ORIGINAL LED VERSION Reverie 8T/9T RC-WM-110 or Personal Comfort Flex 9 Wireless Remote with Pillow Or Lumbar Feature
$549.00
In stock: 2 available
Make sure all your buttons are the same before ordering! The remote that you will receive will have a T in the middle, but they are the exact same units as the one with a L or P. If you are OK, not having the pillow or lumbar functionality, we do have the same remote without that lumbar button for $150 less available here: https://www.adjustablebedremotes.com/#!/Reverie-7t-or-R400-450-And-R550-non-Pillow-Tilt-RC-WM-111-Wireless-LED-Remote-CHECK-PROCESSOR-BOX-BEFORE-ORDERING/p/175118260
SKU 10113
was $399.00
Save 8%
$369.00
