Conversion Kit Compatible with Ashley Sierra Sleep M9X5 or M9X7 and Motto Sleep FB Ch05 and 3 Button Ch03 Bases, Includes New Model Remote (X7 Or X5)
$169.00
was $209.00 Save 19%
In stock: 8 available
This is a two piece conversion kit for the Ashley Sierra Sleep m9x5 or x7 and 3 button ch03 bed base. simply unplug your head and foot motor cord from under your bed and plug them into our new control box and then plug the control box in and you will be up and running! We will program the remote prior to sending it and include instructions. The new remote features a flashlight and one touch presets to make the bed more functional.
 Note, if your original base had specialty features such as an under bed LED or USB port plug-ins, the new control box will not adapt that and you can work around those with a simple five dollar cable or light add on from Amazon if needed.
And finally, it’s important to know that one control box is required per bed. If you have a split king which is essentially two bases pushed up side-by-side, you would need two of these kits if you no longer have any working remote.
SKU 10113
was $399.00
Save 8%
$369.00
