This universal kit converts old generation 4 pin motors on wireless bed base control boxes and includes a new wireless remote to control your bed base with advanced features like backlit buttons, all down and up, and a flashlight. Used to replace a lost or broken remote when there are no more replacements available or in budget or to upgrade a basic remote with only a few buttons.
This kit includes all the wiring and ports needed to make your conversion. Simply unplug your two motors (head and foot) from the existing control box under your bed and plug them into our new unit. All of the remotes showed above used control boxes with four pin connection ports. As long as your remote matches our original picture, this kit will work. (See above picture). Total installation should take no more than 5 minutes but it does require tipping the bed on its side or sliding under the bed to secure the new unit once plugged in. Kit Includes:
1) Wireless Remote Control with flashlight and backlighting (due to supply issues, you will receive a remote that will also include a Flat and Memory button which will not work due to the conversion. If you want to have one touch presets and memory functionality, we sell a deluxe http://bitly.ws/P6tQ and premium with massage http://bitly.ws/P6uo version of this same kit.
Simply plug in the kit after it’s installed and the remote will work. Each remote uses three AAA batteries (included since we program this prior to shipping.). You can only have one remote paired with one box at a time or if you reach out to us we can pair one remote to two boxes if you want to synchronize your king split base. If you want to buy a 2nd remote to use as a backup, we sell them for $70 each.
Also, you can contact us at orders@saltlakemattress.com or 866-448-6879 (text is great) with questions
