Conversion Kit 3 Pc w/Remote Replacement- NON MASSAGE VERSION Compatible w Ashley HHC Moto (Motto) Sleep Ch05B, X5, M9x6 X6, M9X7 X7, M9x8 X8, And M9X9 Adjustable Bases
$189.00
was $209.00 Save 10%
In stock: 11 available
This is a two piece conversion kit for the Remote pictured in the listing. You will receive a new control box and a new wireless remote with the same features as the originaly. The remote will be slightly different shape but all of the functionality will be the same (with the exception of the massage in this unit) but we have a flashlight button and one touch flat on our new remote!
We will provide installation instructions but it is as easy as unplugging two cords from under the bed and plugging them into our new unit. We will Pre-program the remote for you so once you plug in your unit and put AAA batteries in the remote, you will be good to go. This also includes a brand new power supply.
If you wanted to special order a version of this kit that would include massage features. The cost would be $80 more and would require cutting your massage motor wires and sliding them into to our harness. Let us know
Note, if your original base had specialty features such as an under bed LED or USB port plug-ins, the new control box will not adapt that and you can work around those with a simple five dollar cable or light add on from Amazon if needed.
And finally, it’s important to know that one control box is required per bed. If you have a split king which is essentially two bases pushed up side-by-side, you would need two of these kits if you no longer have any working remote.
SKU 10113
was $399.00
Save 8%
$369.00
