Conversion Kit (Basic Model w/Massage) for Reverie RC-WM-102 Legacy Bases (See Pic) -Used for a lost/broken remote. 13 Button Backlit Controls Movement/Massage/Intensity Modes
$249.00
was $399.00 Save 38%
In stock: 8 available
This universal kit converts old generation Reverie wireless bed base control boxes and includes a new wireless remote to control your bed base with massage with three intensities and wave modes. Used to replace a lost or broken remote when there are no more replacements available or in budget. THIS KIT WILL NOT WORK WITH PRESETS LIKE ONE TOUCH FLAT OR MEMORY POSITIONS, we do have a kit that allows for that feature for a bit more if needed.
This kit includes all the wiring and ports needed to make your conversion. Simply unplug your four motors from the existing control box under your bed and plug them into our new unit. All of the remotes showed above used control boxes with five pin connection ports. As long as your box has massage and head and foot motors with five pins in the plugs and your remotes looked similar then this will work. (See above picture)
Total installation should take no more than 5 minutes but it does require plugging in your head and foot motors from under your bed. Kit Includes:
1) Wireless Remote Control with flashlight and backlighting. (Presets, Flat, and Memory Buttons will not work) Each remote uses three AAA batteries (included since we program this prior to shipping.). You can only have one remote paired with one box at a time. If you want to buy a 2nd remote to use as a backup, we sell them for $70 each.
We also offer this remote and control box without the massage features for $179 if interested.
Reverie R600/ R650 Dual Tilt Wireless Rechargeable Remote LED Versions (or Value Non-led Version w/AAA Batteries for $129)
SKU 00069
$449.00
Serta Motion Select (Light Gray Version) Remote
SKU 00039
was $139.00
Save 29%
$99.00
Ergomotion Softide 5100/8100 Remote- Discontinued… See Our New Conversion Kit Ergomotion Softide 5100/8100 Remote- Discontinued… See Our New Conversion Kit
SKU 00091
was $299.00
Save 10%
$269.00
Out of stock
Mlily NP2W, Richmat NU200 or NU202U, Lady Americana, Or Lucid L300 200 Wireless RemoteMlily NP2W, Richmat NU200 or NU202U, Lady Americana, Or Lucid L300 200 Wireless Remote
SKU 10047
was $159.00
Save 19%
$129.00
Reverie RC-WM-E02 (New Version) Replacement Remote
SKU 00273
was $140.00
Save 15%
$119.00
Leggett & Platt Prodigy 1.0 Remote Conversion Kit w Massage Functionality (No Presets or Limits- The Old Remote Is Discontinued) Also Talk to Us About Kits w/o Massage For LessLeggett & Platt Prodigy 1.0 Remote Conversion Kit w Massage Functionality (No Presets or Limits- The Old Remote Is Discontinued) Also Talk to Us About Kits w/o Massage For Less
SKU 00083
was $279.00
Save 11%
$249.00
Serta Perfect Position III New 3 Preset Version Remote
SKU 00040
was $299.00
Save 17%
$249.00
SKU 00058
was $249.00
Save 24%
$189.00
Leggett & Platt Brio 60 Series/ B-122-60 Bello Remote
SKU 00159
$169.00
Replacement Remote Compatible with Sealy Ease 1.0 2.0 3.0 or 4.0 - New 6 Button Serta VersionReplacement Remote Compatible with Sealy Ease 1.0 2.0 3.0 or 4.0 - New 6 Button Serta Version
SKU 00248
was $169.00
Save 47%
$89.00
Replacement Remote Compatible with Adjusta-Magic Signature BASIC ONE VIBE Old Generation E02 -K1, E91SS, Certain Sleep Comfort & Lifestyles Silhouette (see Pics)
SKU 00151
$299.00
Ergomotion V/400 Series 6 Pin New 2 Pc Conversion Kit - See PicsErgomotion V/400 Series 6 Pin New 2 Pc Conversion Kit - See Pics
SKU 00071
was $349.00
Save 23%
$269.00
Replacement 3pc Conversion Kit w Wireless Remote Compatible with the Discontinued BedTech or Moto Sleep (Motto Sleep) CH13 ZG XSF300 RemoteReplacement 3pc Conversion Kit w Wireless Remote Compatible with the Discontinued BedTech or Moto Sleep (Motto Sleep) CH13 ZG XSF300 Remote
SKU 00238
was $399.00
Save 38%
$249.00
Authentic Okin Serta Motion Current Gen (Motion Perfect 2/3/4, Motion Essentials 3/4/5, iSeries, Air, Motion Plus, Motion Custom 2/3) Power Cord 3 Piece Set w Input Cord
SKU 00047
was $109.00
Save 27%
$80.00
Conversion Kit Compatible with Homelegance or Hofish Adjustable Base Remote Conversion Kit Compatible with Homelegance or Hofish Adjustable Base Remote
SKU 00142
was $209.00
Save 5%
$199.00
Okin Massage/Lumbar/Bluetooth/USB Motion Custom Control Box
SKU 10090
was $359.00
Save 3%
$349.00
Ergomotion Softide 8100 Or 8300 Remote- Discontinued- See Our New Conversion Kit
SKU 00111
$249.00
Out of stock
Leggett & Platt Sunrise Remote
SKU 00077
$159.00
Serta Motion Custom II/III Remote - We Also Have a Value Remote Available For $40 Less w/o LumbarSerta Motion Custom II/III Remote - We Also Have a Value Remote Available For $40 Less w/o Lumbar
SKU 00013
was $199.00
Save 15%
$169.00
Ergomotion 6 Button Wired Remote Replacement Conversion Kit (New Control Box And Remote)Ergomotion 6 Button Wired Remote Replacement Conversion Kit (New Control Box And Remote)
SKU 00112
was $299.00
Save 17%
$249.00
Adjusta-Magic E91 (e-91) Or Certain Craftmatic Classic Corded Remotes Replacement (see 2nd Picture)Adjusta-Magic E91 (e-91) Or Certain Craftmatic Classic Corded Remotes Replacement (see 2nd Picture)
SKU 00050
$299.00
Replacement Compatible with Certain iDealbeds (ideal) 4i/c, Certain Craftmatic Legacy, or Leggett & Platt Style Plus, Williamsburg, Frankfurt K-132  18 Button Remote- Make Sure Your Buttons Match Replacement Compatible with Certain iDealbeds (ideal) 4i/c, Certain Craftmatic Legacy, or Leggett & Platt Style Plus, Williamsburg, Frankfurt K-132  18 Button Remote- Make Sure Your Buttons Match
SKU 00102
was $149.00
Save 20%
$119.00
Reverie 3E Tech RC-WM-114 Or R350LP ERC114W00 Wireless Remote- Also We Have a Used Showroom Model Avail For $75Reverie 3E Tech RC-WM-114 Or R350LP ERC114W00 Wireless Remote- Also We Have a Used Showroom Model Avail For $75
SKU 00029
was $129.00
Save 23%
$99.00
Leggett & Platt C-Series (C Series 9644) Universal Conversion Kit (old Model Disc.)Leggett & Platt C-Series (C Series 9644) Universal Conversion Kit (old Model Disc.)
SKU 00257
was $199.00
Save 10%
$179.00
Replacement Wireless Remote Compatible with Beautyrest Black Luxury Or Motion Restore BasesReplacement Wireless Remote Compatible with Beautyrest Black Luxury Or Motion Restore Bases
SKU 00145
was $149.00
Save 30%
$105.00
Adjusta-Magic E90 (e-90) Corded Remote (New Version With A Few Extra Buttons)Adjusta-Magic E90 (e-90) Corded Remote (New Version With A Few Extra Buttons)
SKU 00049
$299.00
Ergomotion E6+ Custom with Light Button (New Grey Version) Remote
SKU 10043
was $149.00
Save 7%
$139.00
Replacement Power Cord Compatible with certain model Sealy and Tempurpedic Extend, Ergo & Ease 1.0/2.0/3.0 - 3 Piece Set
SKU 00042
was $109.00
Save 13%
$95.00
Silver Replacement Remote Compatible With Leggett & Platt S-Cape (scape) 700 or Performance Remote w/pillow Tilt Buttons - See Second Picture for the One You Will ReceiveSilver Replacement Remote Compatible With Leggett & Platt S-Cape (scape) 700 or Performance Remote w/pillow Tilt Buttons - See Second Picture for the One You Will Receive
SKU 00033
$499.00
Replacement Remote Compatible with Bnkdt By Wayfair Blissful Nights, Ergomotion Sherwood Bedding, Or Sapphire Sleep Series Bases- New Alt VersionReplacement Remote Compatible with Bnkdt By Wayfair Blissful Nights, Ergomotion Sherwood Bedding, Or Sapphire Sleep Series Bases- New Alt Version
SKU 00306
$149.00
Leggett & Platt Simplicity HF Remote- Physical Button OEM Version Also Avail For $119- Ask For Info
SKU 10107
was $189.00
Save 11%
$169.00
Replacement Remote Compatible with Sealy Premier X-10 (x10) E97 Dual Vibe RemoteReplacement Remote Compatible with Sealy Premier X-10 (x10) E97 Dual Vibe Remote
SKU 00125
$599.00
Original White Reverie 3E Wired RC-HW-105 or RC-HW-106 Corded Remote- Use Promo Code “TES” To Save $40 For The Black New Gen Option Shown In The 2nd Picture Original White Reverie 3E Wired RC-HW-105 or RC-HW-106 Corded Remote- Use Promo Code “TES” To Save $40 For The Black New Gen Option Shown In The 2nd Picture
SKU 00025
$199.00
Out of stock
MLily Or Idle Sleep NL200/nl200u Remote Control -Works With HJC18 Control Boxes
SKU 10054
was $159.00
Save 25%
$119.00
Mlily Adjustables MS200 Split CalKing (Comes In Two Pieces That Sit Side By Side) Size 750lb Capacity Adjustable Bed w/Free ShippingMlily Adjustables MS200 Split CalKing (Comes In Two Pieces That Sit Side By Side) Size 750lb Capacity Adjustable Bed w/Free Shipping
SKU 10094
was $1 499.00
Save 13%
$1 299.00
Replacement Remote Compatible with Rize Privia/Contemporary II/Avante Remote TRURC-N5 Compatible with New R4 Sealy - Discontinued, See Our New Universal Conversion Kit Replacement Remote Compatible with Rize Privia/Contemporary II/Avante Remote TRURC-N5 Compatible with New R4 Sealy - Discontinued, See Our New Universal Conversion Kit
SKU 00279
$299.00
Out of stock
Leggett and Platt MR2T8TVZG with Massage Speed Scape Raven Remote- Don’t Just Match Remotes- Also Check Your Learn Button Before Ordering- MR2t TVLeggett and Platt MR2T8TVZG with Massage Speed Scape Raven Remote- Don’t Just Match Remotes- Also Check Your Learn Button Before Ordering- MR2t TV
SKU 10044
$299.00
Serta Motion Essentials and Ergo Black 1st Gen 1.0 (New 2 Pc Conversion Kit Version) Remote ReplacementSerta Motion Essentials and Ergo Black 1st Gen 1.0 (New 2 Pc Conversion Kit Version) Remote Replacement
SKU 00001
was $299.00
Save 40%
$179.00
Replacement Wireless Remote Compatible with  Beautyrest Smartmotion 1.0 (New Serta Grey Remote) Smart Motion Bases
SKU 00063
was $169.00
Save 30%
$119.00
Leggett BASIC ONE VIBE Remote Compatible with Old Generation E02 -K1, E91SS, Certain Sealy, Sleep Comfort & Lifestyles Silhouette and Other Models (see Pics)Leggett BASIC ONE VIBE Remote Compatible with Old Generation E02 -K1, E91SS, Certain Sealy, Sleep Comfort & Lifestyles Silhouette and Other Models (see Pics)
SKU 00140
$299.00
Serta Motion Air Headboard Kit- Match Remote Picture 1st! (Remotes Sold Seperatly)Serta Motion Air Headboard Kit- Match Remote Picture 1st! (Remotes Sold Seperatly)
SKU 10100
was $149.00
Save 34%
$99.00
Ergomotion Quest 2.0 Adjustable Remote
SKU 00287
was $199.00
Save 15%
$169.00
Leggett & Platt Premier Series Remote
SKU 00216
$249.00
Remote Replacement Compatible with S-Cape E95 (E-95), Adjusta-Sleep, Certain Old Gen Craftmatic, WRLS 2 VIB, and Certain Contour Premier, Sleep Comfort, Eurosleep, Simmons Series 2000, or Craft 1Remote Replacement Compatible with S-Cape E95 (E-95), Adjusta-Sleep, Certain Old Gen Craftmatic, WRLS 2 VIB, and Certain Contour Premier, Sleep Comfort, Eurosleep, Simmons Series 2000, or Craft 1
SKU 00018
$349.00
Reverie OSO O400 ERC144A01 Wireless Remote
SKU 00089
was $149.00
Save 9%
$135.00
Leggett and Platt Wallhugger S-Cape (New Black Version- Wall Hugger) Old Gen E-95 WRLS 2 VIB Raven RemoteLeggett and Platt Wallhugger S-Cape (New Black Version- Wall Hugger) Old Gen E-95 WRLS 2 VIB Raven Remote
SKU 00019
was $349.00
Save 29%
$249.00
Replacement Remote Compatible with Sleep Number Flex Fit or Select Comfort Shipshape Swingline Corded Bases NEW White OEM VersionReplacement Remote Compatible with Sleep Number Flex Fit or Select Comfort Shipshape Swingline Corded Bases NEW White OEM Version
SKU 00156
$299.00
Okimat 2 Okin Remote Compatible with New Gen Craftmatic/Comfort Base Remote, 258A Model Electropedic, or Saatva Lineal Bases- Must Match Back Of Old Remote Exactly w Oval Button above AAAs Okimat 2 Okin Remote Compatible with New Gen Craftmatic/Comfort Base Remote, 258A Model Electropedic, or Saatva Lineal Bases- Must Match Back Of Old Remote Exactly w Oval Button above AAAs
SKU 00209
$339.00
Leggett And Platt D-Series (D Series) Converter Kit w/Plug, New Motors, and Adapters #4b8900Leggett And Platt D-Series (D Series) Converter Kit w/Plug, New Motors, and Adapters #4b8900
SKU 00143
$399.00
Leggett And Platt Softline Pro-Motion, Swingline, Sleep Number Flex Fit Wired, Series III, or 1st Gen Brio (new Black And White Version- Top Right Pic)
SKU 00073
was $129.00
Save 8%
$119.00
