Replacement 3 Piece Conversion Kit Compatible w Simmons Nuflex or Softide 8100 Or 8300 (Includes Support For Lumbar And Pillow Tilt) 6 Pin - New White Version Remote- Replaces Lost or Broken Remote
$549.00
was $699.00 Save 21%
In stock: 6 available
As of 2018, the manufacturer has discontinued the old remote and this listing is for the 2 piece conversion kit (Control box and new remote). You will be required to unplug four cords from the old control box wnd your power cord and plug them into this new kit. This original remote had a rigid sides for the nuflex or a button on the top edge for the Softide. All 3 have been replaced by this kit and functions wil be the same. If your bed had four massage motors, you can leave two unplugged (most do) or splice them together for maximum functionality. If your old bed had lumbar motors and you want to have those active, we do offer an upgraded kit for double the cost. We also have a non-massage version of this same kit for $199 if you never really used massage and wanted to save some money here:
https://www.adjustablebedremotes.com/#!/Serta-Motion-Essentials-1-0-New-Deluxe-Grey-Preset-Version-2-Pc-Conversion-Kit-Replacement-Remote/p/635711964
One other neat thing about converting is you can now have two remotes paired with one control box. If you have a queen bed, now you can have one remote per nightstand for only $119 more! Reach us if interested
SKU 10113
was $399.00
Save 8%
$369.00
