9 Button Deluxe Version (No Massage) Conversion Kit for Old Generation Customatic, Rize, Reverie, Bobs, or Roeuy Lung or Tempurpedic Ergo Plus Delta Drive Head/Foot (not Premier) Control Boxes
$219.00
was $379.00 Save 42%
In stock: 6 available
Because the original remotes and parts have been discontinued, replacing a lost or broken old generation Remote requires converting the electronics with one of these conversion kits which includes a new gen wireless remote to control your bed base. We have several different kits available per base depending on budget and required functionality. This is a conversion kit for an old generation 4 pin DIN customatic/roeuy lung/delta drive bed. (your old wired remote may have had five pins… But we are referring to the head and foot motors when we talk about four pin DIN switch -See one of the two control box styles in our pictures to ensure compatibility). It includes 2 built-in ports to allow you to simply plug in your existing head and foot motor cables. Our nine button remote is preprogrammed to control the movement of your bed, head up or down and foot up or down as well as give you several one touch presets and a one touch flat button as well as a flashlight on the remote.This will not operate any massage functionality of your bed although we do have an upgraded kit available for $80 more.
This listing includes one 9 button remote, a new control box, and a new power supply which all are programmed to work together. You can purchase a second backup remote for $70 more by viewing our other listing but you can only have one remote program at a time.
Each remote uses three Included AAA batteries.
We also sell a four port version for $299 if you have massage motors on your bed or a harness kit for $199 that requires cutting your wires (279 massage)
#ukit
SKU 10113
was $399.00
Save 8%
$369.00
Four Button BASIC Two Pack Remote/Universal Conversion Kit for One Old Adjustable Bed (Most beds Since 2000-motors must be 24v) -Used for a lost/broken or disc. remote. Controls Head/Foot Up/DownFour Button BASIC Two Pack Remote/Universal Conversion Kit for One Old Adjustable Bed (Most beds Since 2000-motors must be 24v) -Used for a lost/broken or disc. remote. Controls Head/Foot Up/Down
SKU 10119
was $449.00
Save 11%
$399.00
