Conversion Kit Compatible with Old Tempurpedic, Ruoey lung, or Rize Bed With Basic Remote - No Presets Or Massage- Simply Plug In Your Motor Cables
+8
+7
$179.00
In stock: 4 available
This is a conversion kit for an old generation 4 pin DIN temper 101 delta drive or roeuy lung rize bed. We are referring to your motor plugs when we mention 4 pin DIN. If you have a wired remote, it’s possible that it has five pins but this kit is still compatible so long as your red and white motor plugs have 4 (See one of the two control box styles in our pictures to ensure compatibility). It includes 2 built-in ports to allow you to simply plug in your existing head and foot motor cables.
This listing includes one remote (no presets) and a new control box, which all are programmed to work together. Each  remote uses three Included AAA batteries.
We also sell a four port version for $299 if you want to use the massage motors on your bed
SKU 10113
was $399.00
Save 8%
$369.00
Four Button BASIC Two Pack Remote/Universal Conversion Kit for One Old Adjustable Bed (Most beds Since 2000-motors must be 24v) -Used for a lost/broken or disc. remote. Controls Head/Foot Up/DownFour Button BASIC Two Pack Remote/Universal Conversion Kit for One Old Adjustable Bed (Most beds Since 2000-motors must be 24v) -Used for a lost/broken or disc. remote. Controls Head/Foot Up/Down
SKU 10119
was $449.00
Save 11%
$399.00
