Conversion Kit (Non-Massage Deluxe Model) Compatible with Reverie, Rize, Privia, Sealy Reflection (Reflexion) R4/R7, Craftmatic or Customatic 4 Pin Bases- Replace lost/broken remotes. 9 Button Backlit
+7
$219.00
was $349.00 Save 37%
In stock: 5 available
This universal kit converts old generation 4 pin motors on wireless bed base control boxes and includes a new wireless remote to control your bed base with advanced features like presets, one touch flat, and a flashlight. Used to replace a lost or broken remote when there are no more replacements available or in budget or to upgrade a basic remote with only a few buttons.
This kit includes all the wiring and ports needed to make your conversion. Simply unplug your two motors (head and foot) from the existing control box under your bed and plug them into our new unit. All of the remotes showed above used control boxes with four pin connection ports. As long as your remote matches our original picture, this kit will work. (See above picture). This kit does not operate massage although we sell that option for an upgrade.
Total installation should take no more than 5 minutes but it does require tipping the bed on its side or sliding under the bed to secure the new unit once plugged in. Kit Includes:
1) Wireless 9 Button Remote Control with flashlight and backlighting (The massage buttons will not work on this unit but all others will! If you want to have massage functionality, you must upgrade to our other unit)- Simply plug in the kit after it’s installed and the remote will work. Each remote uses three AAA batteries (included since we program this prior to shipping.). You can only have one remote paired with one box at a time or if you reach out to us we can pair one remote to two boxes if you want to synchronize your king split base. If you want to buy a 2nd remote to use as a backup, we sell them for $70 each.
We also offer this kit with two massage ports to allow you to access your massage and intensity/pulse features for $349:
https://www.adjustablebedremotes.com/#!/Remote-Conversion-Kit-Deluxe-Model-for-Sealy-Reflection-4-and-Stearns-Reflections-Reflexion-7-Replaces-a-lost-broken-remote-13-Button-Backlit-Controls-Movement-Massage-Presets/p/471642455
Also, you can contact us at orders@saltlakemattress.com or 866-448-6879 (text is great) with questions
Replacement Remote Compatible with Sealy BASIC ONE VIBE E97 Old Generation Single Vibe (see Pics and Massage Info Below)
SKU 00124
$299.00
Leggett & Platt Scape HF Massage And Certain Model MF 900 Remote- Physical Button OEM Version (original Glass Front Version Discontinued)Leggett & Platt Scape HF Massage And Certain Model MF 900 Remote- Physical Button OEM Version (original Glass Front Version Discontinued)
SKU 10088
was $149.00
Save 20%
$119.00
Replacement Remote Compatible with Ashley Sierra Sleep M9x5 (X5)(not X7) For a less Expensive Option on Future Replacements, See our Conversion Kit
SKU 00056
was $209.00
Save 14%
$179.00
Ergomotion Softide 2100 WIRELESS Remote - NEW 2 Pc Conversion kit - See attachedErgomotion Softide 2100 WIRELESS Remote - NEW 2 Pc Conversion kit - See attached
SKU 00113
was $299.00
Save 27%
$219.00
Leggett & Platt Signature, Simplicity 2.0, or certain 100 Or 300 Brio Series Remote- Disc. Model, See PicsLeggett & Platt Signature, Simplicity 2.0, or certain 100 Or 300 Brio Series Remote- Disc. Model, See Pics
SKU 00034
$179.00
Reverie OSO O200 ERC014A01 Wired Remote
SKU 00220
was $149.00
Save 27%
$109.00
Replacement Remote Compatible with Mattress Firm 50 II Series, Bas-X HC, K-110 or 0776 Somos Bed (Somosbeds) 200 Series Leggett Corded Remote
SKU 00099
was $159.00
Save 38%
$99.00
Richmat 7 Button HJH13D Wireless Remote Compatible with FlexEzz, Enso, Metro Mattress, Bedtech, and X5 iLift by RichmatRichmat 7 Button HJH13D Wireless Remote Compatible with FlexEzz, Enso, Metro Mattress, Bedtech, and X5 iLift by Richmat
SKU 00252
was $159.00
Save 28%
$115.00
Replacement Remote Compatible with Certain Model Craftmatic Legacy (l132 L-132 Series) Linak Bed Remotes- See Our Universal Conversion Kits
SKU 00043
$549.00
Replacement Remote Compatible with Beautyrest Smartmotion 1.0 (New Value Grey Remote - See 2nd Picture For the Remote You’ll Get) Smart MotionReplacement Remote Compatible with Beautyrest Smartmotion 1.0 (New Value Grey Remote - See 2nd Picture For the Remote You’ll Get) Smart Motion
SKU 10089
was $149.00
Save 20%
$119.00
Replacement Remote Compatible with Rize Privia/Contemporary II/Avante Remote TRURC-N5 Compatible with New R4 Sealy - Discontinued, See Our New Universal Conversion Kit Replacement Remote Compatible with Rize Privia/Contemporary II/Avante Remote TRURC-N5 Compatible with New R4 Sealy - Discontinued, See Our New Universal Conversion Kit
SKU 00279
$299.00
Out of stock
Leggett and Platt MR2T8TVZG with Massage Speed Scape Raven Remote- Don’t Just Match Remotes- Also Check Your Learn Button Before Ordering- MR2t TVLeggett and Platt MR2T8TVZG with Massage Speed Scape Raven Remote- Don’t Just Match Remotes- Also Check Your Learn Button Before Ordering- MR2t TV
SKU 10044
$299.00
Old Gen Nuflex and Serta Motion Perfect Massage Combination Splitter Cord (2 Sets to Sync/Split Four Massage Units Down To 2)
SKU 10080
$49.00
Serta Motion Perfect, Essentials (Not 2nd Gen), Custom, Plus, Air, New Gen Ergomotion, Ease/Tempur, Matt Firm 50/okin 300/600 & Richmat/Reverie 29v Power Box/Plug (Doesn’t inc. input cord)
SKU 00132
was $99.00
Save 30%
$69.00
Leggett And Platt Softline Pro-Motion, Swingline, Sleep Number Flex Fit Wired, Series III, or 1st Gen Brio (new Black And White Version- Top Right Pic)
SKU 00073
was $129.00
Save 8%
$119.00
Authentic Okin Serta Motion Current Gen (Motion Perfect 2/3/4, Motion Essentials 3/4/5, iSeries, Air, Motion Plus, Motion Custom 2/3) Power Cord 3 Piece Set w Input Cord
SKU 00047
was $109.00
Save 27%
$80.00
Replacement Wireless Remote Compatible with BedTech BT3000 and Bt3000LP and Certain Richmat Flexeez Easy Rest Revive Living Spaces White Wireless Remote (Bed Tech 3000)Replacement Wireless Remote Compatible with BedTech BT3000 and Bt3000LP and Certain Richmat Flexeez Easy Rest Revive Living Spaces White Wireless Remote (Bed Tech 3000)
SKU 00249
was $159.00
Save 25%
$119.00
Serta Motion Plus Headboard Brackets Set (All Sizes) make sure to match the picture of the remote on the second pageSerta Motion Plus Headboard Brackets Set (All Sizes) make sure to match the picture of the remote on the second page
SKU 00094
was $119.00
Save 17%
$99.00
E95 Scape (S-cape) -Only Compatible with Certain Old Gen Craftmatic, and Certain Okimat or Hb310 Leggett Or Sealy Remotes
SKU 00100
was $299.00
Save 17%
$249.00
Leggett And Platt Series II Silver Corded Remote (Must Look The Same -includes Cord)
SKU 10050
$399.00
Richmat HJH55 (New Version- See Description) Compatible with Mattress 600 or 3000 Silver or Black, Enso, Classic Brands Innova NU203CB, PostureCloud- Works with Certain HJC18  Boxes - Mf3000Richmat HJH55 (New Version- See Description) Compatible with Mattress 600 or 3000 Silver or Black, Enso, Classic Brands Innova NU203CB, PostureCloud- Works with Certain HJC18  Boxes - Mf3000
SKU 00256
was $159.00
Save 21%
$125.00
Ergomotion Softide 5100/8100 Remote- Discontinued… See Our New Conversion Kit Ergomotion Softide 5100/8100 Remote- Discontinued… See Our New Conversion Kit
SKU 00091
was $299.00
Save 10%
$269.00
Out of stock
Replacement Remote Compatible with Sealy Corded Old Gen RemoteReplacement Remote Compatible with Sealy Corded Old Gen Remote
SKU 00284
was $139.00
Save 14%
$119.00
Leggett & Platt S-Cape (scape) 1.0+, Performance +, or Matt. Firm 500 Series Remote- DISCONTINUED- You’ll Receive The Version with a Light Button And Non Functioning Pillow Tilt Buttons (700 Series)Leggett & Platt S-Cape (scape) 1.0+, Performance +, or Matt. Firm 500 Series Remote- DISCONTINUED- You’ll Receive The Version with a Light Button And Non Functioning Pillow Tilt Buttons (700 Series)
SKU 00032
$499.00
Replacement 2 Piece Conversion Kit Compatible w Simmons Nuflex or Softide 5100/8100 (no Lumbar Support) 6 Pin - New Grey Version Remote- Replaces Lost or Broken RemoteReplacement 2 Piece Conversion Kit Compatible w Simmons Nuflex or Softide 5100/8100 (no Lumbar Support) 6 Pin - New Grey Version Remote- Replaces Lost or Broken Remote
SKU 00080
was $329.00
Save 24%
$249.00
E95 Scape Converter Kit w/Plug and #3133 Short Adapters
SKU 00118
$799.00
Reverie R600/ R650 Dual Tilt Wireless Rechargeable Remote LED Versions (or Value Non-led Version w/AAA Batteries for $129)
SKU 00069
$449.00
Replacement Remote Compatible with Mattress Firm 600 MF600 or Pillow Tilt Prodigy Basses (Make Sure You’re Getting The Correct One). Value Option Available For $260 Less.
SKU 00162
$499.00
Reverie OSO O400 ERC144A01 Wireless Remote
SKU 00089
was $149.00
Save 9%
$135.00
Mlily Adjustables MS200 TwXL (Buy 2 to make a Split King) Size 750lb Capacity Adjustable Bed w/Free ShippingMlily Adjustables MS200 TwXL (Buy 2 to make a Split King) Size 750lb Capacity Adjustable Bed w/Free Shipping
SKU 00173
was $799.00
Save 19%
$649.00
Replacement Remote Compatible with Tempurpedic B3111-220 Ergo Series TES Wired Remote RC-HW-106 Or Rc-hw-110
SKU 00024
was $149.00
Save 20%
$119.00
Replacement Remote Compatible with Mattress Firm En300 MF300 Series Richmat 8 Button White Version See Pics (Not Black and White Leggett Stand Up or Leggett 7 Button Top Line) Works With ML190 /NL200Replacement Remote Compatible with Mattress Firm En300 MF300 Series Richmat 8 Button White Version See Pics (Not Black and White Leggett Stand Up or Leggett 7 Button Top Line) Works With ML190 /NL200
SKU 00278
was $159.00
Save 25%
$119.00
MLily NU400 or NP2W+ Remote Control -Works With HJC18 And HJH55 Massage Control BoxesMLily NU400 or NP2W+ Remote Control -Works With HJC18 And HJH55 Massage Control Boxes
SKU 10048
was $159.00
Save 9%
$145.00
Reverie 3E RC-WM-109 Wireless Remote
SKU 00026
$349.00
Out of stock
Leggett & Platt Prodigy 1.0 Remote Conversion Kit w Massage Functionality (No Presets or Limits- The Old Remote Is Discontinued) Also Talk to Us About Kits w/o Massage For LessLeggett & Platt Prodigy 1.0 Remote Conversion Kit w Massage Functionality (No Presets or Limits- The Old Remote Is Discontinued) Also Talk to Us About Kits w/o Massage For Less
SKU 00083
was $279.00
Save 11%
$249.00
SKU 00058
was $249.00
Save 24%
$189.00
Reverie OSO O300 ERC239A01 (erc239) 433 MHz Oso300 Wireless Remote
SKU 00166
was $149.00
Save 7%
$139.00
Okin Input Section Only for Power Cord Compatible with Serta/Sealy/Beautyrest (Motion Perfect 2/3/4, Motion Essentials 3/4/5, iSeries, Motion Plus/Air, Motion Custom 2/3, Ease, Extend, SmartmotionOkin Input Section Only for Power Cord Compatible with Serta/Sealy/Beautyrest (Motion Perfect 2/3/4, Motion Essentials 3/4/5, iSeries, Motion Plus/Air, Motion Custom 2/3, Ease, Extend, Smartmotion
SKU 10082
was $79.00
Save 13%
$69.00
Replacement Wireless Remote Compatible with Beautyrest and In Motion (inMotion) Old Gen Renew Plus BasesReplacement Wireless Remote Compatible with Beautyrest and In Motion (inMotion) Old Gen Renew Plus Bases
SKU 00101
$249.00
RC-WM-101 Replacement Remote Compatible with Tempurpedic Ergo Advanced (New Gray RC-WM-119 Version) Remote
SKU 00022
was $149.00
Save 20%
$119.00
Reverie 3E Mesh RC-WM-113 (replaces -117) Wireless Remote 3EM- Used Showroom Model w/o Battery Cover Option Avail For $75Reverie 3E Mesh RC-WM-113 (replaces -117) Wireless Remote 3EM- Used Showroom Model w/o Battery Cover Option Avail For $75
SKU 00027
was $129.00
Save 23%
$99.00
Leggett & Platt C-Series (C Series 9644) Universal Conversion Kit (old Model Disc.)Leggett & Platt C-Series (C Series 9644) Universal Conversion Kit (old Model Disc.)
SKU 00257
was $199.00
Save 10%
$179.00
Leggett & Platt Raven K-120 K120 And Richmat (not Linak) M120 White Remote
SKU 00036
was $149.00
Save 20%
$119.00
Reverie or Purple Powerbase 8Q Or 8X RC-WM-e53 Replacement Remote
SKU 00079
was $149.00
Save 9%
$135.00
Replacement 3pc Conversion Kit w Wireless Remote Compatible with the Discontinued BedTech or Moto Sleep (Motto Sleep) CH13 ZG XSF300 RemoteReplacement 3pc Conversion Kit w Wireless Remote Compatible with the Discontinued BedTech or Moto Sleep (Motto Sleep) CH13 ZG XSF300 Remote
SKU 00238
was $399.00
Save 38%
$249.00
Reverie 8T/9T or R600 R650 RC-WM-110 or Personal Comfort Flex 9 Wireless Remote with Lumbar FeatureReverie 8T/9T or R600 R650 RC-WM-110 or Personal Comfort Flex 9 Wireless Remote with Lumbar Feature
SKU 00044
was $149.00
Save 7%
$139.00
Serta Motion Essentials II (2nd) Gen hb12012-00 M-120 Linak Wired Remote (Alt black version avail. for $60 less!)Serta Motion Essentials II (2nd) Gen hb12012-00 M-120 Linak Wired Remote (Alt black version avail. for $60 less!)
SKU 00002
was $179.00
Save 11%
$159.00
Out of stock
Replacement Remote Compatible with Sealy Old Generation Or Certain Old WRLS 2 VIB Dual Massage
SKU 00126
was $269.00
Save 7%
$249.00
Replacement Remote Compatible with Sealy Ease 1.0 2.0 3.0 or 4.0 - New 6 Button Serta VersionReplacement Remote Compatible with Sealy Ease 1.0 2.0 3.0 or 4.0 - New 6 Button Serta Version
SKU 00248
was $169.00
Save 47%
$89.00
Leggett & Platt Falcon 2.0+ Remote
SKU 00076
was $179.00
Save 58%
$75.00
