Replacement Wireless Remote Compatible with Revive BT6500 6500 - Alt Bedtech Version Bed Tech, MLily NE500 Bases - White Version With Lumbar NOTE No Bluetooth Icon
$125.00
was $149.00 Save 16%
In stock: 39 available
As the title states, the new remote that you will receive is the white one pictured first but with a BedTech Logo. There are several presets on the remote, so you can customize one touch settings very easily. Note, if your old remote or control box had a Bluetooth icon, this remote will not work, and you need to see our other listing
