Remote Conversion Kit (BASIC Model w/Massage)Compatible with Sealy Reflection 4 or Stearns Reflections (Reflexion) 7 -Replaces a lost/broken remote. Backlit Controls Motors/Massage-NO PRESETS
$249.00
was $399.00 Save 38%
In stock: 6 available
This kit converts Sealy Reflection 4 and Stearns and Foster Reflections (Reflexion) 7 bed base control boxes with an easy-to-install plug in unit and includes a new wireless remote to control your bed base with advanced features like backlit lighting, a flashlight, and massage with three intensities and wave modes. Used to replace a lost or broken remote when there are no more replacements available or in budget. NOTE: The presets will not work on this remote. We feature another kit for $70 more that will allow that functionality.
This kit includes 4 custom ports to allow you to simply plug in your existing motors from your existing wiring.
Kit Includes:
1) Conversion Control Box and a Power Supply Cable/Transformer Box - Simply plug in your existing cords and plug in the unit!
1) Wireless Remote Control with flashlight and backlighting- Simply plug in the kit after it’s installed and the remote will work. Each remote uses three AAA batteries (included since we program this prior to shipping.). You can only have one remote paired with one box at a time. If you want to buy a 2nd remote to use as a backup, we sell them for $70 each.
A Surge Protector. This can be a power strip or single box, but its important to make sure the words "Surge Protector" or some variant are on the unit. Usually you can buy both at walmart but the power strip without surge protection is a dollar or two less. Here is a combo strip/protector for $10 on Amazon: https://www.amazon.com/dp/B08466BVJV?ref_=cm_sw_r_...
We also offer this remote and control box without the massage buttons or with presets.
Remote Replacement Compatible with S-Cape E95 (E-95), Adjusta-Sleep, Certain Old Gen Craftmatic, WRLS 2 VIB, and Certain Contour Premier, Sleep Comfort, Eurosleep, Simmons Series 2000, or Craft 1Remote Replacement Compatible with S-Cape E95 (E-95), Adjusta-Sleep, Certain Old Gen Craftmatic, WRLS 2 VIB, and Certain Contour Premier, Sleep Comfort, Eurosleep, Simmons Series 2000, or Craft 1
SKU 00018
$349.00
Leggett & Platt Signature, Simplicity 2.0, or certain 100 Or 300 Brio Series Remote- Disc. Model, See PicsLeggett & Platt Signature, Simplicity 2.0, or certain 100 Or 300 Brio Series Remote- Disc. Model, See Pics
SKU 00034
$179.00
Old Gen Nuflex and Serta Motion Perfect Massage Combination Splitter Cord (2 Sets to Sync/Split Four Massage Units Down To 2)
SKU 10080
$49.00
Adjusta-Magic E90 (e-90) Corded Remote (New Version With A Few Extra Buttons)Adjusta-Magic E90 (e-90) Corded Remote (New Version With A Few Extra Buttons)
SKU 00049
$299.00
Conversion Kit 2 Piece for the Disc. Leggett & Platt S-Cape (scape) 1.0, 1.0+, 500, 700 or Simplicity 2.0 Remote - See Pictures. Inc. New Control Box, & Grey Remote w/Massage/Presets (No Pillow Tilt) Conversion Kit 2 Piece for the Disc. Leggett & Platt S-Cape (scape) 1.0, 1.0+, 500, 700 or Simplicity 2.0 Remote - See Pictures. Inc. New Control Box, & Grey Remote w/Massage/Presets (No Pillow Tilt)
SKU 00031
was $299.00
Save 17%
$249.00
RC-WM-101 Replacement Remote Compatible with Tempurpedic Ergo Advanced (New Gray RC-WM-119 Version) Remote
SKU 00022
was $149.00
Save 20%
$119.00
Replacement Wireless Remote Compatible with Serta or Beautyrest Motion Air (New Black Version) BasesReplacement Wireless Remote Compatible with Serta or Beautyrest Motion Air (New Black Version) Bases
SKU 10057
$159.00
Serta Perfect Position III New 3 Preset Version Remote
SKU 00040
was $299.00
Save 17%
$249.00
Reverie 3E Mesh RC-WM-113 (replaces -117) Wireless Remote 3EM- Used Showroom Model w/o Battery Cover Option Avail For $75Reverie 3E Mesh RC-WM-113 (replaces -117) Wireless Remote 3EM- Used Showroom Model w/o Battery Cover Option Avail For $75
SKU 00027
was $129.00
Save 23%
$99.00
Reverie R600/ R650 Dual Tilt Wireless Rechargeable Remote LED Versions (or Value Non-led Version w/AAA Batteries for $129)
SKU 00069
$449.00
Serta Motion Essentials 6th Gen Wireless Remote
SKU 00004
$149.00
Leggett & Platt Simplicity HF Remote- Physical Button OEM Version Also Avail For $119- Ask For Info
SKU 10107
was $189.00
Save 11%
$169.00
Replacement Wireless Remote Compatible with  Beautyrest Advance Motion Bases- Value Remote w More Functionality Available For $40 Less
SKU 00144
was $179.00
Save 11%
$159.00
Leggett & Platt Premier Series Remote
SKU 00216
$249.00
Richmat HJH55 (New Version- see pics) Remote Compatible with Classic Brands As Seen On Wayfair or Nectar- Works With Certain HJC18 Massage Control Boxes as Shown Richmat HJH55 (New Version- see pics) Remote Compatible with Classic Brands As Seen On Wayfair or Nectar- Works With Certain HJC18 Massage Control Boxes as Shown
SKU 10096
was $159.00
Save 25%
$119.00
Replacement Wireless Remote Compatible with  Beautyrest Simple Motion Beds (New Black With Light button Non Logo Version)
SKU 00276
was $135.00
Save 12%
$119.00
Linak Authentic OEM Power Cord Set Compatible with Serta Motion Essentials 2, Motion Slim, Leggett & Platt 100 Series II, S-cape, Renew Basic And Plus Series, & Beautyrest Simple Motion BasesLinak Authentic OEM Power Cord Set Compatible with Serta Motion Essentials 2, Motion Slim, Leggett & Platt 100 Series II, S-cape, Renew Basic And Plus Series, & Beautyrest Simple Motion Bases
SKU 00053
was $169.00
Save 47%
$89.00
Reverie 3E RC-WM-109 Wireless Remote
SKU 00026
$349.00
Mlily Adjustables MS300 Queen Size Dual Massage 750lb Capacity Adjustable Bed w/Free Shipping Special Order Eta 1 WkMlily Adjustables MS300 Queen Size Dual Massage 750lb Capacity Adjustable Bed w/Free Shipping Special Order Eta 1 Wk
SKU 00168
was $1 049.00
Save 5%
$999.99
Leggett and Platt Old Gen Raven (New 3 Preset Version) MR2T8TVZG-PM Or Series V/ V Elite E95 Scape Remote- Mr2tLeggett and Platt Old Gen Raven (New 3 Preset Version) MR2T8TVZG-PM Or Series V/ V Elite E95 Scape Remote- Mr2t
SKU 00105
$249.00
Replacement Remote Compatible with Rize Privia/Contemporary II/Avante Remote TRURC-N5 Compatible with New R4 Sealy - Discontinued, See Our New Universal Conversion Kit Replacement Remote Compatible with Rize Privia/Contemporary II/Avante Remote TRURC-N5 Compatible with New R4 Sealy - Discontinued, See Our New Universal Conversion Kit
SKU 00279
$299.00
Out of stock
Leggett & Platt Brio 40 Series Remote
SKU 00158
$169.00
Replacement Remote Compatible with Adjusta-Magic Signature BASIC ONE VIBE Old Generation E02 -K1, E91SS, Certain Sleep Comfort & Lifestyles Silhouette (see Pics)
SKU 00151
$299.00
Leggett and Platt MR2T8TVZG with Massage Speed Scape Raven Remote- Don’t Just Match Remotes- Also Check Your Learn Button Before Ordering- MR2t TVLeggett and Platt MR2T8TVZG with Massage Speed Scape Raven Remote- Don’t Just Match Remotes- Also Check Your Learn Button Before Ordering- MR2t TV
SKU 10044
$299.00
Serta Perfect Position II BASIC ONE VIBE Old Generation E02 -K1, E91SS, New 2020 Raven Version (see Pics)Serta Perfect Position II BASIC ONE VIBE Old Generation E02 -K1, E91SS, New 2020 Raven Version (see Pics)
SKU 00146
$299.00
Replacement Power Cord Compatible with certain model Sealy and Tempurpedic Extend, Ergo & Ease 1.0/2.0/3.0 - 3 Piece Set
SKU 00042
was $109.00
Save 13%
$95.00
Power Cord Compatible with Certain Model Leggett 50 Series, and Matt Firm 300/600 3 Piece Set
SKU 00181
was $109.00
Save 9%
$99.00
Learn Cord For Certain Linak Bases
SKU 00275
$99.00
Ergomotion E6 Remote
SKU 00093
was $149.00
Save 20%
$119.00
Leggett and Platt Replacement Remote Compatible with Old Blue Craftmatic, or Sealy Swingline Blue Wired Remote (Swing Line) - New Black VersionLeggett and Platt Replacement Remote Compatible with Old Blue Craftmatic, or Sealy Swingline Blue Wired Remote (Swing Line) - New Black Version
SKU 00129
was $149.00
Save 20%
$119.00
Reverie 7t or R400/450 And R550 (non-Pillow Tilt) RC-WM-111 Wireless LED Remote- CHECK PROCESSOR BOX BEFORE ORDERINGReverie 7t or R400/450 And R550 (non-Pillow Tilt) RC-WM-111 Wireless LED Remote- CHECK PROCESSOR BOX BEFORE ORDERING
SKU 00067
$299.00
MLily NU400 or NP2W+ Remote Control -Works With HJC18 And HJH55 Massage Control BoxesMLily NU400 or NP2W+ Remote Control -Works With HJC18 And HJH55 Massage Control Boxes
SKU 10048
was $159.00
Save 9%
$145.00
Replacement Remote Compatible with Ashley Sierra Sleep M9X9 Or Black Moto Sleep ZG3 X9 Bases
SKU 00061
was $299.00
Save 17%
$249.00
Leggett & Platt S-Cape (scape) 1.0+, Performance +, or Matt. Firm 500 Series Remote- DISCONTINUED- You’ll Receive The Version with a Light Button And Non Functioning Pillow Tilt Buttons (700 Series)Leggett & Platt S-Cape (scape) 1.0+, Performance +, or Matt. Firm 500 Series Remote- DISCONTINUED- You’ll Receive The Version with a Light Button And Non Functioning Pillow Tilt Buttons (700 Series)
SKU 00032
$499.00
Remote Compatible with Rize Beds- Discontinued -Contemporary/Relaxer Remote TRUN2-FM Replacement- See Our Conversion Kit
SKU 00261
$299.00
Out of stock
Richmat HJH55 (New Version- See Description) Compatible with Mattress 600 or 3000 Silver or Black, Enso, Classic Brands Innova NU203CB, PostureCloud- Works with Certain HJC18  Boxes - Mf3000Richmat HJH55 (New Version- See Description) Compatible with Mattress 600 or 3000 Silver or Black, Enso, Classic Brands Innova NU203CB, PostureCloud- Works with Certain HJC18  Boxes - Mf3000
SKU 00256
was $159.00
Save 21%
$125.00
Serta Perfect Position II New 3 Preset Version Remote
SKU 00021
was $279.00
Save 11%
$249.00
Interflex Bronze Lifestyle Corded Remote (includes Cord)
SKU 00011
$349.00
Scape and Adjusta-Magic E94 (e-94) Or Wireless Craft 1 Rectangle Remote Converter Kit w/Remote And PlugScape and Adjusta-Magic E94 (e-94) Or Wireless Craft 1 Rectangle Remote Converter Kit w/Remote And Plug
SKU 00110
$849.00
Replacement Remote Compatible with Sleep Number/ Select Comfort 12 Button Flexfit 3 (Flex Fit) 360 Version
SKU 00309
was $199.00
Save 30%
$139.00
Silver Replacement Remote Compatible With Leggett & Platt S-Cape (scape) 700 or Performance Remote w/pillow Tilt Buttons - See Second Picture for the One You Will ReceiveSilver Replacement Remote Compatible With Leggett & Platt S-Cape (scape) 700 or Performance Remote w/pillow Tilt Buttons - See Second Picture for the One You Will Receive
SKU 00033
$499.00
Serta Motion Essentials II (2nd) Gen hb12012-00 M-120 Linak Wired Remote (Alt black version avail. for $60 less!)Serta Motion Essentials II (2nd) Gen hb12012-00 M-120 Linak Wired Remote (Alt black version avail. for $60 less!)
SKU 00002
was $179.00
Save 11%
$159.00
Out of stock
Leggett & Platt S-Cape (scape) Version 2.0 or Simplicity 3.0 Remote
SKU 00075
was $369.00
Save 19%
$299.00
Out of stock
Whisper Power Replacement Remote Compatible with Certain Craftmatic Craft 1 Bases NEW GEN (MUST READ BELOW TO VERIFY MODEL- DONT JUST GO OFF THE PICTURE ON THIS ONE)Whisper Power Replacement Remote Compatible with Certain Craftmatic Craft 1 Bases NEW GEN (MUST READ BELOW TO VERIFY MODEL- DONT JUST GO OFF THE PICTURE ON THIS ONE)
SKU 00147
was $299.00
Save 7%
$279.00
Adjustamagic Leggett E-90, E-91, or E-92, - New Gen Cord Replacement (e91, e92, e90)Adjustamagic Leggett E-90, E-91, or E-92, - New Gen Cord Replacement (e91, e92, e90)
SKU 10099
$55.00
Adjustamagic, Interflex Wired 2 Button, or Leggett 1st Series, Bronze, Silver, or Gold 10 Foot Cord Replacement OnlyAdjustamagic, Interflex Wired 2 Button, or Leggett 1st Series, Bronze, Silver, or Gold 10 Foot Cord Replacement Only
SKU 10055
$55.00
Replacement Remote Compatible w Profile DC, Series III, Innova, Sleep Number Corded, or 1st Gen Brio Replacement Corded Remote - (Use Promo Code “scratch” To Save $10 Off A Slightly Scratched ModelReplacement Remote Compatible w Profile DC, Series III, Innova, Sleep Number Corded, or 1st Gen Brio Replacement Corded Remote - (Use Promo Code “scratch” To Save $10 Off A Slightly Scratched Model
SKU 10053
was $129.00
Save 8%
$119.00
Reverie 5i, 5D, 7S, R400 or 450, or 4M Replacement Remote
SKU 00028
was $139.00
Save 29%
$99.00
Replacement Remote Compatible with InKline White Noise 5 Button or Black 6 Button BasesReplacement Remote Compatible with InKline White Noise 5 Button or Black 6 Button Bases
SKU 10095
$149.00
Replacement Remote Compatible with Mattress Firm 600 MF600 or Pillow Tilt Prodigy Basses (Make Sure You’re Getting The Correct One). Value Option Available For $260 Less.
SKU 00162
$499.00
