PICTURE ON THIS ONE)
SKU 00147
was $299.00
Save 7%
$279.00
Serta Motion Essentials 6th Gen Wireless Remote
SKU 00004
$149.00
Ergomotion Pure Contour Gold Remote
SKU 00167
$159.00
Reverie RC-WM-E02 (New Version) Replacement Remote
SKU 00273
was $140.00
Save 15%
$119.00
Leggett & Platt Brio 60 Series/ B-122-60 Bello Remote
SKU 00159
$169.00
Leggett & Platt Prodigy 1.0 Remote Conversion Kit w Massage Functionality (No Presets or Limits- The Old Remote Is Discontinued) Also Talk to Us About Kits w/o Massage For LessLeggett & Platt Prodigy 1.0 Remote Conversion Kit w Massage Functionality (No Presets or Limits- The Old Remote Is Discontinued) Also Talk to Us About Kits w/o Massage For Less
SKU 00083
was $279.00
Save 11%
$249.00
Replacement White Wireless Remote Compatible with  BedTech BT4000 (Bed Tech) Bases- Use The 3000 If You Don’t Need Pillow TiltReplacement White Wireless Remote Compatible with  BedTech BT4000 (Bed Tech) Bases- Use The 3000 If You Don’t Need Pillow Tilt
SKU 00250
was $159.00
Save 9%
$145.00
Replacement 3pc Conversion Kit w Wireless Remote Compatible with the Discontinued BedTech or Moto Sleep (Motto Sleep) CH13 ZG XSF300 RemoteReplacement 3pc Conversion Kit w Wireless Remote Compatible with the Discontinued BedTech or Moto Sleep (Motto Sleep) CH13 ZG XSF300 Remote
SKU 00238
was $399.00
Save 38%
$249.00
Authentic Okin Serta Motion Current Gen (Motion Perfect 2/3/4, Motion Essentials 3/4/5, iSeries, Air, Motion Plus, Motion Custom 2/3) Power Cord 3 Piece Set w Input Cord
SKU 00047
was $109.00
Save 27%
$80.00
Leggett & Platt S-Cape (scape) Version 2.0 or Simplicity 3.0 Remote
SKU 00075
was $369.00
Save 19%
$299.00
Out of stock
SKU 00058
was $249.00
Save 24%
$189.00
Original White Reverie 3E Wired RC-HW-105 or RC-HW-106 Corded Remote- Use Promo Code “TES” To Save $40 For The Black New Gen Option Shown In The 2nd Picture Original White Reverie 3E Wired RC-HW-105 or RC-HW-106 Corded Remote- Use Promo Code “TES” To Save $40 For The Black New Gen Option Shown In The 2nd Picture
SKU 00025
$199.00
Out of stock
Richmat HJH55 (New Version- See Description) Compatible with Mattress 600 or 3000 Silver or Black, Enso, Classic Brands Innova NU203CB, PostureCloud- Works with Certain HJC18  Boxes - Mf3000Richmat HJH55 (New Version- See Description) Compatible with Mattress 600 or 3000 Silver or Black, Enso, Classic Brands Innova NU203CB, PostureCloud- Works with Certain HJC18  Boxes - Mf3000
SKU 00256
was $159.00
Save 21%
$125.00
Replacement Remote Compatible with Tempurpedic Ergo Power or Extend Remote- 30 Day Return -Scratched but tested working perfectly fineReplacement Remote Compatible with Tempurpedic Ergo Power or Extend Remote- 30 Day Return -Scratched but tested working perfectly fine
SKU 00121
was $139.00
Save 22%
$109.00
Ergomotion Quest 2.0 Adjustable Remote
SKU 00287
was $199.00
Save 15%
$169.00
Adjusta-Magic E90 (e-90) Corded Remote (New Version With A Few Extra Buttons)Adjusta-Magic E90 (e-90) Corded Remote (New Version With A Few Extra Buttons)
SKU 00049
$299.00
Replacement Remote Compatible with Ashley Sierra Sleep M9x5 (X5)(not X7) For a less Expensive Option on Future Replacements, See our Conversion Kit
SKU 00056
was $209.00
Save 14%
$179.00
Replacement Power Cord Compatible with certain model Sealy and Tempurpedic Extend, Ergo & Ease 1.0/2.0/3.0 - 3 Piece Set
SKU 00042
was $109.00
Save 13%
$95.00
Scape Converter Kit w/Plug and #7453 Adapters. Works for the Interflex Titanium, Gold, and certain Englander Or Orthomatic remotesScape Converter Kit w/Plug and #7453 Adapters. Works for the Interflex Titanium, Gold, and certain Englander Or Orthomatic remotes
SKU 00108
$849.00
Leggett and Platt Wallhugger S-Cape (New Black Version- Wall Hugger) Old Gen E-95 WRLS 2 VIB Raven RemoteLeggett and Platt Wallhugger S-Cape (New Black Version- Wall Hugger) Old Gen E-95 WRLS 2 VIB Raven Remote
SKU 00019
was $349.00
Save 29%
$249.00
Replacement Remote Compatible with Sleep Number/ Select Comfort 12 Button Flexfit 3 (Flex Fit) 360 Version
SKU 00309
was $199.00
Save 30%
$139.00
Serta Perfect Position II New 3 Preset Version Remote
SKU 00021
was $279.00
Save 11%
$249.00
