Reverie 3E Mesh RC-WM-113 (replaces -117) Wireless Remote 3EM 10 Button Replacement
$119.00
was $129.00 Save 8%
In stock: 10 available
If your original remote matches this one shown, You can use this remote or the upgraded version WM – 114 3E tech, which will give you preset features. Each remote cost the same price. Due to current supply chain constraints, you may receive the upgraded version as a replacement to this but it will work exactly the same, plus potentially give you some added benefits - The logo may vary from unit to unit, but the chip inside and Shell will be identical and the additional presets should work with your bed
Sealed In Packaging 100 Piece Brand New AAA Battery Set
SKU 10081
$25.00
SKU 10113
was $399.00
Save 8%
$369.00
