Replacement Conversion Kit (Must Switch Control Box- We Provide Instructions) Compatible w/Tempurpedic Ergo Up TES Bases-Used for a lost/broken remote. 8 Button Backlit Remote NO PRESETS/FLAT
$179.00
was $349.00 Save 49%
In stock: 13 available
This kit converts old generation 4 pin motors on wireless bed base control boxes and includes a new wireless remote to control your bed base witj backlit lighting and flashlight. Used to replace a lost or broken remote when there are no more replacements available or in budget or to upgrade a basic remote with only a few buttons. This Kit will not operate presets like a one touch flat or zero gravity button or a foot motor (+$20 if you have the Ergo plus model that already includes ahead and a foot motor and you needed an extra small cable). We sell a kit for $249 that would include those deluxe features.
This kit includes all the wiring and ports needed to make your conversion. Simply unplug your two motors from the existing control box under your bed and plug them into our new unit.
Total installation should take no more than 5 minutes but it does require tipping the bed on its side or sliding under the bed to secure the new unit once plugged in.
Kit Includes:
1) Wireless 8 Button (only the head and foot buttons on the flashlight buttons will work on this unit… If you want access to custom presets and one touch flat buttons, we sell a kit for $249. Reach out to us for information.) Remote Control with flashlight and backlighting- Simply plug in the kit after it’s installed and the remote will work. Each remote uses three AAA batteries (included since we program this prior to shipping.). You can only have one remote paired with one box at a time. If you want to buy a 2nd remote to use as a backup, we sell them for $70 each.
We recommend buying a Surge Protector before install if you don’t already have your bed plugged in. This can be a power strip or single box, but its important to make sure the words "Surge Protector" or some variant are on the unit. Usually you can buy both at walmart but the power strip without surge protection is a dollar or two less. Here is a combo strip/protector for $10 on Amazon: https://www.amazon.com/dp/B08466BVJV?ref_=cm_sw_r_...
Also, you can contact us at orders@saltlakemattress.com or 866-448-6879 (text is great) with questions
Ergomotion Softide 2100 WIRELESS Remote - NEW 2 Pc Conversion kit - See attachedErgomotion Softide 2100 WIRELESS Remote - NEW 2 Pc Conversion kit - See attached
SKU 00113
was $299.00
Save 27%
$219.00
Reverie OSO O200 ERC014A01 Wired Remote
SKU 00220
was $149.00
Save 27%
$109.00
Ergomotion E6 Remote
SKU 00093
was $149.00
Save 20%
$119.00
Replacement Remote Compatible with InKline White Noise 5 Button or Black 6 Button BasesReplacement Remote Compatible with InKline White Noise 5 Button or Black 6 Button Bases
SKU 10095
$149.00
Reverie Oasis ERC117 Wireless Remote (New 4M Multi Button Version)
SKU 00092
was $149.00
Save 34%
$99.00
Replacement Remote Compatible with Sleep Number Flex Fit or Select Comfort Ship Shape Corded Bases OEM Version
SKU 00283
$299.00
Replacement Remote Compatible with Living Comfort, Euro Sleep, and WRLS 2 VIBE Adjustable Bed Remote ReplacementReplacement Remote Compatible with Living Comfort, Euro Sleep, and WRLS 2 VIBE Adjustable Bed Remote Replacement
SKU 00305
$349.00
Replacement Remote Compatible with Select Comfort/Sleep Number Flex Fit (flexfit) Precision/Precision+ (New Black Version)Replacement Remote Compatible with Select Comfort/Sleep Number Flex Fit (flexfit) Precision/Precision+ (New Black Version)
SKU 00088
was $299.00
Save 17%
$249.00
Replacement Wireless Remote Compatible with BedTech BT3000 and Bt3000LP and Certain Richmat Flexeez Easy Rest Revive Living Spaces White Wireless Remote (Bed Tech 3000)Replacement Wireless Remote Compatible with BedTech BT3000 and Bt3000LP and Certain Richmat Flexeez Easy Rest Revive Living Spaces White Wireless Remote (Bed Tech 3000)
SKU 00249
was $159.00
Save 25%
$119.00
Leggett & Platt Raven K-120 K120 And Richmat (not Linak) M120 White Remote
SKU 00036
was $149.00
Save 20%
$119.00
Replacement Remote Compatible with Sleep Number Flex Fit (flexfit) BASIC ONE VIBE Non-LCD Version (see Pics)
SKU 00152
$299.00
Leggett & Platt Brio 60 Series/ B-122-60 Bello Remote
SKU 00159
$169.00
Replacement Compatible with Certain iDealbeds (ideal) 4i/c, Certain Craftmatic Legacy, or Leggett & Platt Style Plus, Williamsburg, Frankfurt K-132  18 Button Remote- Make Sure Your Buttons Match Replacement Compatible with Certain iDealbeds (ideal) 4i/c, Certain Craftmatic Legacy, or Leggett & Platt Style Plus, Williamsburg, Frankfurt K-132  18 Button Remote- Make Sure Your Buttons Match
SKU 00102
was $149.00
Save 20%
$119.00
Leggett and Platt Wallhugger S-Cape (New Black Version- Wall Hugger) Old Gen E-95 WRLS 2 VIB Raven RemoteLeggett and Platt Wallhugger S-Cape (New Black Version- Wall Hugger) Old Gen E-95 WRLS 2 VIB Raven Remote
SKU 00019
was $349.00
Save 29%
$249.00
Remote Replacement Compatible with S-Cape E95 (E-95), Adjusta-Sleep, Certain Old Gen Craftmatic, WRLS 2 VIB, and Certain Contour Premier, Sleep Comfort, Eurosleep, Simmons Series 2000, or Craft 1Remote Replacement Compatible with S-Cape E95 (E-95), Adjusta-Sleep, Certain Old Gen Craftmatic, WRLS 2 VIB, and Certain Contour Premier, Sleep Comfort, Eurosleep, Simmons Series 2000, or Craft 1
SKU 00018
$349.00
Conversion Kit Compatible with Boyd Specialty Sleep Adjusta Flex 5 Button Corded Remote (new 3 Pc Conversion Kit Version, See Pics)Conversion Kit Compatible with Boyd Specialty Sleep Adjusta Flex 5 Button Corded Remote (new 3 Pc Conversion Kit Version, See Pics)
SKU 10061
was $199.00
Save 10%
$179.00
Replacement Wireless Remote Compatible with Serta or Beautyrest Motion Air (New Black Version) BasesReplacement Wireless Remote Compatible with Serta or Beautyrest Motion Air (New Black Version) Bases
SKU 10057
$159.00
Replacement Remote Compatible with MR2 Scape for Ergo Raven Bases by Tempurpedic GSMR2
SKU 00023
$249.00
Replacement Remote Compatible with Certain MLily, Sven & Son, Classic Brands, or Idle Sleep NL300/nl300u Bases -Works With HJC18 Massage or NU203CB Control Boxes (Style May Vary)Replacement Remote Compatible with Certain MLily, Sven & Son, Classic Brands, or Idle Sleep NL300/nl300u Bases -Works With HJC18 Massage or NU203CB Control Boxes (Style May Vary)
SKU 10045
was $159.00
Save 15%
$135.00
Ergomotion Softide 8100 Or 8300 Remote- Discontinued- See Our New Conversion Kit
SKU 00111
$249.00
Out of stock
Leggett & Platt Brio 40 Series Remote
SKU 00158
$169.00
Serta Perfect Position II BASIC ONE VIBE Old Generation E02 -K1, E91SS, New 2020 Raven Version (see Pics)Serta Perfect Position II BASIC ONE VIBE Old Generation E02 -K1, E91SS, New 2020 Raven Version (see Pics)
SKU 00146
$299.00
Linak Authentic OEM Power Cord Set Compatible with Serta Motion Essentials 2, Motion Slim, Leggett & Platt 100 Series II, S-cape, Renew Basic And Plus Series, & Beautyrest Simple Motion BasesLinak Authentic OEM Power Cord Set Compatible with Serta Motion Essentials 2, Motion Slim, Leggett & Platt 100 Series II, S-cape, Renew Basic And Plus Series, & Beautyrest Simple Motion Bases
SKU 00053
was $169.00
Save 47%
$89.00
Okimat 2 Okin Remote Compatible with New Gen Craftmatic/Comfort Base Remote, 258A Model Electropedic, or Saatva Lineal Bases- Must Match Back Of Old Remote Exactly w Oval Button above AAAs Okimat 2 Okin Remote Compatible with New Gen Craftmatic/Comfort Base Remote, 258A Model Electropedic, or Saatva Lineal Bases- Must Match Back Of Old Remote Exactly w Oval Button above AAAs
SKU 00209
$339.00
Okin Massage Control Box Replaces Keeson Kesson Control Box Model Number MC121 MC122 (mc121bs, Mc122sc)
SKU 00290
$199.00
Conversion Kit 2 Piece for the Disc. Leggett & Platt S-Cape (scape) 1.0, 1.0+, 500, 700 or Simplicity 2.0 Remote - See Pictures. Inc. New Control Box, & Grey Remote w/Massage/Presets (No Pillow Tilt) Conversion Kit 2 Piece for the Disc. Leggett & Platt S-Cape (scape) 1.0, 1.0+, 500, 700 or Simplicity 2.0 Remote - See Pictures. Inc. New Control Box, & Grey Remote w/Massage/Presets (No Pillow Tilt)
SKU 00031
was $299.00
Save 17%
$249.00
Learn Cord For Certain Linak Bases
SKU 00275
$99.00
Leggett And Platt Softline Pro-Motion, Swingline, Sleep Number Flex Fit Wired, Series III, or 1st Gen Brio (new Black And White Version- Top Right Pic)
SKU 00073
was $129.00
Save 8%
$119.00
Reverie 3E RC-WM-109 Wireless Remote
SKU 00026
$349.00
Replacement Remote Compatible with Bnkdt By Wayfair Blissful Nights, Ergomotion Sherwood Bedding, Or Sapphire Sleep Series Bases- New Alt VersionReplacement Remote Compatible with Bnkdt By Wayfair Blissful Nights, Ergomotion Sherwood Bedding, Or Sapphire Sleep Series Bases- New Alt Version
SKU 00306
$149.00
Replacement Wireless Remote Compatible with  Beautyrest Smartmotion 1.0 (New Serta Grey Remote) Smart Motion Bases
SKU 00063
was $169.00
Save 30%
$119.00
Silver Replacement Remote Compatible With Leggett & Platt S-Cape (scape) 700 or Performance Remote w/pillow Tilt Buttons - See Second Picture for the One You Will ReceiveSilver Replacement Remote Compatible With Leggett & Platt S-Cape (scape) 700 or Performance Remote w/pillow Tilt Buttons - See Second Picture for the One You Will Receive
SKU 00033
$499.00
Leggett and Platt Old Gen Raven (New 3 Preset Version) MR2T8TVZG-PM Or Series V/ V Elite E95 Scape Remote- Mr2tLeggett and Platt Old Gen Raven (New 3 Preset Version) MR2T8TVZG-PM Or Series V/ V Elite E95 Scape Remote- Mr2t
SKU 00105
$249.00
Replacement Remote Compatible with Mattress Firm 300 Series Topline 7 Button Phoenix Mecano Leggett Brand (Not Richmat 8 Button or Black/White Standup) Remote
SKU 00141
$229.00
Leggett and Platt Bas-x 2.0 Series Leggett Corded Remote
SKU 00164
was $129.00
Save 8%
$119.00
Adjusta-Magic E91 (e-91) Or Certain Craftmatic Classic Corded Remotes Replacement (see 2nd Picture)Adjusta-Magic E91 (e-91) Or Certain Craftmatic Classic Corded Remotes Replacement (see 2nd Picture)
SKU 00050
$299.00
Replacement Remote Compatible with Idealbeds 5i/custom Wireless Remote (New Name brand Replacement Remote With All The Same Features- ideal)Replacement Remote Compatible with Idealbeds 5i/custom Wireless Remote (New Name brand Replacement Remote With All The Same Features- ideal)
SKU 00277
was $149.00
Save 20%
$119.00
Replacement Remote Compatible with Sleep Number Or Select Comfort Flex Fit And Flex Fit+ Plus (flexfit) DUAL VIBE Non-LCD Version (see Pics)
SKU 00154
was $249.00
Save 4%
$239.00
Replacement Remote Compatible with Certain Model Craftmatic Legacy (l132 L-132 Series) Linak Bed Remotes- See Our Universal Conversion Kits
SKU 00043
$549.00
Replacement Remote Compatible with Interflex Silver or Old Gen Specific Simmons Corded Bases (Must Look The Same- includes Cord)
SKU 10040
$399.00
Ergomotion/Blissful Nights/InKline/Essence/Motion Air 5 or 6 Button Wireless Remote (Value Grey Remote Available For $119)Ergomotion/Blissful Nights/InKline/Essence/Motion Air 5 or 6 Button Wireless Remote (Value Grey Remote Available For $119)
SKU 00272
$159.00
RC-WM-101 Replacement Remote Compatible with Tempurpedic Ergo Advanced (New Gray RC-WM-119 Version) Remote
SKU 00022
was $149.00
Save 20%
$119.00
Ergomotion E4 or Tempur (must Match Picture Exactly) WIRED 2 Piece Conversion Kit- New Wireless White Remote & Control Box, See PicsErgomotion E4 or Tempur (must Match Picture Exactly) WIRED 2 Piece Conversion Kit- New Wireless White Remote & Control Box, See Pics
SKU 00116
was $299.00
Save 43%
$169.00
Reverie OSO O400 ERC144A01 Wireless Remote
SKU 00089
was $149.00
Save 9%
$135.00
Reverie 2E/3E Head Only 2 or 3 Button Corded RemoteReverie 2E/3E Head Only 2 or 3 Button Corded Remote
SKU 00281
was $139.00
Save 14%
$119.00
MLily NU400 or NP2W+ Remote Control -Works With HJC18 And HJH55 Massage Control BoxesMLily NU400 or NP2W+ Remote Control -Works With HJC18 And HJH55 Massage Control Boxes
SKU 10048
was $159.00
Save 9%
$145.00
Replacement Remote Compatible with Sleep Number Flex Fit or Select Comfort Shipshape Swingline Corded Bases NEW White OEM VersionReplacement Remote Compatible with Sleep Number Flex Fit or Select Comfort Shipshape Swingline Corded Bases NEW White OEM Version
SKU 00156
$299.00
Replacement Remote Compatible with Sealy Corded Old Gen RemoteReplacement Remote Compatible with Sealy Corded Old Gen Remote
SKU 00284
was $139.00
Save 14%
$119.00
Leggett and Platt Replacement Remote Compatible with Old Blue Craftmatic, or Sealy Swingline Blue Wired Remote (Swing Line) - New Black VersionLeggett and Platt Replacement Remote Compatible with Old Blue Craftmatic, or Sealy Swingline Blue Wired Remote (Swing Line) - New Black Version
SKU 00129
was $149.00
Save 20%
$119.00
Leggett and Platt MR2T8TVZG with Massage Speed Scape Raven Remote- Don’t Just Match Remotes- Also Check Your Learn Button Before Ordering- MR2t TVLeggett and Platt MR2T8TVZG with Massage Speed Scape Raven Remote- Don’t Just Match Remotes- Also Check Your Learn Button Before Ordering- MR2t TV
SKU 10044
$299.00
