Replacement Wireless Remote Compatible with
BT6500 6500 Bedtech Bed Tech, MLily NE500 or Revive Bases - White Version With Lumbar NOTE No Bluetooth Icon
Replacement Wireless Remote Compatible with BT6500 6500 Bedtech Bed Tech, MLily NE500 or Revive Bases - White Version With Lumbar NOTE No Bluetooth Icon
$125.00
was $149.00 Save 16%
In stock: 42 available
You will receive a replacement remote that looks the same as the one pictured with the Bed Tech logo. There are several presets on the remote, so you can customize one touch settings very easily. Note, if your old remote or control box had a Bluetooth icon, this remote will not work, and you need to see our other listing
