Conversion Kit 2 Piece for the Disc. Leggett & Platt S-Cape (scape) 1.0, 1.0+, 500, 700 or Simplicity 2.0 Remote - See Pictures. Inc. New Control Box, & Grey Remote w/Massage/Presets (No Pillow Tilt)
$279.00
was $299.00 Save 7%
In stock: 23 available
This listing is for a two-piece Conversion Kit. Since the original remote was completely discontinued, this is the only way to get your bed up and running again.
The new remote will have all the same functionality as the original remote, and as a bonus, you can program two remotes to work with one bed base if you want to have another remote in a nightstand as a back up, or on the other side of the bed
Additional remotes are $119. This kit will include one remote and one control box (plugs into your existing power supply) and adapters. If you have a split king bed and both of your remotes are lost or broken, you will need to purchase two conversion kits. We will program the remote before sending. The light button will not transfer with this kit unless you hardwire it into the adapter slot marked yellow or pay a $30 upgrade for us to provide a special harness.
Please make sure to match your old remote before ordering this kit to ensure compatibility
Depending on what style control box you have, you may have to switch one or two wires on an adapter cable that we sell, but we will walk you through that with detailed instructions and you can always reach out to us for Customer Support. You can also purchase a separate Wi-Fi adapter for $119 if you wanted to have access access to a smart app.
We do sell a kit for $100 less but your massage cables and the presets will work and it will require cutting some cords under the bed to get it working. Reference the basic version with the white remote if you want to purchase that one
- Text me with any questions! Matt with bedremotes.com by Salt Lake Mattress- (866) 448-6879-
Sealed In Packaging 100 Piece Brand New AAA Battery Set
SKU 10081
$25.00
SKU 10113
was $399.00
Save 8%
$369.00
