Grey Serta Logo Remote with 3 Extra Presets- Replacement Compatible with Serta Motion Perfect 2.0 With Rubber Learn Button (Not 6 PIN)
$99.00
was $149.00 Save 34%
In stock: 4 available
Please ensure that you need this version rather than the older 1.0 version that features a 6 pin dip switch rather than a clear rubbery button behind the battery cover like this model features. This remote has smooth sides whereas the 1.0 Version had rigid sides, also the word “massage” is in different places. If this is the right remote you will see a power down box with a spot for two 9V batteries under your frame. The old white version has been replaced by a grey one but it is made by the same maker and has the same functionality with three additional functional buttons!
EAN: 7426885247065
Also, we have a value version of this same remote from the same manufacturing company available for $20 less
SKU 10113
was $399.00
Save 8%
$369.00
