Replacement Wireless Remote Compatible with Revive
BT6500 6500 Bedtech Bed Tech, MLily NE500 Bases - White Version With Lumbar NOTE No Bluetooth Icon
Replacement Wireless Remote Compatible with Revive BT6500 6500 Bedtech Bed Tech, MLily NE500 Bases - White Version With Lumbar NOTE No Bluetooth Icon
$125.00
was $149.00 Save 16%
In stock: 41 available
As the title states, the new remote that you will receive is the white one pictured first. There are several presets on the remote, so you can customize one touch settings very easily. Note, if your old remote or control box had a Bluetooth icon, this remote will not work, and you need to see our other listing
