Remote Compatible with Craftmatic Classic, E90, E91, or E-92 (only Single Massage Will Work) Wired Replacement For Certain Wired Craft Corded Remotes E-90 E-91 E-92
$299.00
In stock: 11 available
This will only work to replace corded remotes that looked the same or had the same shape and button design as the ones shown in the picture. If your old remote was wireless instead of wired, this will not work and you would require a conversion kit from a separate listing. There are some slight scratches on the cords from the shipping container, but they are all tested and working in perfect order. Please check with us if you have any questions before ordering to avoid lost shipping expense
