This universal kit converts old bed base control boxes with an easy-to-install 3 step process and includes a new wireless remote to control your bed base with advanced features like presets, one touch flat, and massage with three intensities and wave modes… even if your old bed did not have those features! (Note.. if your old bed did not have massage, that will not be an option on this new one either). Used to replace a lost or broken remote when there are no more replacements available or in budget or to upgrade a basic remote with only a few buttons.
This kit includes all the wiring and harnesses needed to make your conversion. Total installation should take no more than 5 minutes but it does require tipping the bed on its side. If you want to ensure that this model is compatible, look at your actuator motors under the bed and verify that they are 24V or 29V. (We have converted several bases without issue and almost all of the beds we have looked at that have been made after 2005 use the 24V voltage, but ultimately we have not tested every bed on the market so cutting your wires is at your own discretion. You can however splice them back together if the conversion does not work so ultimately there is not a huge risk.)
We send detailed instructions and even are in the process of recording videos for different models that we are converting on our showroom to make this as easy as possible. There are three steps to installing this unit. First, tip your bed on its side and unplug it from the wall. Second, cut the cords of the head and foot actuator motor and strip the forward and reverse wires and repeat for each massage motor (see our video). Third, slide each wire into its corresponding hole in our harness and click down the clamp with your thumb. Then secure the boxes to your frame with our zip cables we provide, plug the new power cord in, and you’re good to go!
Kit Includes:
1) Conversion Control Box with Wire Harnesses and a Power Supply Cable/Transformer Box - Simply click in the wires once cut and plug in the unit!
1) Wireless Deluxe Remote Control with flashlight and backlighting- (depending on inventory, you will either get a remote with or without massage buttons but on this kit it will not have that feature so the massage buttons will not do anything) Simply plug in the kit after it’s installed and the remote will work. Each remote uses three AAA batteries (included since we program this prior to shipping.). You can only have one remote paired with one box at a time. If you want to buy a 2nd remote to use as a backup, we sell them for $70 each.
1) Zip Tie Cable to secure the new box under the bed
1) Wire Stripper or Pair of Scissors (we recommend a good but inexpensive pair of strippers as it will make the stripping process a lot easier and quicker. Here is a pair on Amazon that we bought for $6 and use in our instruction video): https://www.amazon.com/gp/aw/d/B06X9875Z7?psc=1&ref=ppx_pop_mob_b_asin_title
We also sell a basic 4 button remote kit for $159 if you wanted to save some money
