Comfortbase, Structures or Rejuven 8 (rejuven8 rejuvenate) or Puffy Certain Enso Okin Refined Conversion Kit For New Gen Craftmatic/Comfort Base Remote, 258A Model. Model Specific Non-Massage Version
$199.00
was $499.00 Save 60%
In stock: 12 available
This is for a two-piece Conversion Kit. It replaces the original remote with a new gray wireless, remote and control box. Your head and foot motor will simply plug into the new control box and we pair the remote before shipping so everything will work perfectly. This is a safe and easy process to do because it is DC-voltage 24 V.
If your old Remote had massage, you can upgrade for $20 to a kit that will include an adapter for that functionality
Most people don’t really use the massage on this unit so if yours did have massage, you can simply leave it unplugged.
SKU 10113
was $399.00
Save 8%
$369.00
