Replacement Wireless Remote Compatible with  BT6500 6500 Bedtech Bed Tech, MLily NE500 or Revive Deluxe Bases - NOTE: Bluetooth Icon Version- See Info
$199.00
In stock: 2 available
This Remote replaces Bed Tech BT6500 models that have a Bluetooth icon in the bottom corne…. not the black flat glass remote form Leggett. Once you have matched your white remote, you will also see the Bluetooth icon on your control box.
There are two versions of this bed base, one with the Bluetooth icon and one without it. The remotes are on different frequencies. Please check with us if you have any questions.
